No TX and RX are dedicated serial port for the display.m.art.y wrote: ↑Mon Sep 18, 2023 11:40 am Hi, another question. Are the TX and RX signals for the Nextion display the same as the TX and RX in the usb socket? My intention is to use usb TX and RX for the serial monitor and also for the Nextion display. Would that work if I provide 5v and ground for the display? Thanks
Simp BMS
- Has thanked: 328 times
- Been thanked: 847 times
Re: Simp BMS
- JaniK
- Has thanked: 101 times
- Been thanked: 15 times
Re: Simp BMS
OK, I have a problem that I cannot solve;
I am using original old SimpBMS hardware, the software version is from 11.03.2023
https://github.com/Tom-evnut/VW-bms/com ... er/VWBMSV2
VW BMS V2
problem item: Module #8 (CAN module 4S+4Sdumb+2Sdumb total 10S)
I have 12S(module#6) and 10S(module#8) connected to SimpBMS. They have both worked fine standalone when tested before with old vw code supplied with the simpBMS years ago, but now the 10S shows up as 8S, but the problematic 2S module, that is not showing voltage, is transmitting the temperature via CAN bus.
Shown here with the 2S interconnect wire, temp shows when connected, the voltages are present on the CAN module circuit board too, but not showing on terminal for some reason. I tested other 10S module and other interconnect cable but still same behaviour.
could this be something changed in the code and the voltages for 2s modules are just ignored? the 4S modules work fine as you can see.
Module#6=4S BMS +4S +4S
Module#8=4S BMS +4S +2S
Are the missing 2S cell voltages possibly shown on the canbus debug capture below?
(Module #8 has total 10Cells connected, temp3 is from 2S module that shows no voltages.)
The 10S and 8S modules worked with old software that had different way of showing the "missing module voltage readings"
this 10S module is now showing also as 8S
Sorry long post but I tried to be precise.
VW BMS V2
BMS Status : 5 Error 20
Out:0000 Cont:0000 In:0000
Modules: 2 Cells: 20 Strings: 1 Voltage: 76.166V Avg Cell Voltage: 3.808V Low Cell Voltage: 3.803V High Cell Voltage: 3.812V Delta Voltage: 9mV Avg Temp: 10.333C
Module #6 45.70V Cell0: 3.81V Cell1: 3.81V Cell2: 3.81V Cell3: 3.81V Cell4: 3.81V Cell5: 3.81V Cell6: 3.81V Cell7: 3.81V Cell8: 3.81V Cell9: 3.81V Cell10: 3.81V Cell11: 3.81V Cell12: 0.00V
Temp 1: 11.00C Temp 2: 10.50C Temp 3: 10.50C | Bal Stat: 0
Module #8 30.46V Cell13: 3.81V Cell14: 3.81V Cell15: 3.81V Cell16: 3.81V Cell17: 3.81V Cell18: 3.81V Cell19: 3.81V Cell20: 3.80V Cell21: 0.00V Cell22: 0.00V Cell23: 0.00V Cell24: 0.00V Cell25: 0.00V
Temp 1: 10.00C Temp 2: 9.50C Temp 3: 10.50C | Bal Stat: 0
CANbus 0.00mA 66% SOC 73260.00mAh
!!! Series Cells Fault !!!
Debug Settings Menu
Toggle on/off
1 - Can Debug :1
2 - Current Debug :0
3 - Output Check :0
4 - Input Check :0
5 - ESS mode :0
6 - Cells Present Reset :20
7 - Gauge Debug :0
8 - CSV Output :0
9 - Decimal Places to Show :2
q - Go back to menu
488182,0x16A9543F,false,8, 0xF4, 0x0F, 0x24, 0x00, 0x00, 0x00, 0x00, 0x00
488259,0x16A9542F,false,8, 0xC3, 0x54, 0x15, 0x01, 0x33, 0x00, 0x00, 0x00
488401,0x1A555467,false,8, 0x83, 0x43, 0x48, 0x20, 0x20, 0xB7, 0x00, 0x00
488433,0x16A95441,false,8, 0xEC, 0x05, 0x24, 0x00, 0x00, 0x00, 0x00, 0x00
488469,0x16A95431,false,8, 0x2A, 0x53, 0x1D, 0x01, 0x31, 0x00, 0x00, 0x00
