Our Prius has a 3.3kW onboard AC charging system, which takes almost 2 hours to charge on AC. However, the CHAdeMO charging system takes 15min to 20min at 15kW to 17kW, depending on temperature etc. So for us the reasons are:
- 1. There are many more Type 2 (and J-1772) stations available than CHAdeMO, CCS-SAE, and Tesla chargers combined (and likely to remain so).
2. The Type 2 points are not just more plentiful but are often immediately available whereas the CHAdeMO (and CCS) chargers are often in use or have a queue (... at least where I live).
3. Installation and maintenance of charging points is much cheaper for AC than DC, so in future AC charging points will remain more plentiful and will more frequently provide low-cost charging. Hence retailers, employers, public services, etc. can afford AC chargers. The result is that non-domestic AC charging points will remain more plentiful and much cheaper than DC into the future (and more often be free-of-cost).
4. In many places 22kW is easy to install domestically so fast charging at home at 22kW becomes possible. Since the Prius's CHAdeMO has a max.power of 17kW then for me this would represent fast charging at its best.
5. We can charge much faster using CHAdeMO (DC) than using AC.
I have found something similar to buy in the internet: but this leaves the rectification up to the onboard charging system, I think. Although different, related posts include: Does anyone know of a Type 2 to CHAdeMO Converter to buy? or if it would be easy to construct?
