We have the VCU up and running on the laptop, and power to the motor, 100v I think, but it doesn't turn over,
It seems the Firmware is only for Gen1, Where to find the updated firmware for Gen2 ZE1 motors?
Zombie Firmware for ZE1 e+
- Has thanked: 3 times
- Has thanked: 76 times
- Been thanked: 218 times
Re: Zombie Firmware for ZE1 e+
That gen1 module will run any gen leaf as far as I am aware. I have personally seen it running up to 2019 leaf inverters and motors no problem.
I think the issue you have is voltage, pretty sure the lead needs a few more volts to run via canbus.
ok, sorry for delay.
We have bumped it up to 210v, got the VCU to close the Negative contactor but not the Positive one for some reason. We can override it no problem, but then the motor still doesn't spin
- Has thanked: 206 times
- Been thanked: 563 times