488505,0x18FED802,false,5, 0x0A, 0x21, 0x00, 0x00, 0x00
8 | Temp Found488572,0x1A555408,false,8, 0x6B, 0xC0, 0x00, 0x00, 0x69, 0x6B, 0xFB, 0xFB
6,0 | 488574,0x1C4,false,8, 0x21, 0x6D, 0xAF, 0xF7, 0x8A, 0xAF, 0xF8, 0x0A
6,1 | 488575,0x1C5,false,8, 0xE0, 0x7D, 0xAF, 0xF9, 0x6A, 0xAF, 0xF8, 0x0A
6,2 | 488576,0x1C6,false,8, 0x9A, 0xCD, 0xAF, 0xFC, 0xCA, 0xAF, 0xF9, 0x0A
488580,0x1CC,false,8, 0x00, 0xF1, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0x0F
488581,0x1CD,false,8, 0xEC, 0xF1, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0x0F
488582,0x1CE,false,8, 0x5A, 0xF1, 0xFF, 0xFF, 0xEF, 0xFF, 0xFE, 0x0F
488683,0x16A9543F,false,8, 0x71, 0x00, 0x24, 0x00, 0x00, 0x00, 0x00, 0x00
488761,0x16A9542F,false,8, 0xDE, 0x55, 0x15, 0x01, 0x33, 0x00, 0x00, 0x00
488816,0x18FED602,false,5, 0x0C, 0x21, 0x00, 0x00, 0x00
488934,0x16A95441,false,8, 0x9F, 0x06, 0x24, 0x00, 0x00, 0x00, 0x00, 0x00
488970,0x16A95431,false,8, 0xCC, 0x54, 0x1D, 0x01, 0x31, 0x00, 0x00, 0x00
489011,0x1A555465,false,8, 0x83, 0x43, 0x48, 0x20, 0x20, 0xB7, 0x00, 0x00
6,0 | 489075,0x1C4,false,8, 0xC1, 0x5E, 0xAF, 0xF7, 0x8A, 0xAF, 0xF8, 0x0A
6,1 | 489076,0x1C5,false,8, 0x97, 0x7E, 0xAF, 0xF9, 0x6A, 0xAF, 0xF8, 0x0A
6,2 | 489077,0x1C6,false,8, 0x5D, 0xCE, 0xAF, 0xFC, 0xCA, 0xAF, 0xF9, 0x0A
6 | Temp Found489162,0x1A555406,false,8, 0x6C, 0x00, 0x00, 0x00, 0x6B, 0x6B, 0xFB, 0xFB
489185,0x16A9543F,false,8, 0x94, 0x01, 0x24, 0x00, 0x00, 0x00, 0x00, 0x00
489262,0x16A9542F,false,8, 0x97, 0x56, 0x15, 0x01, 0x33, 0x00, 0x00, 0x00
489403,0x1A555467,false,8, 0x80, 0x35, 0x51, 0x45, 0x35, 0x97, 0x00, 0x00
489436,0x16A95441,false,8, 0xD3, 0x07, 0x24, 0x00, 0x00, 0x00, 0x00, 0x00
489472,0x16A95431,false,8, 0xE3, 0x55, 0x1D, 0x01, 0x31, 0x00, 0x00, 0x00
489507,0x18FED802,false,5, 0x0A, 0x21, 0x00, 0x00, 0x00
8 | Temp Found489574,0x1A555408,false,8, 0x6B, 0xC0, 0x00, 0x00, 0x69, 0x6B, 0xFB, 0xFB
6,0 | 489576,0x1C4,false,8, 0x6B, 0x5F, 0xAF, 0xF7, 0x8A, 0xAF, 0xF8, 0x0A
6,1 | 489577,0x1C5,false,8, 0x64, 0x7F, 0xAF, 0xF9, 0x6A, 0xAF, 0xF8, 0x0A
6,2 | 489578,0x1C6,false,8, 0x7D, 0xCF, 0xAF, 0xFD, 0xCA, 0xAF, 0xF9, 0x0A
489582,0x1CC,false,8, 0x46, 0xF2, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0x0F
489583,0x1CD,false,8, 0x0F, 0xF2, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0x0F
489584,0x1CE,false,8, 0x17, 0xF2, 0xFF, 0xFF, 0xEF, 0xFF, 0xFE, 0x0F
489686,0x16A9543F,false,8, 0x06, 0x02, 0x24, 0x00, 0x00, 0x00, 0x00, 0x00
489763,0x16A9542F,false,8, 0x72, 0x57, 0x15, 0x01, 0x33, 0x00, 0x00, 0x00
489818,0x18FED602,false,5, 0x0C, 0x21, 0x00, 0x00, 0x00
489937,0x16A95441,false,8, 0x30, 0x08, 0x24, 0x00, 0x00, 0x00, 0x00, 0x00
489973,0x16A95431,false,8, 0x1C, 0x56, 0x1D, 0x01, 0x31, 0x00, 0x00, 0x00
490013,0x1A555465,false,8, 0x80, 0x35, 0x51, 0x45, 0x35, 0x97, 0x00, 0x00
6,0 | 490077,0x1C4,false,8, 0xA5, 0x60, 0xAF, 0xF7, 0x8A, 0xAF, 0xF8, 0x0A
6,1 | 490078,0x1C5,false,8, 0x4E, 0x70, 0xAF, 0xF9, 0x6A, 0xAF, 0xF8, 0x0A
6,2 | 490079,0x1C6,false,8, 0x04, 0xC0, 0xAF, 0xFD, 0xCA, 0xAF, 0xF9, 0x0A
490083,0x1CC,false,8, 0xE8, 0xF3, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0x0F
490084,0x1CD,false,8, 0x27, 0xF3, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0x0F
490085,0x1CE,false,8, 0x9B, 0xF3, 0xFF, 0xFF, 0xEF, 0xFF, 0xFE, 0x0F
6 | Temp Found490164,0x1A555406,false,8, 0x6C, 0x00, 0x00, 0x00, 0x6B, 0x6B, 0xFB, 0xFB
