Gen 2 Charger V5 Software Development Thread
- Been thanked: 1138 times
Setting up a new thread for development of software for the new STM32F103C8T6 based logic board for the Tesla Gen 2 10kw charger.
Design files (with my screwups fixed) for the boards released on Github :
https://github.com/damienmaguire/Tesla- ... /master/V5
New boards ordered from JLC and will start proper work once they arrive.
Here is my pathetic attempt to flash an LED and pump out some CAN messages.
https://github.com/damienmaguire/Tesla- ... 5/Software
The plan :
1) Ripoff as much of Johannes's code as possible.
2) Download this book into my brain : https://www.amazon.co.uk/Beginning-STM3 ... 274&sr=8-1
3) Offer free boards to people who want to help develop the code then ripoff their hard work for my own benefit.
4)Retire to Lanzarote.
The plan :
- Been thanked: 1918 times
Re: Gen 2 Charger V5 Software Development Thread
One little hint: thou shall use libraries. Try to use as much files from libopeninv unchanged. Check out the "git submodule" command on how to link a copy to your project. You don't have to compile all files, just what you need.
That way you are compatible with the Wifi code as is.
doobedoobedo
I spotted a flaw in your plan - you missed out the "???" step before you got to "profit".Jack Bauer wrote: ↑Tue Jan 21, 2020 11:49 am The plan :
Oh yeah wasn't it something like :
1)Collect underpants
2)????
3)Profit
2)????
3)Profit
doobedoobedo
I pass on offering to get you started on your new ventureJack Bauer wrote: ↑Tue Jan 21, 2020 6:50 pm Oh yeah wasn't it something like :
2)????
3)Profit
I'm interested to help with development.
I have both a master and a slave unit.
And I have done some work on embedded units in the past.
Even with FreeRtos. But not on the Stm however.
send me a pm so we can discuss if I qualify....
Regards
/Per
Regards
/Per
Thanks will take you up on that once I have some new boards into stock early Feb. I really screwed up the first design:)
on the new schematic V5, I'm missing the pats and the connection for CAN_EXTH/L and CANH3/L3
These are not implemented on the V5. Please let's keep this thread for software development and post support questions on the charger board support thread.
Similarly interested in testing/developing for the V5 board.
This ST part new to me too, but I've worked a lot with similar TI ARM based MCUs, TI-RTOS/FreeRTOS and CANBus etc.
- Kevin Sharpe
- Been thanked: 10 times
The firmware is currently in development but I'm sure you'll find plenty to do once the code is released to GitHub
viewtopic.php?f=10&t=78&p=6663#p6663
Beta firmware for the V5 :
https://github.com/damienmaguire/Tesla- ... er_Gen2_V5
Note this is untested as delays at JLC due to corona virus. Will see if I can cobble something together with a bluepill.
This firmware also support wifi via the unversal interface with the following parameters being available :
The information will be provided over serial to the esp8266 at 19200 baud 8n1 on uart3 in the form :
vaxxx,vbxxx,vcxxx,iaxxx,ibxxx,icxxx,uaxxx,ubxxx,ucxxx,aaxxx,abxxx,acxxx* where :
va=AC volts Module 1
vb=AC volts Module 2
vc=AC volts Module 3
ia=AC Current Module 1
ib=AC Current Module 2
ic=AC Current Module 3
ua=DC Volts Module 1
ub=DC Volts Module 2
uc=DC Volts Module 3
aa=DC Current Module 1
ab=DC Current Module 1
ac=DC Current Module 1
*=end of string
xxx=three digit integer for each parameter eg va230 = 230volts.
updates will be every 100ms approx.
*=end of string
First test of the new STM32 based software is looking good. Tom's menu system working as it should:)
- Has thanked: 330 times
- Been thanked: 848 times
Wait something I code actually works.
Has the Settings menu now been transformed into something more user friendly? ( I have not dug into the settings menu of the opensource version recently)
I quite like what I achieved with my SimpBMS code, a frozen settings screen that you can just send the corresponding identifier 'number or letter' and value and it 'automatically' refreshes the settings overview.
Sorry for the noob question, but what tools are you using to compile and link the code base.
ST's website shows at least 4 tool options tho TrueSTUDIO (Eclipse/CDT) by Attolic seems to be the default 'free' tool chain.
https://www.st.com/content/st_com/en/su ... -step.html
With TrueSTUDIO, I can open the eclipse project in Charger_Gen2_V5, but build fails as there is no 'make' in the installation. Seems the project is not setup to use the Eclipse/CDT internal builder.
Now I could fix this a few different ways, and happy to use the right make tool from a command line.
Would like to setup my environment the same way you guys do to get started.
Wow, Gen 2 chargers have really come down in price lately. I think it's time to upgrade from this Lear deal. Ill be happy to do some testing once I get some hardware on order.
Thanks for the tip - no problem now building the V5 code base from github!Jack Bauer wrote: ↑Thu Feb 20, 2020 8:15 am Uses the CubeIDE:
https://www.st.com/en/development-tools ... beide.html
Can't wait to get testing - ready to get a board when ready.
Pleased to announce the new charger boards are working well on the bench. Next up testing under actual charge conditions in the Panzer. I'll make boards available in the shop soon for beta testers.
So we have our first bug. The proximity pin is used to detect the presence of the charge plug and also to determine the current carrying capability of the cable by means of a resistor divider. In the original arduino code it looks like this :
if ( parameters.type == 2)
if ( val > 950)
Proximity = Unconnected;
else
Proximity = Connected;
if ( val < 950 && val > 800)
cablelim = 13000;
if ( val < 800 && val > 700)
cablelim = 20000;
if ( val < 600 && val > 450)
cablelim = 32000;
if ( val < 400 && val > 250)
cablelim = 63000;
the arduino uses 10bit adc but I'm guessing the stm32 uses a higher resolution as it reports connected even with 3.3v on the adc pin.
if ( val > 950)
else
cablelim = 13000;
cablelim = 20000;
cablelim = 32000;
cablelim = 63000;
Yes. Still no luck with this bug. Have confirmed no hardware problems.
- Kevin Sharpe
It's a long time since I played with this but iirc it's the EVSE that does the cable current measurement and limits its Pilot PWM accordingly. The car only uses Proximity to see whether a cable is connected. In this post you can see more details when using a J1772 connector;Jack Bauer wrote: ↑Fri Mar 13, 2020 1:46 pm The proximity pin is used to detect the presence of the charge plug and also to determine the current carrying capability of the cable by means of a resistor divider.
viewtopic.php?f=10&t=78&start=290#p8424
Edit: I've attached the diagram from the 61851 standard. Note the resistors defining the cable current capacity, "RC".
Edit2: I've had a chat with one of my colleagues and they reminded me that it was only in later versions of the standard that resistor "RC" was included in connectors at *both* ends of the cable (in early versions of the standard it was at the EVSE end only). When we get access to the workshop i'll check some cables and see whether we can safely assume "RC" is installed in both connectors.
Edit3: I'll open a bug report on GitHub just to capture the potential issue.
