[DRIVING] BMW Z3
andybpowell
Has thanked: 198 times
Been thanked: 236 times
Re: [WIP] BMW Z3
Post by andybpowell »
barracuda816 wrote: Sat Apr 06, 2024 8:50 am I am terrible at reading charts. What are the axis values here? When you say speed are you referring to motor rpm or vehicle mph?
the speed is motor rpm on the right hand scale the inverter temp and current on the left
andybpowell
Re: [WIP] BMW Z3
Here's the latest run hit a max speed of 65mph felt strong and smoothe just ran out of road
6.7mph per 1000 rpm so for me a theoretical 94mph if it makes max rpm and it feels like it will
Has thanked: 260 times
Been thanked: 70 times
Re: [WIP] BMW Z3
Post by Jacobsmess »
What does that work out at rpm/V?
Has thanked: 106 times
Been thanked: 228 times
Re: [WIP] BMW Z3
Jacobsmess wrote: Sat Apr 06, 2024 5:33 pm What does that work out at rpm/V?
Did you see his speed level off? So there is no point speculating.
andybpowell
Re: [WIP] BMW Z3
managed to get an extra 5mph had to brake pretty hard at the end of it though
I really need to get to a decent stretch of road so 70 Mph and still pulling strong
Re: [WIP] BMW Z3
Gosh darnit, looks like I might have to sell both the leaf motor and GS450H at the rate!
Re: [WIP] BMW Z3
Jacobsmess wrote: Sun Apr 07, 2024 3:24 pm Gosh darnit, looks like I might have to sell both the leaf motor and GS450H at the rate!
Why? GS450h has a way higher prop speed. And also should be the more powerful motors.
The only real upside of the IS300h is the not needing of an externa oil pump.
Re: [WIP] BMW Z3
tom91 wrote: Sun Apr 07, 2024 3:49 pm Why? GS450h has a way higher prop speed. And also should be the more powerful motors.
No oil pump, simpler, less to go wrong, lighter and smaller
Re: [WIP] BMW Z3
Jacobsmess wrote: Sun Apr 07, 2024 4:03 pm No oil pump, simpler, less to go wrong, lighter and smaller
Down side: 4500 rpm prop speed limit. Lets not dilute this thread more with things already covered in other topics.
Woodfie
Has thanked: 164 times
Re: [WIP] BMW Z3
Post by Woodfie »
andybpowell wrote: Sun Apr 07, 2024 3:11 pm managed to get an extra 5mph had to brake pretty hard at the end of it though
Very Impressive, thanks for graf and graphing.
Would you be able to do some stable runs at any 10mph, 20mph, 30 mph, ........etc. etc .
Keen to know approximate stable current draw data.
Much appreciated if not too difficult to find an airfield
( just kidding) or decent bit of flat road.
andybpowell
Re: [WIP] BMW Z3
Woodfie wrote: Sun Apr 07, 2024 8:18 pm Very Impressive, thanks for graf and graphing.
decent empty road is my problem I'm afraid :)
Woodfie
Re: [WIP] BMW Z3
Post by Woodfie »
andybpowell wrote: Sun Apr 07, 2024 8:39 pm decent empty road is my problem I'm afraid :)
Yes, imagine that is a challenge.. anything approximating stable current draw , you can manage would be great, as your chart can be interpolated to suit difficult request folks like myself. Thanks.
andybpowell
Re: [WIP] BMW Z3
Woodfie wrote: Sun Apr 07, 2024 10:47 pm Yes, imagine that is a challenge.. anything approximating stable current draw , you can manage would be great, as your chart can be interpolated to suit difficult request folks like myself. Thanks.
no problem happy to help where I can
Aragorn
Has thanked: 5 times
Been thanked: 53 times
Re: [WIP] BMW Z3
Post by Aragorn »
looks like circa 325A and 350v at the battery? so ~115kw
Is it still limited in software, or is that all it will give?
Woodfie
Re: [WIP] BMW Z3
Post by Woodfie »
andybpowell wrote: Mon Apr 08, 2024 8:33 am no problem happy to help where I can
One question, the time line on the bottom, is that on tenths of a second,
looks exceptional acceleration if that is so. Thanks
Woodfie
Re: [WIP] BMW Z3
Post by Woodfie »
Looks like hundreds, so 30 to 60mph in couple of seconds .
Helps put your earlier post in line.. about screaming and wheel spinning down the road.😆
andybpowell
Re: [WIP] BMW Z3
Aragorn wrote: Mon Apr 08, 2024 8:44 am looks like circa 325A and 350v at the battery? so ~115kw
It's limited in software currently
andybpowell
Re: [WIP] BMW Z3
Woodfie wrote: Mon Apr 08, 2024 11:06 am Looks like hundreds, so 30 to 60mph in couple of seconds .
No idea on the bottom scale
royhen99
Has thanked: 17 times
Been thanked: 109 times
Re: [WIP] BMW Z3
Post by royhen99 »
I think the numbers across the bottom are sample number. The time varies with "Burst length" but from tests I have done it is about 27-28ms per sample with "Burst length" = 10.
andybpowell
Re: [WIP] BMW Z3
80 ish it might have been 78-79 but near enough
need more road
barracuda816
Has thanked: 21 times
Been thanked: 12 times
Re: [WIP] BMW Z3
Post by barracuda816 »
This is fantastic. Really shows the l210 is a usable option. Thanks for sharing all your hard work.
Re: [WIP] BMW Z3
Amazing, 12000 rpm and no signs of levelling off!
Woodfie
Re: [WIP] BMW Z3
Post by Woodfie »
:D Great work, has put my attempted use of the Prius zvw30 inverter with the L210 sadley to rest... To be replaced with the 300h inverter, and have ordered a Zombie, to follow the path you have blazed... Again well done and thanks.. Enjoy your Zipping 3 around :evil:
mfox
Re: [WIP] BMW Z3
Post by mfox »
barracuda816 wrote: Tue Apr 09, 2024 11:55 am This is fantastic. Really shows the l210 is a usable option. Thanks for sharing all your hard work.
I though from the beginning it should not be a problem whit top speed, despite those gear rations etc...
I mean , Lexus top speed wasn't 100-120 km/h.. It is much more with the same gearbox... Why should be now the problem..
ok , you need to change low ratio diff etc.. but that is not problem..
And I believe max power is approx the same as 450h, despite official rating.. Maybe is gh450 slightly more but nothing significant.
I think Is300 is better option then gs450. Smaller, lighter, single speed, no extra oil pump (no extra 12v power consumption), It has PARKING LOCK prop,
easier to run...
andybpowell
Re: [WIP] BMW Z3
My Z3 is pretty much off the road for now as the extremely harsh power delivery makes it hard to drive safely and will tear out my bushes some of the updates in the Zombie pipeline should relieve or hopefully fix this issue so I'm doing the jobs I put off while evaluating the feasibility of the 300h which I think we can all agree has been decided as a yes it is.
My rear battery box only has a fuse, no contactor and no safety disconnect the contactor I have and is a simple fix and I have purchased a kia niro (I believe) safety disconnect which also contains a fuse, the only issue with it is that the fuse sits about 10mm higher than the mountings for the disconnect
So I made an adapter to allow me to mount it flush with the top of my rear battery box, since I dont have a 3d printer or the cad skills required I made it using my CNC mill which was probably a lot quicker than printing anyway
I also need to tidy the wiring and plumbing