490188,0x16A9543F,false,8, 0x6F, 0x03, 0x24, 0x00, 0x00, 0x00, 0x00, 0x00
490265,0x16A9542F,false,8, 0x36, 0x58, 0x15, 0x01, 0x33, 0x00, 0x00, 0x00
490405,0x1A555467,false,8, 0x81, 0x39, 0x39, 0x41, 0x48, 0x26, 0x00, 0x00
490439,0x16A95441,false,8, 0xF9, 0x09, 0x24, 0x00, 0x00, 0x00, 0x00, 0x00
490475,0x16A95431,false,8, 0x69, 0x57, 0x1D, 0x01, 0x31, 0x00, 0x00, 0x00
490509,0x18FED802,false,5, 0x0A, 0x21, 0x00, 0x00, 0x00
8 | Temp Found490576,0x1A555408,false,8, 0x6B, 0xC0, 0x00, 0x00, 0x69, 0x6B, 0xFB, 0xFB
6,0 | 490578,0x1C4,false,8, 0x97, 0x51, 0xAF, 0xF7, 0x8A, 0xAF, 0xF8, 0x0A
6,1 | 490579,0x1C5,false,8, 0x1E, 0x71, 0xAF, 0xF9, 0x6A, 0xAF, 0xF8, 0x0A
6,2 | 490580,0x1C6,false,8, 0xF3, 0xC1, 0xAF, 0xFD, 0xCA, 0xAF, 0xF9, 0x0A
490584,0x1CC,false,8, 0x18, 0xF4, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0x0F
490585,0x1CD,false,8, 0x75, 0xF4, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0x0F
490586,0x1CE,false,8, 0x7D, 0xF4, 0xFF, 0xFF, 0xEF, 0xFF, 0xFE, 0x0F
490689,0x16A9543F,false,8, 0xE2, 0x04, 0x24, 0x00, 0x00, 0x00, 0x00, 0x00
490766,0x16A9542F,false,8, 0x34, 0x59, 0x15, 0x01, 0x33, 0x00, 0x00, 0x00
490820,0x18FED602,false,5, 0x0C, 0x21, 0x00, 0x00, 0x00
490940,0x16A95441,false,8, 0x16, 0x0A, 0x24, 0x00, 0x00, 0x00, 0x00, 0x00
490976,0x16A95431,false,8, 0x3F, 0x58, 0x1D, 0x01, 0x31, 0x00, 0x00, 0x00
491015,0x1A555465,false,8, 0x81, 0x39, 0x39, 0x41, 0x48, 0x26, 0x00, 0x00
6,0 | 491079,0x1C4,false,8, 0xF2, 0x52, 0xAF, 0xF7, 0x8A, 0xAF, 0xF8, 0x0A
6,1 | 491080,0x1C5,false,8, 0x7A, 0x72, 0xAF, 0xF9, 0x6A, 0xAF, 0xF8, 0x0A
6,2 | 491081,0x1C6,false,8, 0xCB, 0xC2, 0xAF, 0xFD, 0xCA, 0xAF, 0xF9, 0x0A
491085,0x1CC,false,8, 0xE0, 0xF5, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0x0F
491086,0x1CD,false,8, 0x18, 0xF5, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0x0F
491087,0x1CE,false,8, 0x1F, 0xF5, 0xFF, 0xFF, 0xEF, 0xFF, 0xFE, 0x0F
6 | Temp Found491166,0x1A555406,false,8, 0x6C, 0x00, 0x00, 0x00, 0x6B, 0x6B, 0xFB, 0xFB
491191,0x16A9543F,false,8, 0xB2, 0x05, 0x24, 0x00, 0x00, 0x00, 0x00, 0x00
491268,0x16A9542F,false,8, 0xF0, 0x5A, 0x15, 0x01, 0x33, 0x00, 0x00, 0x00
491407,0x1A555467,false,8, 0x82, 0x30, 0x33, 0x32, 0x32, 0x76, 0x00, 0x00
491442,0x16A95441,false,8, 0x32, 0x0B, 0x24, 0x00, 0x00, 0x00, 0x00, 0x00
491478,0x16A95431,false,8, 0xA1, 0x59, 0x1D, 0x01, 0x31, 0x00, 0x00, 0x00
491511,0x18FED802,false,5, 0x0A, 0x21, 0x00, 0x00, 0x00
8 | Temp Found491578,0x1A555408,false,8, 0x6B, 0xC0, 0x00, 0x00, 0x69, 0x6B, 0xFB, 0xFB
6,0 | 491580,0x1C4,false,8, 0x56, 0x53, 0xAF, 0xF7, 0x8A, 0xAF, 0xF8, 0x0A
6,1 | 491581,0x1C5,false,8, 0x13, 0x73, 0xAF, 0xF9, 0x6A, 0xAF, 0xF8, 0x0A
6,2 | 491582,0x1C6,false,8, 0xA6, 0xC3, 0xAF, 0xFD, 0xCA, 0xAF, 0xF9, 0x0A
491586,0x1CC,false,8, 0xEF, 0xF6, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0x0F
491587,0x1CD,false,8, 0xE5, 0xF6, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0x0F
491588,0x1CE,false,8, 0x65, 0xF6, 0xFF, 0xFF, 0xEF, 0xFF, 0xFE, 0x0F
491692,0x16A9543F,false,8, 0x26, 0x06, 0x24, 0x00, 0x00, 0x00, 0x00, 0x00
491770,0x16A9542F,false,8, 0x74, 0x5B, 0x15, 0x01, 0x33, 0x00, 0x00, 0x00
491822,0x18FED602,false,5, 0x0C, 0x21, 0x00, 0x00, 0x00
491943,0x16A95441,false,8, 0xE6, 0x0C, 0x24, 0x00, 0x00, 0x00, 0x00, 0x00
