Yes, see my video a few posts back. Seems pretty similar to GS450H, some inverter wiring shares same pinout as the LS300H. Zombieverter seems to talk to it fine on GS450H setting, at least at low speed on bench. Fingers crossed it will continue to work as hoped.Jacobsmess wrote: ↑Wed Nov 22, 2023 9:31 pm Have you spin up the ls600H transmission yet? Is it identical to the GS450H bar the transfer box?
I like the look of that Hyundai EPAS, it looks way more compact than the Corsa options that are commonly used.
The Hyundai Sonata EPAS is bigger than most other systems, motor and gearbox size, which is why I chose it for my truck, given the bigger wheels. Taking a chance on it, but seems to work well. Can be clocked in different orientations which worked in my favor.
