Filter on current sensor input
joromy
Post by joromy »
Having problems with noise from the ABS circuit, possibly trigger overcurrent. Goes away if ABS is disconnected.
ABS active is connected to IN_BMS input for derating REGEN.
What is max recommended Hz for the input filter on IL inputs, without compromising the real current sensing?
Is there any fitering in software?
Re: Filter on current sensor input
In sine version filtering mainly affects over current detection speed. In FOC version also filter delay must be taken into account, but I guess it will work down to 10-20kHz
joromy
Post by joromy »
It is sine version.
I have 15kHz, so It may be better to filter the ABS circuit.