491979,0x16A95431,false,8, 0x96, 0x5A, 0x1D, 0x01, 0x31, 0x00, 0x00, 0x00
492017,0x1A555465,false,8, 0x82, 0x30, 0x33, 0x32, 0x32, 0x76, 0x00, 0x00
492087,0x1CC,false,8, 0x4A, 0xF7, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0x0F
492088,0x1CD,false,8, 0xE6, 0xF7, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0x0F
492089,0x1CE,false,8, 0xE7, 0xF7, 0xFF, 0xFF, 0xEF, 0xFF, 0xFE, 0x0F
6 | Temp Found492168,0x1A555406,false,8, 0x6C, 0x00, 0x00, 0x00, 0x6B, 0x6B, 0xFB, 0xFB
492194,0x16A9543F,false,8, 0x8F, 0x07, 0x24, 0x00, 0x00, 0x00, 0x00, 0x00
492271,0x16A9542F,false,8, 0x76, 0x5C, 0x15, 0x01, 0x33, 0x00, 0x00, 0x00
492409,0x1A555467,false,8, 0x83, 0x43, 0x48, 0x20, 0x20, 0xB7, 0x00, 0x00
492445,0x16A95441,false,8, 0xB1, 0x0D, 0x24, 0x00, 0x00, 0x00, 0x00, 0x00
492481,0x16A95431,false,8, 0x8A, 0x5B, 0x1D, 0x01, 0x31, 0x00, 0x00, 0x00
492513,0x18FED802,false,5, 0x0A, 0x21, 0x00, 0x00, 0x00
8 | Temp Found492580,0x1A555408,false,8, 0x6B, 0xC0, 0x00, 0x00, 0x69, 0x6B, 0xFB, 0xFB
6,0 | 492582,0x1C4,false,8, 0x88, 0x54, 0xAF, 0xF7, 0x8A, 0xAF, 0xF8, 0x0A
6,1 | 492583,0x1C5,false,8, 0xD1, 0x74, 0xAF, 0xF9, 0x6A, 0xAF, 0xF8, 0x0A
6,2 | 492584,0x1C6,false,8, 0x16, 0xC4, 0xAF, 0xFC, 0xCA, 0xAF, 0xF9, 0x0A
492588,0x1CC,false,8, 0x11, 0xF8, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0x0F
492589,0x1CD,false,8, 0x08, 0xF8, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0x0F
492590,0x1CE,false,8, 0xFA, 0xF8, 0xFF, 0xFF, 0xEF, 0xFF, 0xFE, 0x0F
492695,0x16A9543F,false,8, 0xCB, 0x08, 0x24, 0x00, 0x00, 0x00, 0x00, 0x00
492772,0x16A9542F,false,8, 0x05, 0x5D, 0x15, 0x01, 0x33, 0x00, 0x00, 0x00
492825,0x18FED602,false,5, 0x0C, 0x21, 0x00, 0x00, 0x00
492946,0x16A95441,false,8, 0xBF, 0x0E, 0x24, 0x00, 0x00, 0x00, 0x00, 0x00
492982,0x16A95431,false,8, 0x5E, 0x5C, 0x1D, 0x01, 0x31, 0x00, 0x00, 0x00
493019,0x1A555465,false,8, 0x83, 0x43, 0x48, 0x20, 0x20, 0xB7, 0x00, 0x00
493089,0x1CC,false,8, 0x28, 0xF9, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0x0F
493090,0x1CD,false,8, 0x01, 0xF9, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0x0F
493091,0x1CE,false,8, 0xE0, 0xF9, 0xFF, 0xFF, 0xEF, 0xFF, 0xFE, 0x0F
6 | Temp Found493170,0x1A555406,false,8, 0x6C, 0x00, 0x00, 0x00, 0x6B, 0x6B, 0xFB, 0xFB
493197,0x16A9543F,false,8, 0x85, 0x09, 0x24, 0x00, 0x00, 0x00, 0x00, 0x00
493274,0x16A9542F,false,8, 0x77, 0x5E, 0x15, 0x01, 0x33, 0x00, 0x00, 0x00
493411,0x1A555467,false,8, 0x80, 0x35, 0x51, 0x45, 0x35, 0x97, 0x00, 0x00
493448,0x16A95441,false,8, 0xD2, 0x0F, 0x24, 0x00, 0x00, 0x00, 0x00, 0x00
493484,0x16A95431,false,8, 0xE2, 0x5D, 0x1D, 0x01, 0x31, 0x00, 0x00, 0x00
493514,0x18FED802,false,5, 0x0A, 0x21, 0x00, 0x00, 0x00
8 | Temp Found493582,0x1A555408,false,8, 0x6B, 0xC0, 0x00, 0x00, 0x69, 0x6B, 0xFB, 0xFB
6,0 | 493584,0x1C4,false,8, 0x5E, 0x55, 0xAF, 0xF7, 0x8A, 0xAF, 0xF8, 0x0A
6,1 | 493585,0x1C5,false,8, 0xDC, 0x75, 0xAF, 0xF9, 0x6A, 0xAF, 0xF8, 0x0A
6,2 | 493586,0x1C6,false,8, 0xE5, 0xC5, 0xAF, 0xFD, 0xCA, 0xAF, 0xF9, 0x0A
493590,0x1CC,false,8, 0x12, 0xFA, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0x0F
493591,0x1CD,false,8, 0x6A, 0xFA, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0x0F
493592,0x1CE,false,8, 0xED, 0xFA, 0xFF, 0xFF, 0xEF, 0xFF, 0xFE, 0x0F
493698,0x16A9543F,false,8, 0x63, 0x0A, 0x24, 0x00, 0x00, 0x00, 0x00, 0x00
