Hi All.
Does anyone have the schematic of the charger module?
I'm specifically interrupted inthe input section on the AC side with intention to examine the component rating for possibility of running the charger from DC (HV battery) supply.
Any info, help, suggestions will be greatly appreciated.
Unfortunately the board is not easy to remove to check.
(I want to build DIY home DC charger to allow for faster home charging for cars with only 7kw AC charging like MG5. It would charge from large solar/battery (~60kwh) system, and charging directly from hv battery will remove need for large inverter and reduce/remove losses at the inverter)
Martin
Tesla gen3 charger schematic
- Kutato72
- Has thanked: 2 times
- Been thanked: 26 times
Re: Tesla gen3 charger schematic
The Gen3 OBC input has a thyristor soft-start circuit. If you give it DC and it accidentally turns on, it will immediately smoke with a huge bang from the inrush current surge.
