Zombie config setup wrong in wiki?
86elcamino
- Has thanked: 6 times
- Been thanked: 3 times
Zombie gs450h not working. After hours of double checking everything, I noticed that status was "potpressed", so I changed to pot min to slightly above offthrottle readings, and everything started working. Am I misreading the config directrions in the wiki?
royhen99
- Has thanked: 22 times
- Been thanked: 134 times
Re: Zombie config setup wrong in wiki?
The wiki is just reflecting the release notes that go with version 1.06 where there were a lot of changes to the throttle code.
https://github.com/damienmaguire/Stm32- ... /tag/1.06A
Like you I found potmin needs to be above the minimum potval.
The change between 1.11A and 2.00A occured here https://github.com/damienmaguire/Stm32- ... c4e8a7954a.
potpressed was changed from being based on potnom to potval > potmin.