493775,0x16A9542F,false,8, 0xA4, 0x5F, 0x15, 0x01, 0x33, 0x00, 0x00, 0x00
493826,0x18FED602,false,5, 0x0C, 0x21, 0x00, 0x00, 0x00
493949,0x16A95441,false,8, 0xE0, 0x00, 0x24, 0x00, 0x00, 0x00, 0x00, 0x00
493985,0x16A95431,false,8, 0x70, 0x5E, 0x1D, 0x01, 0x31, 0x00, 0x00, 0x00
494020,0x1A555465,false,8, 0x80, 0x35, 0x51, 0x45, 0x35, 0x97, 0x00, 0x00
494091,0x1CC,false,8, 0x74, 0xFB, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0x0F
494092,0x1CD,false,8, 0xFD, 0xFB, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0x0F
494093,0x1CE,false,8, 0x51, 0xFB, 0xFF, 0xFF, 0xEF, 0xFF, 0xFE, 0x0F
6 | Temp Found494172,0x1A555406,false,8, 0x6C, 0x00, 0x00, 0x00, 0x6B, 0x6B, 0xFB, 0xFB
494200,0x16A9543F,false,8, 0x52, 0x0B, 0x24, 0x00, 0x00, 0x00, 0x00, 0x00
494277,0x16A9542F,false,8, 0x0D, 0x50, 0x15, 0x01, 0x33, 0x00, 0x00, 0x00
494412,0x1A555467,false,8, 0x81, 0x39, 0x39, 0x41, 0x48, 0x26, 0x00, 0x00
494451,0x16A95441,false,8, 0xB5, 0x01, 0x24, 0x00, 0x00, 0x00, 0x00, 0x00
494487,0x16A95431,false,8, 0x3D, 0x5F, 0x1D, 0x01, 0x31, 0x00, 0x00, 0x00
494517,0x18FED802,false,5, 0x0A, 0x21, 0x00, 0x00, 0x00
8 | Temp Found494584,0x1A555408,false,8, 0x6B, 0xC0, 0x00, 0x00, 0x69, 0x6B, 0xFB, 0xFB
6,0 | 494586,0x1C4,false,8, 0x1C, 0x56, 0xAF, 0xF7, 0x8A, 0xAF, 0xF8, 0x0A
6,1 | 494587,0x1C5,false,8, 0xFB, 0x76, 0xAF, 0xF9, 0x6A, 0xAF, 0xF8, 0x0A
6,2 | 494588,0x1C6,false,8, 0x72, 0xC6, 0xAF, 0xFD, 0xCA, 0xAF, 0xF9, 0x0A
494701,0x16A9543F,false,8, 0xD6, 0x0C, 0x24, 0x00, 0x00, 0x00, 0x00, 0x00
494778,0x16A9542F,false,8, 0xEE, 0x51, 0x15, 0x01, 0x33, 0x00, 0x00, 0x00
494828,0x18FED602,false,5, 0x0C, 0x21, 0x00, 0x00, 0x00
494952,0x16A95441,false,8, 0x55, 0x02, 0x24, 0x00, 0x00, 0x00, 0x00, 0x00
494988,0x16A95431,false,8, 0x3A, 0x50, 0x1D, 0x01, 0x31, 0x00, 0x00, 0x00
495022,0x1A555465,false,8, 0x81, 0x39, 0x39, 0x41, 0x48, 0x26, 0x00, 0x00
495093,0x1CC,false,8, 0x8B, 0xFC, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0x0F
495094,0x1CD,false,8, 0x09, 0xFC, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0x0F
495095,0x1CE,false,8, 0x81, 0xFC, 0xFF, 0xFF, 0xEF, 0xFF, 0xFE, 0x0F
6 | Temp Found495174,0x1A555406,false,8, 0x6C, 0x00, 0x00, 0x00, 0x6B, 0x6B, 0xFB, 0xFB
495203,0x16A9543F,false,8, 0x27, 0x0D, 0x24, 0x00, 0x00, 0x00, 0x00, 0x00
495280,0x16A9542F,false,8, 0x6D, 0x52, 0x15, 0x01, 0x33, 0x00, 0x00, 0x00
495415,0x1A555467,false,8, 0x82, 0x30, 0x33, 0x32, 0x32, 0x76, 0x00, 0x00
495454,0x16A95441,false,8, 0x98, 0x03, 0x24, 0x00, 0x00, 0x00, 0x00, 0x00
495490,0x16A95431,false,8, 0x56, 0x51, 0x1D, 0x01, 0x31, 0x00, 0x00, 0x00
495519,0x18FED802,false,5, 0x0A, 0x21, 0x00, 0x00, 0x00
8 | Temp Found495586,0x1A555408,false,8, 0x6B, 0xC0, 0x00, 0x00, 0x69, 0x6B, 0xFB, 0xFB
6,0 | 495588,0x1C4,false,8, 0xA3, 0x57, 0xAF, 0xF7, 0x8A, 0xAF, 0xF8, 0x0A
6,1 | 495589,0x1C5,false,8, 0x80, 0x77, 0xAF, 0xF9, 0x6A, 0xAF, 0xF8, 0x0A
6,2 | 495590,0x1C6,false,8, 0x74, 0xC7, 0xAF, 0xFD, 0xCA, 0xAF, 0xF9, 0x0A
495594,0x1CC,false,8, 0xAE, 0xFD, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0x0F
495595,0x1CD,false,8, 0x2D, 0xFD, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0x0F
495596,0x1CE,false,8, 0xFD, 0xFD, 0xFF, 0xFF, 0xEF, 0xFF, 0xFE, 0x0F
495704,0x16A9543F,false,8, 0xD7, 0x0E, 0x24, 0x00, 0x00, 0x00, 0x00, 0x00
495781,0x16A9542F,false,8, 0x57, 0x53, 0x15, 0x01, 0x33, 0x00, 0x00, 0x00
