Yes the regen works very well, just request a negative torque value.
All the code needed for control has been posted.
Mitsubishi Outlander rear motor invertor
Re: Mitsubishi Outlander rear motor invertor
Hi
Just starting to power up the inverter, motor to go in a Grandin Dallas Jeep
can someone post a photo of the HV battery + and - screw terminals polarity ,please
Cheers
Cheers
FFMan
- Has thanked: 9 times
- Been thanked: 50 times
Hi
trying to get this to spin on 128v as a test. Is there a minimum as having no joy ?
What is the max voltage for the rear inverter also ?
Retired - (E46 touring, Phev rear motor, OEM inverter cabin heater and charger,BMW 9kwh & 12kwh packs)
[WIP] JImny & phev running gear
royhen99
- Has thanked: 22 times
- Been thanked: 134 times
Minimum 200V. Not sure of maximum, at least 395V possibly 420V.
LRBen
- Has thanked: 122 times
- Been thanked: 290 times
