Possible error on OpenInverter Wiki ?  [SOLVED]
ImportFanatiK
Has thanked: 6 times
Post by ImportFanatiK »
I am wiring up the 23 pin ampseal connector, and I noticed a discrepancy regarding the reverse gear on the wiki on this page here:
https://openinverter.org/wiki/Tesla_Mod ... _I/O_Plug
The table suggests reverse should be pin 8, but this image earlier on the page suggests it should be pin 5:
https://openinverter.org/wiki/File:LDU_ ... iagram.png
My assumption is that the correct pin for reverse (when using the open inverter LDU board) is pin 8.
Could anyone confirm?
Thanks,
- James
Re: Possible error on OpenInverter Wiki ?  [SOLVED]
Actually on the same page in the "non-zoomed" diagram it also says pin 8 so assuming that is correct
ImportFanatiK
I installed the open inverter board today into the LDU and booted it up via the harness. I can confirm that pin 8 is the correct pin for reverse (I flipped the switch to reverse and the value was reflected correctly in open inverter).