495830,0x18FED602,false,5, 0x0C, 0x21, 0x00, 0x00, 0x00
495955,0x16A95441,false,8, 0x51, 0x04, 0x24, 0x00, 0x00, 0x00, 0x00, 0x00
495991,0x16A95431,false,8, 0xF5, 0x52, 0x1D, 0x01, 0x31, 0x00, 0x00, 0x00
496024,0x1A555465,false,8, 0x82, 0x30, 0x33, 0x32, 0x32, 0x76, 0x00, 0x00
496095,0x1CC,false,8, 0xA7, 0xFE, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0x0F
496096,0x1CD,false,8, 0x44, 0xFE, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0x0F
496097,0x1CE,false,8, 0x22, 0xFE, 0xFF, 0xFF, 0xEF, 0xFF, 0xFE, 0x0F
6 | Temp Found496176,0x1A555406,false,8, 0x6C, 0x00, 0x00, 0x00, 0x6B, 0x6B, 0xFB, 0xFB
496206,0x16A9543F,false,8, 0xF4, 0x0F, 0x24, 0x00, 0x00, 0x00, 0x00, 0x00
496283,0x16A9542F,false,8, 0xC3, 0x54, 0x15, 0x01, 0x33, 0x00, 0x00, 0x00
496417,0x1A555467,false,8, 0x83, 0x43, 0x48, 0x20, 0x20, 0xB7, 0x00, 0x00
496456,0x16A95441,false,8, 0xEC, 0x05, 0x24, 0x00, 0x00, 0x00, 0x00, 0x00
496492,0x16A95431,false,8, 0x2A, 0x53, 0x1D, 0x01, 0x31, 0x00, 0x00, 0x00
496521,0x18FED802,false,5, 0x0A, 0x21, 0x00, 0x00, 0x00
8 | Temp Found496588,0x1A555408,false,8, 0x6B, 0xC0, 0x00, 0x00, 0x69, 0x6B, 0xFB, 0xFB
6,0 | 496590,0x1C4,false,8, 0x36, 0x58, 0xAF, 0xF7, 0x8A, 0xAF, 0xF8, 0x0A
6,1 | 496591,0x1C5,false,8, 0xA7, 0x78, 0xAF, 0xF9, 0x6A, 0xAF, 0xF8, 0x0A
6,2 | 496592,0x1C6,false,8, 0xA8, 0xC8, 0xAF, 0xFD, 0xCA, 0xAF, 0xF9, 0x0A
496596,0x1CC,false,8, 0x3F, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0x0F
496597,0x1CD,false,8, 0x23, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0x0F
496598,0x1CE,false,8, 0xC0, 0xFF, 0xFF, 0xFF, 0xEF, 0xFF, 0xFE, 0x0F
496707,0x16A9543F,false,8, 0x71, 0x00, 0x24, 0x00, 0x00, 0x00, 0x00, 0x00
496784,0x16A9542F,false,8, 0xDE, 0x55, 0x15, 0x01, 0x33, 0x00, 0x00, 0x00
496832,0x18FED602,false,5, 0x0C, 0x21, 0x00, 0x00, 0x00
496958,0x16A95441,false,8, 0x9F, 0x06, 0x24, 0x00, 0x00, 0x00, 0x00, 0x00
496994,0x16A95431,false,8, 0xCC, 0x54, 0x1D, 0x01, 0x31, 0x00, 0x00, 0x00
497026,0x1A555465,false,8, 0x83, 0x43, 0x48, 0x20, 0x20, 0xB7, 0x00, 0x00
497097,0x1CC,false,8, 0x0A, 0xF0, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0x0F
497098,0x1CD,false,8, 0xFC, 0xF0, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0x0F
497099,0x1CE,false,8, 0x45, 0xF0, 0xFF, 0xFF, 0xEF, 0xFF, 0xFE, 0x0F
6 | Temp Found497178,0x1A555406,false,8, 0x6C, 0x00, 0x00, 0x00, 0x6B, 0x6B, 0xFB, 0xFB
497209,0x16A9543F,false,8, 0x94, 0x01, 0x24, 0x00, 0x00, 0x00, 0x00, 0x00
497286,0x16A9542F,false,8, 0x97, 0x56, 0x15, 0x01, 0x33, 0x00, 0x00, 0x00
497418,0x1A555467,false,8, 0x80, 0x35, 0x51, 0x45, 0x35, 0x97, 0x00, 0x00
497459,0x16A95441,false,8, 0xD3, 0x07, 0x24, 0x00, 0x00, 0x00, 0x00, 0x00
497496,0x16A95431,false,8, 0xE3, 0x55, 0x1D, 0x01, 0x31, 0x00, 0x00, 0x00
497523,0x18FED802,false,5, 0x0A, 0x21, 0x00, 0x00, 0x00
8 | Temp Found497590,0x1A555408,false,8, 0x6B, 0xC0, 0x00, 0x00, 0x69, 0x6B, 0xFB, 0xFB
6,0 | 497592,0x1C4,false,8, 0x51, 0x69, 0xAF, 0xF7, 0x8A, 0xAF, 0xF8, 0x0A
6,1 | 497593,0x1C5,false,8, 0x55, 0x79, 0xAF, 0xF9, 0x6A, 0xAF, 0xF8, 0x0A
6,2 | 497594,0x1C6,false,8, 0x0F, 0xC9, 0xAF, 0xFD, 0xCA, 0xAF, 0xFA, 0x0A
497710,0x16A9543F,false,8, 0x06, 0x02, 0x24, 0x00, 0x00, 0x00, 0x00, 0x00
497787,0x16A9542F,false,8, 0x72, 0x57, 0x15, 0x01, 0x33, 0x00, 0x00, 0x00
497834,0x18FED602,false,5, 0x0C, 0x21, 0x00, 0x00, 0x00
