[DRIVING] BMW Z3  [FINISHED]
Has thanked: 480 times
Been thanked: 137 times
Re: [WIP] BMW Z3
Post by Jacobsmess »
Video is showing as private ignore this, seems to have fixed itself now...
andybpowell
Has thanked: 218 times
Been thanked: 257 times
Re: [WIP] BMW Z3
Post by andybpowell »
Jacobsmess wrote: Thu Mar 14, 2024 5:56 pm Video is showing as private
no it's public
andybpowell
Re: [WIP] BMW Z3
The dc to dc circuit I was using as an economiser was using was a little erratic it turns out the onboard pot was overly sensative causing the hold voltage to fluctuate so have swapped to a more robust circuit which has solved the issue and the bms was doing some strange things, the number of modules/cells was not always reading correctly for some reason if the contactors are enabled before the bms detects the modules/cells it doesn't detect them all, but if I just give it a second(literally) between power on and start it's fine not sure why
andybpowell
Re: [WIP] BMW Z3
So just a little update I've mostly been tidying up the wiring and plumbing and making some minor tweeks but mostly been taking the car on progressively longer trips out checking everythings tight, no rubbing or pulling cables and generally trying not to leave tyre marks on the road which is really hard with the available torque and gearing basically getting it ready for it's mot which is due in 3 weeks I've also managed a stable spped test and it does 40mph at 6000 rpm so at max revs 80mph i really need a lower ratio diff
Re: [WIP] BMW Z3
What are you calling max revs and what is dictating that?
andybpowell
Re: [WIP] BMW Z3
Jacobsmess wrote: Thu Mar 21, 2024 5:49 pm What are you calling max revs and what is dictating that?
actually that's wrong I had 12000 rpm in my head for some reason at 14000 max mg2 rpm that would be 93 this obviously assumes the mg2 max speed is achievable and this is just an assumption only testing will tell and I will get to that at some point
Woodfie
Has thanked: 221 times
Been thanked: 95 times
Re: [WIP] BMW Z3
Post by Woodfie »
Well done on your progress, is the only other driving if a L210 other than the Bmwagon test that I know of.
Have just rcvd a gs300h or crown inverter from Japan, and to replace the Prius zvw30 inverter driving the L210 transmission.. Have 3.75 diff ratio, which i feel will be a speed limitation.. So keen to follow your progress.
Did you have a path to the code you are using please, to make the tyres Mark's on the road..
andybpowell
Re: [WIP] BMW Z3
Woodfie wrote: Tue Mar 26, 2024 12:44 am Well done on your progress, is the only other driving if a L210 other than the Bmwagon test that I know of.
use te latest zombie 2.05a release
andybpowell
Re: [WIP] BMW Z3
I've done about 20 miles in the car today without any issues inverter temp is about 20 deg C but spikes quite rapidly during acceleration but hasn't peaked over about 33 yet and motor has reached a massive 35 deg C :lol: and I've been driving quite hard within the local speed limits (max 50)
barracuda816
Has thanked: 74 times
Been thanked: 23 times
Re: [WIP] BMW Z3
Post by barracuda816 »
Can't wait to see if it will happily cruise at 70-80ish, would be interesting to see current draw and if the temp stays stable at that speed.
Re: [WIP] BMW Z3
What does the motor temp get to out of curiosity?
Stupid me. I misread. 35degC!
Has thanked: 264 times
Been thanked: 717 times
Re: [WIP] BMW Z3
andybpowell wrote: Sat Mar 30, 2024 12:11 pm motor has reached a massive 35 deg C
Jacobsmess wrote: Sat Mar 30, 2024 3:58 pm What does the motor temp get to out of curiosity?
Woodfie
Re: [WIP] BMW Z3
Post by Woodfie »
andybpowell wrote: Sat Mar 30, 2024 12:11 pm I've done about 20 miles in the car today without any issues inverter temp is about 20 deg C but spikes quite rapidly during acceleration but hasn't peaked over about 33 yet and motor has reached a massive 35 deg C :lol: and I've been driving quite hard within the local speed limits (max 50)
Nice progress............. Wondering.
Do you have a current measure at stable 50,? and is that mph or kph ?
Alibro
Has thanked: 416 times
Been thanked: 277 times
Re: [WIP] BMW Z3
Post by Alibro »
I saw very similar behaviour last night but I suspect it is because I made some changes to the PWM that controls the coolant pump. I intend to turn up the duty cycle to get a bit more flow.
Is it possible your inverter is not getting cooled enough?
andybpowell
Re: [WIP] BMW Z3
Woodfie wrote: Mon Apr 01, 2024 1:44 am Nice progress............. Wondering.
mph and no sorry not yet
andybpowell
Re: [WIP] BMW Z3
Alibro wrote: Mon Apr 01, 2024 6:28 am I saw very similar behaviour last night but I suspect it is because I made some changes to the PWM that controls the coolant pump. I intend to turn up the duty cycle to get a bit more flow.
coolant temp is low and flow is more than adequate with twin pumps I don't think the spikes are excessive or anything to worry about it was just an observation really :)
andybpowell
Re: [WIP] BMW Z3
Considering the roads and traffic around here I actually managed to get some reasonably stable constant speed runs done this morning on some level roads
Woodfie
Re: [WIP] BMW Z3
Post by Woodfie »
Nice result there
Thanks for that, looks a vast improvement on the Prius Gen 3 inverter attempt, motor matching issues maybe.
Have initiated BMWagon swap to crown inverter, of matching part number, so hope to fly it soon.
Bintang 5
Has thanked: 6 times
Re: [DRIVING] BMW Z3
Post by Bintang 5 »
andybpowell wrote: Tue Sep 19, 2023 2:19 pm Most of my new parts arrived today, lexus 300h inverter
and the wiring loom
any chance you have the partnumber of the wire loom?
I was looking for a used loom, but without the proper partnumber it's almost impossible to find one...
andybpowell
Bintang 5 wrote: Mon Apr 01, 2024 12:17 pm any chance you have the partnumber of the wire loom?
no sorry stripped it out to what i needed threw the rest
andybpowell
Re: [WIP] BMW Z3
I managed to hit the high voltage limit on the outlander dc-dc yesterday. after charging my battery up I went to take it for a drive and noticed the aux batt volts was dropping took me a while to catch on the battery was only at 393v I thought it was supposed to stop at nearer 397v ? though when I plugged the charging cable back in it came on so it appears to ignore this during charging, I suppose worse case if I want those extra few volts I could send can signals to charge at 0 Amps when ign is on and not charging when above a certain voltage
Alibro
Re: [WIP] BMW Z3
Post by Alibro »
My dc to dc works fine up to 400V. I don't usually charge that high as I still haven't sorted the BMS but the charger was fine with it.
Has thanked: 455 times
Been thanked: 1771 times
Re: [WIP] BMW Z3
Mine turns off at 400V and turns back on at 393V. So short acceleration bursts are sufficient to start it back up but likely short regen bursts turn it off again.
andybpowell
Re: [WIP] BMW Z3
So does anyone know of a reason that I can't or should not send the charger the messages to charge at 0 Amps when batt volts are above 393v and the ignition is on and not charging to overcome this ?
barracuda816
Re: [WIP] BMW Z3
andybpowell wrote: Mon Apr 01, 2024 8:49 am Considering the roads and traffic around here I actually managed to get some reasonably stable constant speed runs done this morning on some level roads
I am terrible at reading charts. What are the axis values here? When you say speed are you referring to motor rpm or vehicle mph?
