support cell balancing on VW Passat GTE pack
Hi I am try to find a BMS that will support cell balancing on VW Passat GTE pack?
- Has thanked: 82 times
- Been thanked: 422 times
Re: support cell balancing on VW Passat GTE pack
SimpBMS should. I used it on my Beetle with success
Thanks just manual did state not sported, as it does work do you or any body know were the best place to buy it?
Its ok just got one off ebay for £250 used with screen
- Has thanked: 206 times
- Been thanked: 563 times
Yea simpBMS manual has not been updated in a long time. I stopped properly supporting it and updating due to it no longer being made now for over 2 years.
VW balancing is working for the GTE packs.
I am using SimpBMS can the CAB300 senser and VW battery Can live on the same bus? or do i need to add another can bus?