497961,0x16A95441,false,8, 0x30, 0x08, 0x24, 0x00, 0x00, 0x00, 0x00, 0x00
497997,0x16A95431,false,8, 0x1C, 0x56, 0x1D, 0x01, 0x31, 0x00, 0x00, 0x00
498028,0x1A555465,false,8, 0x80, 0x35, 0x51, 0x45, 0x35, 0x97, 0x00, 0x00
498099,0x1CC,false,8, 0x00, 0xF1, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0x0F
498100,0x1CD,false,8, 0xEC, 0xF1, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0x0F
498101,0x1CE,false,8, 0x5A, 0xF1, 0xFF, 0xFF, 0xEF, 0xFF, 0xFE, 0x0F
6 | Temp Found498179,0x1A555406,false,8, 0x6C, 0x00, 0x00, 0x00, 0x6B, 0x6B, 0xFB, 0xFB
498212,0x16A9543F,false,8, 0x6F, 0x03, 0x24, 0x00, 0x00, 0x00, 0x00, 0x00
498289,0x16A9542F,false,8, 0x36, 0x58, 0x15, 0x01, 0x33, 0x00, 0x00, 0x00
498420,0x1A555467,false,8, 0x81, 0x39, 0x39, 0x41, 0x48, 0x26, 0x00, 0x00
498462,0x16A95441,false,8, 0xF9, 0x09, 0x24, 0x00, 0x00, 0x00, 0x00, 0x00
498498,0x16A95431,false,8, 0x69, 0x57, 0x1D, 0x01, 0x31, 0x00, 0x00, 0x00
498524,0x18FED802,false,5, 0x0A, 0x21, 0x00, 0x00, 0x00
8 | Temp Found498592,0x1A555408,false,8, 0x6B, 0xC0, 0x00, 0x00, 0x6A, 0x6B, 0xFB, 0xFB
6,0 | 498594,0x1C4,false,8, 0x74, 0x5A, 0xAF, 0xF7, 0x8A, 0xAF, 0xF8, 0x0A
6,1 | 498595,0x1C5,false,8, 0x09, 0x7A, 0xAF, 0xF9, 0x6A, 0xAF, 0xF8, 0x0A
6,2 | 498596,0x1C6,false,8, 0x2A, 0xCA, 0xAF, 0xFD, 0xCA, 0xAF, 0xF9, 0x0A
498713,0x16A9543F,false,8, 0xE2, 0x04, 0x24, 0x00, 0x00, 0x00, 0x00, 0x00
498790,0x16A9542F,false,8, 0x34, 0x59, 0x15, 0x01, 0x33, 0x00, 0x00, 0x00
498836,0x18FED602,false,5, 0x0C, 0x21, 0x00, 0x00, 0x00
498964,0x16A95441,false,8, 0x16, 0x0A, 0x24, 0x00, 0x00, 0x00, 0x00, 0x00
499000,0x16A95431,false,8, 0x3F, 0x58, 0x1D, 0x01, 0x31, 0x00, 0x00, 0x00
499031,0x1A555465,false,8, 0x81, 0x39, 0x39, 0x41, 0x48, 0x26, 0x00, 0x00
499101,0x1CC,false,8, 0x46, 0xF2, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0x0F
499102,0x1CD,false,8, 0x0F, 0xF2, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0x0F
499103,0x1CE,false,8, 0x17, 0xF2, 0xFF, 0xFF, 0xEF, 0xFF, 0xFE, 0x0F
6 | Temp Found499182,0x1A555406,false,8, 0x6C, 0x00, 0x00, 0x00, 0x6B, 0x6B, 0xFB, 0xFB
499215,0x16A9543F,false,8, 0xB2, 0x05, 0x24, 0x00, 0x00, 0x00, 0x00, 0x00
499292,0x16A9542F,false,8, 0xF0, 0x5A, 0x15, 0x01, 0x33, 0x00, 0x00, 0x00
499422,0x1A555467,false,8, 0x82, 0x30, 0x33, 0x32, 0x32, 0x76, 0x00, 0x00
499465,0x16A95441,false,8, 0x32, 0x0B, 0x24, 0x00, 0x00, 0x00, 0x00, 0x00
499501,0x16A95431,false,8, 0xA1, 0x59, 0x1D, 0x01, 0x31, 0x00, 0x00, 0x00
499526,0x18FED802,false,5, 0x0A, 0x21, 0x00, 0x00, 0x00
8 | Temp Found499594,0x1A555408,false,8, 0x6B, 0xC0, 0x00, 0x00, 0x69, 0x6B, 0xFB, 0xFB
6,0 | 499596,0x1C4,false,8, 0xB6, 0x5B, 0xAF, 0xF7, 0x8A, 0xAF, 0xF8, 0x0A
6,1 | 499597,0x1C5,false,8, 0xC7, 0x7B, 0xAF, 0xF9, 0x6A, 0xAF, 0xF8, 0x0A
6,2 | 499598,0x1C6,false,8, 0x7B, 0xCB, 0xAF, 0xFD, 0xCA, 0xAF, 0xF9, 0x0A
499716,0x16A9543F,false,8, 0x26, 0x06, 0x24, 0x00, 0x00, 0x00, 0x00, 0x00
499793,0x16A9542F,false,8, 0x74, 0x5B, 0x15, 0x01, 0x33, 0x00, 0x00, 0x00
499838,0x18FED602,false,5, 0x0C, 0x21, 0x00, 0x00, 0x00
499967,0x16A95441,false,8, 0xE6, 0x0C, 0x24, 0x00, 0x00, 0x00, 0x00, 0x00
500003,0x16A95431,false,8, 0x96, 0x5A, 0x1D, 0x01, 0x31, 0x00, 0x00, 0x00
500032,0x1A555465,false,8, 0x82, 0x30, 0x33, 0x32, 0x32, 0x76, 0x00, 0x00
500103,0x1CC,false,8, 0xE8, 0xF3, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0x0F
