Suitable Precharge resistor for GS450h inverter
- acollins22
- Has thanked: 9 times
- Been thanked: 6 times
Hi Folks,
I am still accumulating the parts for my '79 Scimitar/Lexus GS450h project.
I am now thinking of the precharge. I have seen various online calculators but they all want to know the internal capacitance of the load (inverter). As I am by no means the first to tread this path, please can someone suggest suitable values (resistance, wattage) for a GS450h inverter, fed with ~400v.
If you could also tell me the suspected current, I'll be able to choose a suitable relay too
Thanks,
Andy.
Thanks,
Andy.
- PatrcioEV-ATX
- Has thanked: 40 times
- Been thanked: 60 times
Re: Suitable Precharge resistor for GS450h inverter
Technically, I have no idea. I'm using the contactors and precharge resistor out of a 1st gen LEAF. Just bought the whole set up. All is working as expected.
2012 Nissan Leaf (sold)
2016 Mercedes B250e (sold)
2023 Volvo C40
2023 Volvo C40
- acollins22
Hi PatrcioEV,
Thanks for the reply. I've had a look on ebay here in the UK but couldn't find any Leaf contactors. Are they part of a specific module and if so, what's it called.
Thanks,
Andy.
Thanks,
Andy.
- PatrcioEV-ATX
This is what I bought. Paid $100 I believe. https://www.ebay.com/itm/225442479775?h ... R6LghdfyYQacollins22 wrote: ↑Mon Apr 17, 2023 7:46 pm Hi PatrcioEV,
Thanks,
Andy.
You can see my HVJB here: https://www.instagram.com/p/CgSWSl4uJwg/
2023 Volvo C40
2023 Volvo C40
- acollins22
- Has thanked: 15 times
- Been thanked: 8 times
hi,id love to know if your leaf contactors are able to hold with the gs450 setup, what is your maximum current? I used the same nissan leaf gen1 contactor but all result into permanent shut weldingPatrcioEV-ATX wrote: ↑Tue Apr 18, 2023 5:41 pm This is what I bought. Paid $100 I believe. https://www.ebay.com/itm/225442479775?h ... R6LghdfyYQ
- Been thanked: 13 times
I stuck a 40ohm unit from an Outlander PHEV on mine and monitored the current, it peaked at 17A and dropped to a few amps in just a few seconds, that seemed fine for me, so I went with that.
It's essentially an RC circuit, the capacitor value in the inverter is known, and the capacity of your inline fuse is known, so keep the peak current below that while still allowing the capacitor to charge quickly enough for it to not be inconvenient.
- PatrcioEV-ATX
I have not had any issues with the contactors thus far. I think I pull maybe 550 amps peak.joeflickers wrote: ↑Sun Mar 17, 2024 3:44 am hi,id love to know if your leaf contactors are able to hold with the gs450 setup, what is your maximum current? I used the same nissan leaf gen1 contactor but all result into permanent shut welding
2023 Volvo C40
2023 Volvo C40
What is your battery voltage and your precharge dc switch voltage settings?PatrcioEV-ATX wrote: ↑Tue Mar 19, 2024 1:09 pm I have not had any issues with the contactors thus far. I think I pull maybe 550 amps peak.
What is your battery voltage and your precharge dc switch voltage settings? I also get this error (thottle12diff) on when throttle is pressed below half, could you be having a solution for this?PatrcioEV-ATX wrote: ↑Tue Mar 19, 2024 1:09 pm I have not had any issues with the contactors thus far. I think I pull maybe 550 amps peak.
- PatrcioEV-ATX
I am using the GS450h VCU, not the Zombiverter if that matters. My voltage is 252-344 empty to full (not truly 0 or 100%). I use an Arduino in my HVJB to run the contactors and just do it by time - negative and precharge close, pause, positve closes, pause, precharge opens.joeflickers wrote: ↑Sun Mar 24, 2024 11:55 am What is your battery voltage and your precharge dc switch voltage settings? I also get this error (thottle12diff) on when throttle is pressed below half, could you be having a solution for this?
2023 Volvo C40
2023 Volvo C40
