Inverter for lion battery
Topics concerning inverters for on or off grid use. DIY and OEM.
xvyDFatih
Post by xvyDFatih »
Do you have an inverter recommendation that converts the 250-400V voltage range to 220/230V 50Hz voltage range?
It will be used with Li-on battery pack
Has thanked: 369 times
Been thanked: 1544 times
Re: Inverter for lion battery
Moved to renewables.
You gotta be more verbose here. What power level for example? Which comms interface?
xvyDFatih
Post by xvyDFatih »
johu wrote: Tue Nov 28, 2023 11:00 am Moved to renewables.
ok.
Actually there is 48V input to 230Vac inverter for li-on battery. Im looking 250-400V input range.
Also generally inverters for solar panels. They are converting DC to AC. Im looking for li-on battery.
communication is not imported and not neccessary now. Just Im looking an inverter that converts the 250-400V voltage range to 220/230V 50Hz voltage range.
thanks for feednback.
Has thanked: 215 times
Been thanked: 174 times
Post by jrbe »
xvyDFatih wrote: Thu Nov 30, 2023 7:04 am ok.
...Im looking 250-400V input range.
..communication is not imported and not neccessary now.
..Just Im looking an inverter that converts the 250-400V voltage range to 220/230V 50Hz voltage range.
Will likely need some amperage / kw goals.
A rotary phase converter setup but with a repurposed ev motor on the input side could work well to get clean power out the other side. Likely much cheaper options but also likely not as simple.
