There have been various reports in this forum about Gen2Chargers not working with the replacement boards.
I just had two like that.
My solution:
The internal CAN bus must be terminated with a total of 60 ohms!
Since there is no termination on the three charger modules themselves,
there must be a termination of 60 ohms on the controller board.
As is the case with the original board!
Unfortunately I found on the schematic of all Gen2TeslaChargerV1 - 5 a termination of 120 ohms.
Or I had prunes on my eyes during the investigation?
Either way, many thanks to everyone who pushed the development of this board forward.
Solution for not working Gen2Chargers with replacement boards
- Has thanked: 234 times
- Been thanked: 267 times
Re: Solution for not working Gen2Chargers with replacement boards
CAN bus termination should measure 60 ohms, which is achieved via a 120 ohm resistor on each end of the bus. Since they're in parallel, that results in the 60 ohm total. Hence the board has one 120 ohm resistor.kendo wrote: ↑Mon Oct 30, 2023 4:38 pm There have been various reports in this forum about Gen2Chargers not working with the replacement boards.
My solution:
It sounds like, from what you've seen, perhaps there are some versions where the internal bus does not have its own 120 ohm resistor.
- Has thanked: 368 times
- Been thanked: 1538 times
Very short CAN buses mostly work with 1k termination or something.
Is this proven to be the culprit? I.e. 120 - doesn't work, 60 - does work?
