Can Bus question
johnsongt350
Can Bus question
Post by johnsongt350 »
I installed a screen to read the can bus however I may not have programmed it correctly. Can someone please review my parameters and can bus IDs.
I can buy time also if needed. But if it's something I can just update in the parameters I'm happy to do so.
johnsongt350
Re: Can Bus question
uhi22
Has thanked: 245 times
Been thanked: 684 times
Post by uhi22 »
It would be helpful if you describe your observed behavior and expected behavior. E.g. nothing is shown on your display, or values are arriving but with wrong values or missing completely or start ok and later are stuck or or or.
johnsongt350
I can see the inverter can id however no values are displayed
uhi22
Post by uhi22 »
To divide the search range I propose to look on the CAN, eg using SavvyCAN. In best case this shows that the messages are on bus (multiple times per second) and you could check their content.
