Zomie Shunt needed ?
zippy500
Has thanked: 100 times
Been thanked: 7 times
Post by zippy500 »
My project is running a leaf gen 2 motor/invertor, with a Zombie controlling it.
Do I still need to get a IVT-S current shunt ?
Does the leaf invertor measure current ?
Has thanked: 330 times
Been thanked: 848 times
Re: Zomie Shunt needed ?
Yes you need a shunt, shunt is always required for Precharge control.
zippy500
Post by zippy500 »
OK thanks, had a quick look on the forum as to install, is just a case of wiring it up to the Zombie , then setting it up ?
Yes Zombie has param you toggle to have it set it up once.
