PCS coolant port measurements  [SOLVED]
Has thanked: 246 times
Been thanked: 469 times
can some any one provide some what the internal diameter of the coolant ports on the pcs are?
im working on some adapters and dont have a pcs near me
nkiernan
Has thanked: 518 times
Been thanked: 95 times
Re: PCS coolant port measurements
Post by nkiernan »
I have one on the bench at home so can grab some dims later this evening
P.S.Mangelsdorf
Has thanked: 323 times
Been thanked: 353 times
Re: PCS coolant port measurements  [SOLVED]
Post by P.S.Mangelsdorf »
I measured one I have in storage with a digital caliper.
Inside diameter is 22mm, but flares near the opening to 23.7mm
Outside diameter is 26.1mm, appears to be fairly straight, except for the bead, which is 30.4mm outside diameter.
