What does triggering an error do? [SOLVED]
- Has thanked: 3 times
- Been thanked: 21 times
Hi everyone, I have been starting to drive my car recently and want to set current limits. However, I have opened contactors on a motor while spinning it before and killed an inverter, so I'm scared to trigger any kind of error. When I have my parameters set to TripMode AllOn or Keep DC switch closed, what is the reaction of the logic board to, say, an overcurrent error? The wiki says the reaction is "STOP," but I'm not quite sure what that means. Will it stop taking throttle input? Will I need to turn the motor off and on again to clear the error? Thank you!
- Has thanked: 237 times
- Been thanked: 278 times
Re: What does triggering an error do? [SOLVED]
As long as the trip mode is correct, when an error that causes Stop occurs, it means it safely shuts off the inverter. I believe in most cases it can be restarted with a new start signal, however the Tesla LDU has shown a unique occurrence where the OI control board reports "Overcurrent" but it is actually a hardware Desat error. In those cases, it still shuts down safely, but it needs a 12V power cycle (key off, then on and start) to restart.
One other note: If you are relying primarily on regen braking, a STOP error and shut down will mean you don't have regen, and will have to stop solely on your physical brakes. This can be disorienting and/or scary the first time it happens.
TLDR: If the trip mode is right, hitting a STOP error is safe, you just lose regen braking and will need to restart the inverter.
Ok, very good to know. Thanks for the warning as well, seems like you have some experience
Yeah I do, I really do....
(I've hit so damn many errors at so many inconvenient times)
