- andybpowell
- Has thanked: 210 times
- Been thanked: 244 times
There are enough people out there using these modules and lots of speculation on what they are capable of but little real world data so what sort of peak and continuous current are people drawing on them reliably and what cell voltage limits are you using and what temps are you seeing ?
I have 2kwh 8s bmw x5 modules 68ah
I'm running at
3.2v min
4.1 max
200A continuous
275 peak
with no reliability or temperature issues the highest temp I've seen was 32 deg c today and it's it's 30 deg outside anyway
mine are all fixed to 8mm ally plate
I'm running at
3.2v min
4.1 max
200A continuous
275 peak
- andybpowell
- Gregski
- Has thanked: 361 times
- Been thanked: 481 times
not sure if you follow my [DRIVING]1971 GMCe Lexus GS450H BMW 530e Tesla Model S powered Electruck [FINISHED] build thread but I started doing real road tests and have been reporting the results, I plan on just following the OEM specs
4.1v max is 393 volts some call this 90% charge
3.1v min is practical use that equates to 300 volts, after that the truck becomes a slug
2.8v min I think this is in theory only
RANGE: 34.9 miles
TOP SPEED: 88.9 MPH
- andybpowell
Yes I do follow, look forward to you getting some data on current draw especially as I'm considering ditching my leaf and going over to 450h or 300hGregski wrote: ↑Tue Sep 12, 2023 2:45 pm not sure if you follow my [DRIVING]1971 GMCe Lexus GS450H BMW 530e Tesla Model S powered Electruck [FINISHED] build thread but I started doing real road tests and have been reporting the results, I plan on just following the OEM specs
I can't get Damien's S-box code to display the current draw properly while I drive, still working on it
RANGE: 34.9 miles
TOP SPEED: 82.7 MPH
so I can have more room for batteries
Also thanks for the reply thought I'd Pis**D in someones beer for a while there with the underwealming response
- Gregski
word on the street is the 300h don't need no external oil pump so I would vote for that, I can't see where you hail from and I think the 300h is only available in Europe so not a choice for us United Statesiansandybpowell wrote: ↑Tue Sep 12, 2023 8:00 pm Yes I do follow, look forward to you getting some data on current draw especially as I'm considering ditching my leaf and going over to 450h or 300h
- andybpowell
yes the thing that makes me want to go 300h as opposed to the 450h is the weight and the oil pump but no one seems to have any info on the driveability of the 300h and I can't keep throwing money around
also updated my location
- bobby_come_lately
- Has thanked: 37 times
- Been thanked: 39 times
You might be waiting a while (until I have a garage again), but I have the 300h and inverter ready to go, along with all the other parts for another conversion. Like you though, be very happy for someone else to get there first and talk about their experience!andybpowell wrote: ↑Wed Sep 13, 2023 10:37 am yes the thing that makes me want to go 300h as opposed to the 450h is the weight and the oil pump but no one seems to have any info on the driveability of the 300h and I can't keep throwing money around
- andybpowell
too late already bought everythingbobby_come_lately wrote: ↑Tue Sep 19, 2023 1:35 pm You might be waiting a while (until I have a garage again), but I have the 300h and inverter ready to go, along with all the other parts for another conversion. Like you though, be very happy for someone else to get there first and talk about their experience!
- bobby_come_lately
Ha! You will be well ahead of me.
Having major BMS issues with these packs at the moment. Can get my old Teensy to talk to them but not the ESP32 Jamie and co have been working on. Will get there but frustrating.
- andybpowell
I have to say on paper I like the esp32 but I've had nothing but grief with them but that's probably just me being used to teensy and arduino thoughbobby_come_lately wrote: ↑Tue Sep 19, 2023 1:59 pm Ha! You will be well ahead of me.
- bobby_come_lately
Realise this is off topic but aargh, Teensy. So flippin' fragile!
- andybpowell
100% agree I've killed 2 teensy 4's and a 3.2bobby_come_lately wrote: ↑Thu Sep 21, 2023 11:59 am Realise this is off topic but aargh, Teensy. So flippin' fragile!
- andybpowell
A 3.2 for BMS I assume ? also known as hens teethbobby_come_lately wrote: ↑Thu Sep 21, 2023 11:59 am Realise this is off topic but aargh, Teensy. So flippin' fragile!
if you're desperate I can help you out
- Gregski
I take it this must be true for our EV Ambassador to use this type of harsh language !!!bobby_come_lately wrote: ↑Thu Sep 21, 2023 11:59 am Realise this is off topic but aargh, Teensy. So flippin' fragile!
