MG ZS EV Shift Controller
EVS2K
Post by EVS2K »
There's no MG subsection so I'll ask here.
I'm using a Tesla SDU w/OI in a Honda S2000 (hmm, no mention of MG yet?).
BUT, I'm using the battery and other electronics out of an MG ZS EV (Ahh, there it is!).
The OpenInverter board simple uses a three position switch for shift select. I have it wired as Up for Forward, Centre for Neutral, Down for reverse. But the MG comes with a nice rotary controller I'd like to implement. From the docs I have it is simply a CAMbus device that receives and sends CAN signals to select condition and illuminate feedback lights. It requires 12v on three lines (power, ignition, and ready), GND, and CAN Hi and Lo. If I connect to an Arduino board I can receive the signals and operate relays in place of the switch.
My question (finally) is does anyone have experience with the MG ZS EV shift controller mechanism and more specifically the pint of the connector?
Has thanked: 195 times
Been thanked: 506 times
Re: MG ZS EV Shift Controller
People are currently working on this. You will need a controller to interpret this CAN and then transmit it to the SDU OI board.
What are you doing for the BMS?
Has thanked: 128 times
Been thanked: 325 times
EVS2K wrote: Sat Aug 17, 2024 2:22 am There's no MG subsection so I'll ask here.
Can you provide PN for device and wiring schematic and i can insert it in wiki under MG section?
EVS2K
Post by EVS2K »
I've made some progress.
EVS2K
Post by EVS2K »
tom91 wrote: Sat Aug 17, 2024 11:47 am What are you doing for the BMS?
Option 1: Get the MG system happy
Option 2: Aftermarket
