Nissan Leaf
13
38%
Toyota Prius
15
44%
Other (No Outlanders in US)
6
18%
Total votes: 34
Has thanked: 630 times
Been thanked: 1607 times
Re: 1984 Voltswagen Rabbit Prius Gen 3
here I was just unwrappin' the larger plug section
So I did go out and but the transmission wire harness from a local wrecker for $100
Has thanked: 478 times
Been thanked: 308 times
Post by MattsAwesomeStuff »
Ugh.
The penalty for urgency. Otherwise, Pick N Pull would have them around for $15.
Then again I'm 5 years into my summer project and you're actually getting stuff done, so, $100 here and there is cheap progress.
MattsAwesomeStuff wrote: Wed Jan 31, 2024 9:14 pm Ugh.
Did you miss the part about the way that Pick N Pull uninstalls the inverters using a machete
... and get off your [ahem] donkey, or I'll fly out there and help !
Gregski wrote: Thu Feb 01, 2024 3:49 amDid you miss the part about the way that Pick N Pull uninstalls the inverters using a machete
Oh, I figured that was some previous scrapper. The rule of Junkyards is, if it would take you 10 seconds longer to not damage a $500 component... don't waste your time.
Hey, you know what would make it a tiny bit easier to get the bolt out? If I crushed this entire adjacent panel. *crunch* Way better.
Only thing they get kinda grouchy about is glass, 'cause it can't get picked up with a magnet.
FEBRUARY GOALS
soooo, Day 1, how's it going?
in this video I take a shower with the Toyota Prius Gen 3 transmission
ha ha, made you look !
Commencing deICEing:
the stock radiator had to come out to make it easier to drop the engine later
it brought it's side kick with it
we don't need no windshield squirters where we're going
won't be needing the fuel filterator
dropped the DC-DC Converter [ Beta version ]
I couldn't get MG1 [ also beta ] off until I removed the engine
first time in the garage
I luv this pic
some say he was once late for a pint because he had to drop a 1.6L diesel engine all by himself on his way to a brewery...
Tools Needed:
Been thanked: 1913 times
On my last 2 conversions I didn't even bother draining the oil. Left it in there for the buyer to use :) Fortunately both tanks were near empty. Since we replaced the petrol mower with an electric one I have absolutely no use for the smelly juice.
*eyes the room nervously*
Surely Greg won't finish 2 EVs before I get mine rolling.
6.5 hours to de-ice. I spent 6.5 hours yesterday not even finishing a single bracket yet.
And Greg edits far slower than he works. So this is all long in the past.
*goes back to work on that bracket...*
MattsAwesomeStuff wrote: Sun Feb 11, 2024 7:19 am *goes back to work on that bracket...*
actual pic of Matt's bracket
Actual picture of the actual bracket...
Another 5 hours today.
If I had a lift? No problem. Walk under the car with a drill, drill out 4 holes, they'll be perfect the first time, 5 minutes, 1 minute per hole plus a little assembly, job done.
Without a lift? Blindly scrape at the end of the reach of your fingertips where you think the hole should be drilled. Lay on your back with your hands over your head, trying to guess what angle the drill should be held at. Can't put any pressure on it so you're stepping up 8 drillbits on each hole. Doesn't fit, holes are off center and drilled crooked. Try to file them smooth, on your back, hands over your head, where you have no leverage. Every time you want to switch sides of the bracket, crawl out from under the car, walk around the other side, lay down and shimmy under again because I have to work on the car discretely in the parkade and can't just put it up on jackstands. 5 hours later.
delgadb2
Post by delgadb2 »
I think that's an ac/dc inverter. 8-)
Gregski wrote: Sun Feb 04, 2024 4:27 pm dropped the DC-DC Converter [ Beta version ]
delgadb2 wrote: Mon Feb 12, 2024 7:49 pm I think that's an ac/dc inverter. 8-)
attempting to pressure wash the Rabbit's engine bay using the World's Worst DeWalt Pressure Washer aka the WWDPW...
so coming up next is Motor Mounts, here is a random pic of the 3rd gen Prius transaxle with its stock mounts still on it for reference
There are 3 stock mounts on the transmission itself, all three are rubber mounted to the chassis.
1. The Top Mount (left side / driver side in the US)
2. The Front Mount (closest to the radiator core support)
3. The Back Mount (closest to the firewall)
some say he's been known to hire amateur actors off of Fiverr to pretend to be his friends while they help him with his EV Conversions...
