Throttle Cable Adapter Best Practices?
- Has thanked: 6 times
Could anyone suggest the best approach for adapting the existing throttle cable to interface with open inverter?
Is there a known part that can be used for this purpose I could find in a wrecker? Or is there a good aftermarket kit anyone would reccomend?
Or is it better to try replace the entire pedal assembly with an ev drive by wire pedal, and if so why?
Thanks!
Thanks!
- Bratitude
- Has thanked: 168 times
- Been thanked: 350 times
Re: Throttle Cable Adapter Best Practices?
https://www.evwest.com/catalog/product_ ... cts_id=418
or a throttle body sensors off a intake manifold.
A drive by wire pedal is better because there is less moving parts—less chance of failure, and less mechanical play
- Has thanked: 85 times
- Been thanked: 4 times
There is a honda accelerator pedal sensor that works nicely with most older style cable setups, have used these in boats and cars with a e throttle conversion before, out of lots of different Hondas so cheap at the wreckers yards.
- Has thanked: 393 times
- Been thanked: 111 times
Any idea which ones to look out for? Also, what makes them work nicely?
in the early days of electronic diesel control, many cars were adapted to use e-throttle sensors from the standard cable throttle pedal, as the gasoline versions were still using cable throttle.
Being that Bosch ECU's powered a lot of these cars its not surprising to find a bosch sensor to do what you need. Ofcourse it makes sense to find one thats common in your region.
As a few examples,
BMW M51: https://www.ebay.co.uk/itm/285144412760
VW TDI https://www.ebay.co.uk/itm/285489162968
Audi TDI https://www.ebay.co.uk/itm/304830222734
These are all likely readily available in europe (although granted, becoming less common as these are from 90's cars)
As a few examples,
- crasbe
- Has thanked: 47 times
- Been thanked: 146 times
I replaced your eBay Links with the corresponding part numbers for future reference. eBay links are quite volatile after someone bought the part.Aragorn wrote: ↑Tue Sep 26, 2023 4:50 pm in the early days of electronic diesel control, many cars were adapted to use e-throttle sensors from the standard cable throttle pedal, as the gasoline versions were still using cable throttle.
As a few examples,
BMW M51: BMW Part Number: 224569, Bosch Part Number: 0 205 001 040
VW TDI: Bosch Part Number: 0 205 001 012
Audi TDI: VAG Part Number: 028907475AJ, Bosch Part Number: 0 281 002 286
Maybe someone wants to write a wiki article about those
- celeron55
- Has thanked: 38 times
- Been thanked: 136 times
In the Previa, I reused the original throttle body with its sensor. If you do so, make sure you can achieve your preferred level of redundancy in the signals.
The sensor in the Previa has the potentiometer output plus an idle switch, and I made it so that if the idle switch is active, throttle is heavily limited, so that if the potentiometer is reporting wrongly, the car doesn't become a total hazard.
Reusing the cable and throttle body is of course not an ideal solution in every way. Mine tends to stick a little in cold weather after not been driven for a couple of weeks. It's very good safety practice to wire up the brake signal to override throttle to zero.
- celeron55
One very cheap cable driven throttle sensor is 9643365680. It's used on French cars. I don't know the pinout, but it seems to be a 4 pin sensor so not too difficult to test and find out using a current limited power supply. I would be very surprised if it didn't provide simple analog signals when supplied 5V, like almost all of them do.
EDIT: This was tested now by Tomdb/tom91, with results:
4 - Gnd
3 - 5V
2 - Sig 2 requires pull up to 5V
1 - Sig 1 requires pull up to 5V
4 - Gnd
3 - 5V
Thanks all, this is interesting and something I had wondered about given my accelerator pedal is not a typical one and in a conversion it might be preferential to keep the existing cable setup and have a pot or similar control it.
I had read that hall sensors are much more reliable/less prone to incorrect readings, does anyone want to weigh in on this?
- rstevens81
- Has thanked: 29 times
Came across this tread by accident and was thinking of using an old throttle sensor instead of a prius pedal as its quite tight in the foot well.celeron55 wrote: ↑Tue Sep 26, 2023 7:00 pm One very cheap cable driven throttle sensor is 9643365680. It's used on French cars. I don't know the pinout, but it seems to be a 4 pin sensor so not too difficult to test and find out using a current limited power supply. I would be very surprised if it didn't provide simple analog signals when supplied 5V, like almost all of them do.
just brought one for £15 with the plug on it so when it arrives ill add it to wiki, makes my life (hopefully) easier to use one of these than 3d print some monstrosity to make a prius pedal fit
- Has thanked: 134 times
- Been thanked: 335 times
I feel your pain.rstevens81 wrote: ↑Wed Sep 27, 2023 8:01 am Came across this tread by accident and was thinking of using an old throttle sensor instead of a prius pedal as its quite tight in the foot well.
just brought one for £15 with the plug on it so when it arrives ill add it to wiki, makes my life (hopefully) easier to use one of these than 3d print some monstrosity to make a prius pedal fit![]()
I would recommend not to use any 3D printed fittings unless it is made by quality (expensive) printer and material.
Here you can see how i adapted AURIS pedal since it had a metal rod for lever. Prius pedal wouldnt fit as the steering column would require a bend in the lever. I could then cut the OEM pedal lever in halfh and used Auris pedal for the base with the lever from original.
https://leafdriveblog.wordpress.com/201 ... tle-pedal/
Does anyone have any info on these? I bought one but it's not giving anything out. I think it's because it needs a pull up resistor, any idea on what resistance?celeron55 wrote: ↑Tue Sep 26, 2023 7:00 pm One very cheap cable driven throttle sensor is 9643365680. It's used on French cars. I don't know the pinout, but it seems to be a 4 pin sensor so not too difficult to test and find out using a current limited power supply. I would be very surprised if it didn't provide simple analog signals when supplied 5V, like almost all of them do.
4 - Gnd
3 - 5V
- crasbe
The answer is the same as in the other thread. You need pullup resistors. Tom tested it and it didn't give out any signal without them.Jacobsmess wrote: ↑Mon Dec 04, 2023 9:59 am Does anyone have any info on these? I bought one but it's not giving anything out. I think it's because it needs a pull up resistor, any idea on what resistance?
The value of the Pullup resistors is the same as in the other thread as well, 1kOhm.
I looked for information on Tom's tests but they didn't seem to be on the forum or wiki from what I searched. Also felt it was worthwhile adding information to this thread for others that might be looking and requesting information from others that have used them but I'll source some resistors cheers.
- uhi22
- Has thanked: 204 times
- Been thanked: 609 times
It is quite difficult to find such information in the forums. To improve this, I just created a page in the wiki for this sensor:
https://openinverter.org/wiki/Peugeot_Throttle_Sensor Please feel free to add more information there, if you find something out, and add crosslinks to / from other pages which could be helpful.
- J0hannes
- Has thanked: 15 times
- Been thanked: 132 times
pedals and pedal position sensors have their own category in wiki
There's now some info on the Bosch PWG-3 and Honda 37971-xxx-xxx
