Gen2 IGBT Drivers board CNDR1 and CNDR2 pinouts [SOLVED]
- SuppaTenko
- Been thanked: 4 times
Good day everyone.
Right now I'm working on Leaf-related project - my friends are building custom electro-bike using Leaf powertrain. And I'm making inverter control board for them. We have good engine, 90%-probability-good driver board, battery assembly (now balancing) and toasted inverter logic board.
All parts are from crashed and burned car. Previous owner lost/burned all internal wires, so I need to be sure if I'm connecting Openinverter board just right.
So now I need CNDR1 and CNDR2 pinouts. I briefly searched through Gen1 and Gen3 threads, but wasn't able to find this info.
We're going a bit crazy here, so here's my version of OpenInverter hardware, homebrew etched. Some sections were changed - I used another PWM controller for resolver excitation, 3,5mm 'degsons' instead of proprietary connectors, different ESP8266 module etc. Overall it's based on mainboard v3.4 + leaf adapter. Seems to be working good right now, so we're ready to wire it up.
Thank you for any help in advance.
Cast in the name of God, ye not guilty.
- Been thanked: 1918 times
Re: Gen2 IGBT Drivers board CNDR1 and CNDR2 pinouts
That is so oldschool, nice
You can go back to the beginning, check the video description of this video it has some pinouts. Or just open leaf_adapter.fpc with a software called freepcb
- SuppaTenko
johu, thank you. But I asked about IGBT Drivers Board pinouts. Not about OpenInverter board.
As i said, I don't have stock cables. I can tell where all six PWM signals go, but I'm not sure about FAULT1, FAULT2, UDC_PWM, heatsink temp and both current sensors.
I'm talking about this board and sockets:
- SuppaTenko
Well... Should be something like this.
Please correct me if I'm wrong here.
- photo_3_2023-11-14_16-10-34.jpg (12.92 KiB) Viewed 48931 times
- photo_2_2023-11-14_16-10-34.jpg (16.42 KiB) Viewed 48931 times
- SuppaTenko
Ok, we're definitely alive here. At least WIFI web-interface yields legit errors and numbers. Overall it consumes like 500-600 mAmps from 12V psu. Gonna test with engine and HV supply on upcoming Monday-Tuesday... Wish me luck! =)
- SuppaTenko
Ok, we have an issue with both current sensors.
They show around ~2,45 volts on outputs with zero current - hapf supply voltage or so.
It's too much, should be between 1,23 and 2,06 vots. So we have permanent HICUROFS1/2 and OVERCURRENT stop.
Is it possible that our sensors are damaged?
Which sensors can be used as replacement?
Re: Gen2 IGBT Drivers board CNDR1 and CNDR2 pinouts [SOLVED]
That's the voltage they should sit at. You need to divide it down to the 3V3 window, e.g. with 3k3/6k8 voltage divider
- SuppaTenko
johu, thx, will check input dividers tomorrow.
A bit confusing. We have 3k3+4k7 on mainboardv3.4.pdf from git, only 3k3 for v2 board wiki (https://openinverter.org/wiki/images/a/ ... ain_v2.png), mainboard_mini has 3k3+6k8 as you suggested and as far as I can remember, mine is 3k3+10k which is not enough.
- SuppaTenko
Ok. First, some problems with current sensors were solved. Now it calibrates just fine. Also, there were some strange shenanigans with protection circuit comparator and input/output logic. Also solved. Second, I found cross-layer short-circuit on IGBT board and restored and replaced everything damaged by high temperatures.
So, we had persistent precharge error, several strange overcurrents without any currents and HV, no stable calibration, i changed current sensor dividers etc, etc... Now we have no errors at all, which is good.
Now we can't properly calibrate resolver. I rolled back to FOC 4.97R FW. Angle indicator jumps between 150 and 340 deg. It doesn't mater if you rotate motor or not. The resolver (and engine) was not damaged by fire, so it's not the cause. 1,65V bias presents. We have nice cin/cos signals. But sin/cos waveforms seem to have low swing just around 500 mV (AFAIK, it should be close to 0...3v3 range - correct me if I'm wrong), and excitation waveform is too fuzzy.
My guesses are:
- bad TDA2822 - will check it this evening
- my TPS55340 booster provides wrong supply voltage for TDA amplifier.
According to my computations, MIC2288 should provide 1,24*(3300/510+1) = 9,26 volts with 510+3k3 divider. So does my TPS55340 with 10k+64k9 divider.
Can you show me excitation waveform parameters? What swing should it have? What output voltage your MIC2288 booster provides? Am I wrong?
Sorry for bad photo quality - pretty hard to test and film everything in process. It's excitation waveform and sin/cos outputs. Also, the bike =)
Also, please 'un-solve' this topic. We still have ways to go in this struggle =)
My guesses are:
- SuppaTenko
It was TDA. Now we have some spin. Time to tinker with resolver offset.
UPD. Got some decent RPMs and almost found good syncofs. But half-baked IGBTs finally decided to die. RIP.
Will wait for new inverter now. While it's been delivered I will apply some fixes to my logic board, also rework wires etc. And try to play with CAN bus control and something zombieverter-like in process.
