Hello folks.
What is the acceptable tolerance on the pot input? I have a V6 board (fmw: 4.90.R-sine) with the bmw e45 throttle pedal. Below are my measurements of the fully released pedal on the multimeter (signal-to-ground) vs. on the web interface. When I fully press the pedal the value stays steady - 4095.
As you see the meter is pretty steady on the pedal released, but the values are jumpy on the web....Trying to figure out if it's a problem or not...
Multimeter:
Web interface:
Wiring: I use just vcc1, gnd1, sig1
Throttle parameters:
Tesla Small Drive Unit (SDU) pot tolerance
alexbeatle
- Has thanked: 82 times
- Been thanked: 35 times
- Been thanked: 1918 times
Re: Tesla Small Drive Unit (SDU) pot tolerance
Seems like 50 digits jitter - a bit too much for my taste as well. With the pedal disconnected do you still see the jitter? I wonder whether the onboard low pass filter has the wrong capacitor or resistor value
alexbeatle
I think this can be marked as "solved" for now.
I have the pedal connected to the SDU via a terminal block. I re-seated the wires of the pedal on the TB and this made the values more steady.
I also connected the ch2 of the pedal to the pot2 input, 'cause I was thinking that when unconnected it maybe inducing noise onto ch1, but it had no improvement effect. I turned of the coolant pump, which dropped the inverter temp from about 24C to 20C - no imprevement effect. I will leave it like this for now and will work with the dualchannel throttle.
Perhaps I should bypass the terminal blocks altogether and solder the wires together directly.
Thanks for helping.
New throttle params:
potmin's and potmax's are now taking into account broken wire or short wire.
potmin's = min value +10%, potmax's = max value - 10%. web interface live values: initially showing the pretty steady values when the throttle is released, then randomly pressing (and trying to hold in place) the throttle and finally throttle all the way down.
Thanks for helping.
