Prius Gen2 Boost Converter - how to use?  [SOLVED]
johnspark
Has thanked: 59 times
Been thanked: 48 times
Re: Prius Gen2 Boost Converter - how to use?
Post by johnspark »
ah well i did not realize that, I am only interested in 6000 rpm or less. What is the efficiency like with FOC?
If I don't need the battery voltage boosted it would be a lot simpler...
Pete9008
Has thanked: 102 times
Been thanked: 350 times
Post by Pete9008 »
johnspark wrote: Fri Feb 10, 2023 1:03 am ah well i did not realize that, I am only interested in 6000 rpm or less. What is the efficiency like with FOC?
This reply may also be relevant here viewtopic.php?p=52760#p52760
blackjmyntrn
Post by blackjmyntrn »
evMacGyver wrote: Thu Feb 09, 2023 5:43 pm Why would you like to boost battery voltage higher? I'm not familiar with Prius transaxle, but I'm pretty sure you don't need higher voltage even to reach top RPM from both MGs. For comparison GS450h will get 10000rpm at 250V.
Because you want to use other cells that make up a smaller battery pack and need to get the module you want to use above 207V.
black.jmyntrn.com | my Overlanding Prius Blog
Has thanked: 394 times
Been thanked: 111 times
Post by Jacobsmess »
Where have you seen the GS450H get to 10000rpm at 250V?
evMacGyver
Has thanked: 39 times
Been thanked: 10 times
Post by evMacGyver »
blackjmyntrn wrote: Tue Oct 10, 2023 11:09 pm Because you want to use other cells that make up a smaller battery pack and need to get the module you want to use above 207V.
Sure, I answered to johnspark plan "I would like to use the boost converter to top up my ~300V battery to 350 V" which is more likely not needed and would limits output power.
Jacobsmess wrote: Wed Oct 11, 2023 6:27 am Where have you seen the GS450H get to 10000rpm at 250V?
I should have tested max rpm when my battery was even below 200V at low SOC. I did not have problems on normal road speeds when MG2 is designed for efficiency and kept below 5000rpm at high gear. This 250V and 10krpm is rough estimate from GS450h BEMF voltage, not accurate value.
