Orion 2 BMS with Zombiverter
Rustybkts
Post by Rustybkts »
I have followed all Damien's videos with relish but haven't seen anything regarding the integration of an Orion BMS or any BMS in the video's or the forum.
I note that there are three BMS choices in the parameters but no Orion.
Has anyone used an Orion with the Zombiverter as otherwise, I will need to wire a relay cutout in the charging circuit which is a bit heavy handed to say the least.
LRBen
Has thanked: 58 times
Been thanked: 147 times
Re: Orion 2 BMS with Zombiverter
Post by LRBen »
I've used Orion BMS in a couple conversions with Zombie. What I usually do is to configure Orion to send the BMS messages in the same format as SIMP BMS then just use that as the BMS option.
Rustybkts
Post by Rustybkts »
LRBen wrote: Sat May 04, 2024 11:43 am I've used Orion BMS in a couple conversions with Zombie. What I usually do is to configure Orion to send the BMS messages in the same format as SIMP BMS then just use that as the BMS option.
That's great.
I have used the CAN messaging a lot on my Evora conversion to enable the CAN instruments.
Where do I find the SIMP BMS message format as I'm new to the Openinverter site.
LRBen
Post by LRBen »
Rustybkts wrote: Wed May 08, 2024 9:24 am That's great.
They should be on the simp BMS manual here https://github.com/Tom-evnut/SimpBMS
I believe they are also the same as Victron canbus IDs.
Rustybkts
Post by Rustybkts »
Hi LRBen,
Any chance of publishing the CAN messages between Orion and Zombiverter as I couldn't find them on the link above.
Cheers
Has thanked: 149 times
Been thanked: 340 times
LRBen wrote: Wed May 08, 2024 6:41 pm Victron canbus IDs
You can turn on the victron CAN in the Orion software
