What sort of size vacuum tanks for braking is generally being used for conversion ?
Is this one OK ?
https://www.ebay.co.uk/itm/225975793716
What size Vacuum tank
- Has thanked: 134 times
- Been thanked: 335 times
Re: What size Vacuum tank
I found additional tank unneccary complication and too much plumbing.zippy500 wrote: ↑Sat Apr 20, 2024 6:46 pm What sort of size vacuum tanks for braking is generally being used for conversion ?
Is this one OK ?
First try to connect pump directly but leave provision for tank if needed.
Use of good switch is all the difference. I use Volvo xc90 switch...