- bobby_come_lately
Ha! I'm all about the ESP32s now. Cheap and (so far) reasonably robust. Even when you put 12V on the 3v3 line...
Back on batteries, I have probably killed one of my modules in my second pack. Not sure how, but some cells down at 1.49v. Can't remember if this is the pack I did an accidental range test on, or if these were the ones I bought after that. Will try a manual charge with a PSU like I did before and see if they recover.
- andybpowell
Yea but maybe don't charge it near the house if it's any consolation the race to get a Z3 back on the road is on again as mines a big pile of parts again (admittedly self inflicted)bobby_come_lately wrote: ↑Thu Sep 21, 2023 2:32 pm Ha! I'm all about the ESP32s now. Cheap and (so far) reasonably robust. Even when you put 12V on the 3v3 line...
- Has thanked: 8 times
- Been thanked: 47 times
just looking over previous posts.bobby_come_lately wrote: ↑Sat May 20, 2023 12:09 pm Not cooling them at all for driving. Might do if I add fast charging. But I've seen very little temperature change under load (Prius Gen 3 inverter into Outlander rear motor). Unless you're going to be sucking big current, I don't think it's something you need to worry about. Save the weight!
Same setup as above for me and same conclusion, no cooling or heating but then i only use the phev charger on them, and the discharge rate seems to be capped by the prius inverter at present.
I did install the first pack retaining the bmw coolant plates, but when installing the second pack i skipped that as i can't see i time i'd use them.
E46 touring
BMW 9kwh & 12kwh packs
I have just got round to sorting a BMS for my PHEV pack and now find that you cant buy SImpBMS or the Teensy it runs on! I have a Teensy 4.0 and ESP32s and all sorts of hardware, but not a Teensy 3.2. What are my options for BMS on this battery pack?
- Has thanked: 107 times
- Been thanked: 231 times
As per post in the Simp BMS thread viewtopic.php?p=61882#p61882
Another opensource project has been started using the SimpBMS code as a base https://github.com/bookofthefuture/BMWP ... P32-master
Ofcourse there is always the option of purchasing an EVS-BMS, my latest product. https://citini.com/product/evs-battery- ... nt-system/
- Has thanked: 264 times
- Been thanked: 71 times
Open inverter BMS is also available now, seems very good price but not sure how it works
- bobby_come_lately
Very generous to call this an open source project! More like an idiot hacking around with occasional help from those more talented.tom91 wrote: ↑Sat Sep 30, 2023 2:22 pm As per post in the Simp BMS thread viewtopic.php?p=61882#p61882
If you are not a glutton for frustration and pain, highly recommend Tom's product.
- bobby_come_lately
See above for context (idiot hacking around), and below for evidence.
I had an issue where on start-up the BMS was only recognising one module. When I went through the debug process it would then recognise all five.
I wondered if the issue was resistance on the canbus, since there only appeared to be the 120ohm resistor in my BMS on the loop. So tried disconnecting one end of the loop and adding a 120ohm resistor across CAN H/L.
I got nothing so I put it all back the way it was. Now I get nothing out of the modules.
If I stick Savvycan just on the output of the BMS without the modules connected, I can see it doing its thing (0x80 etc). But as soon as I plug a module in, no more messages.
So questions for anyone feeling so inclined:
- Has anyone else had the issue of modules not communicating at first?
- Could I have killed my modules like this?
- If so, does anyone have any cheap for sale - just the CSCs not the whole batteries
This pack is rather knackered anyway, so might be tempted to sell it off cheap and buy another one.
- bobby_come_lately
I had an issue on my test/second pack where on start-up the BMS was only recognising one module. When I went through the debug process it would then recognise all five.
If savvy can is on the bus with the modules and the BMS which ids are present? all modules broadcast a "status" regardless if they are being requested by the BMS.bobby_come_lately wrote: ↑Tue Nov 07, 2023 11:51 am If I stick Savvycan just on the output of the BMS without the modules connected, I can see it doing its thing (0x80 etc). But as soon as I plug a module in, no more messages.
There is a possibility you messed up you CAN wiring. lacking termination resistor could be an issue it does not have to be.
- bobby_come_lately
The modules are completely silent, so that's worrying.tom91 wrote: ↑Tue Nov 07, 2023 12:29 pm If savvy can is on the bus with the modules and the BMS which ids are present? all modules broadcast a "status" regardless if they are being requested by the BMS.
Possible I messed up the canbus wiring but it's the original BMW loom that was working before the experiment, so I'm not sure how. I've been through it all and tested for continuity and shorts.
Failure of the 5V supply or ground would be the obvious answer but fairly confident I've ruled that out. I'm going to check again though because that's the only thing that really makes sense to me.
