Video: What is Battery Balancing? Learn it in 5 minutes
janosch
Has thanked: 98 times
Been thanked: 106 times
Post by janosch »
Hello,
second of these, I explain battery balancing for you with a few animations, and go into some edge cases too.
By the end of it you should have a grasp of:
  • Why bother with battery balancing?
  • What is battery balancing?
  • What happens if you have a weak cell in your battery pack?
  • What is Active Cell Balancing?
  • What is Passive Balancing?
Let me know what you think, feedback much appreciated. I am currently making one about the C-Rate and have got two more queued up. The goal is to explain just one concept each in about 4-10mins, and not tied to a product or device, but explain the underlying knowledge in an engaging way.
I hope this helps.
Has thanked: 360 times
Been thanked: 249 times
Re: Video: What is Battery Balancing? Learn it in 5 minutes
Post by jrbe »
That was great. I think the videos you make should get links added in the wiki as you go.
Zieg
Has thanked: 168 times
Been thanked: 160 times
Post by Zieg »
That flying capacitor thing is very cool, I had no idea that was a means of active balancing.
Where would a shunt feature fall into this mix? I believe the concept is that during charging some current is bypassed around a high cell, but not sure.
Has thanked: 328 times
Been thanked: 847 times
Shunt is just a resistor across the cells. So that would be passive balancing.
Been thanked: 1913 times
jrbe wrote: Tue Sep 03, 2024 8:43 pm That was great. I think the videos you make should get links added in the wiki as you go.
I linked both videos to the new main page https://openinverter.org/wiki/Main_Page_New
janosch
Post by janosch »
Zieg wrote: Wed Sep 04, 2024 2:46 pm I believe the concept is that during charging some current is bypassed around a high cell, but not sure.
This is great that's coming up. Thats exactly what I thought about BMS for a while. It took me ages to understand how simple they really are!
Thanks everyone, next videos are already in the pipeline :)