500104,0x1CD,false,8, 0x27, 0xF3, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0x0F
500105,0x1CE,false,8, 0x9B, 0xF3, 0xFF, 0xFF, 0xEF, 0xFF, 0xFE, 0x0F
6 | Temp Found500184,0x1A555406,false,8, 0x6C, 0x00, 0x00, 0x00, 0x6B, 0x6B, 0xFB, 0xFB
500218,0x16A9543F,false,8, 0x8F, 0x07, 0x24, 0x00, 0x00, 0x00, 0x00, 0x00
500295,0x16A9542F,false,8, 0x76, 0x5C, 0x15, 0x01, 0x33, 0x00, 0x00, 0x00
500424,0x1A555467,false,8, 0x83, 0x43, 0x48, 0x20, 0x20, 0xB7, 0x00, 0x00
500468,0x16A95441,false,8, 0xB1, 0x0D, 0x24, 0x00, 0x00, 0x00, 0x00, 0x00
500504,0x16A95431,false,8, 0x8A, 0x5B, 0x1D, 0x01, 0x31, 0x00, 0x00, 0x00
500528,0x18FED802,false,5, 0x0A, 0x21, 0x00, 0x00, 0x00
8 | Temp Found500596,0x1A555408,false,8, 0x6B, 0xC0, 0x00, 0x00, 0x69, 0x6B, 0xFB, 0xFB
6,0 | 500598,0x1C4,false,8, 0xF6, 0x5C, 0xAF, 0xF7, 0x8A, 0xAF, 0xF8, 0x0A
6,1 | 500599,0x1C5,false,8, 0xFE, 0x7C, 0xAF, 0xF9, 0x6A, 0xAF, 0xF8, 0x0A
6,2 | 500600,0x1C6,false,8, 0xFB, 0xCC, 0xAF, 0xFD, 0xCA, 0xAF, 0xF9, 0x0A
500719,0x16A9543F,false,8, 0xCB, 0x08, 0x24, 0x00, 0x00, 0x00, 0x00, 0x00
500796,0x16A9542F,false,8, 0x05, 0x5D, 0x15, 0x01, 0x33, 0x00, 0x00, 0x00
500840,0x18FED602,false,5, 0x0C, 0x21, 0x00, 0x00, 0x00
500970,0x16A95441,false,8, 0xBF, 0x0E, 0x24, 0x00, 0x00, 0x00, 0x00, 0x00
501006,0x16A95431,false,8, 0x5E, 0x5C, 0x1D, 0x01, 0x31, 0x00, 0x00, 0x00
501034,0x1A555465,false,8, 0x83, 0x43, 0x48, 0x20, 0x20, 0xB7, 0x00, 0x00
501105,0x1CC,false,8, 0x18, 0xF4, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0x0F
501106,0x1CD,false,8, 0x75, 0xF4, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0x0F
501107,0x1CE,false,8, 0x7D, 0xF4, 0xFF, 0xFF, 0xEF, 0xFF, 0xFE, 0x0F
6 | Temp Found501186,0x1A555406,false,8, 0x6C, 0x00, 0x00, 0x00, 0x6B, 0x6B, 0xFB, 0xFB
501221,0x16A9543F,false,8, 0x85, 0x09, 0x24, 0x00, 0x00, 0x00, 0x00, 0x00
501298,0x16A9542F,false,8, 0x77, 0x5E, 0x15, 0x01, 0x33, 0x00, 0x00, 0x00
501426,0x1A555467,false,8, 0x80, 0x35, 0x51, 0x45, 0x35, 0x97, 0x00, 0x00
501471,0x16A95441,false,8, 0xD2, 0x0F, 0x24, 0x00, 0x00, 0x00, 0x00, 0x00
501507,0x16A95431,false,8, 0xE2, 0x5D, 0x1D, 0x01, 0x31, 0x00, 0x00, 0x00
501530,0x18FED802,false,5, 0x0A, 0x21, 0x00, 0x00, 0x00
8 | Temp Found501598,0x1A555408,false,8, 0x6B, 0xC0, 0x00, 0x00, 0x69, 0x6B, 0xFB, 0xFB
6,0 | 501600,0x1C4,false,8, 0xE8, 0x5D, 0xAF, 0xF7, 0x8A, 0xAF, 0xF8, 0x0A
6,1 | 501601,0x1C5,false,8, 0xE0, 0x7D, 0xAF, 0xF9, 0x6A, 0xAF, 0xF8, 0x0A
6,2 | 501602,0x1C6,false,8, 0x9A, 0xCD, 0xAF, 0xFC, 0xCA, 0xAF, 0xF9, 0x0A
501722,0x16A9543F,false,8, 0x63, 0x0A, 0x24, 0x00, 0x00, 0x00, 0x00, 0x00
501799,0x16A9542F,false,8, 0xA4, 0x5F, 0x15, 0x01, 0x33, 0x00, 0x00, 0x00
501842,0x18FED602,false,5, 0x0C, 0x21, 0x00, 0x00, 0x00
501973,0x16A95441,false,8, 0xE0, 0x00, 0x24, 0x00, 0x00, 0x00, 0x00, 0x00
502009,0x16A95431,false,8, 0x70, 0x5E, 0x1D, 0x01, 0x31, 0x00, 0x00, 0x00
502036,0x1A555465,false,8, 0x80, 0x35, 0x51, 0x45, 0x35, 0x97, 0x00, 0x00
502107,0x1CC,false,8, 0xE0, 0xF5, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0x0F
502108,0x1CD,false,8, 0x18, 0xF5, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0x0F
502109,0x1CE,false,8, 0x1F, 0xF5, 0xFF, 0xFF, 0xEF, 0xFF, 0xFE, 0x0F
6 | Temp Found502188,0x1A555406,false,8, 0x6C, 0x00, 0x00, 0x00, 0x6B, 0x6B, 0xFB, 0xFB
502224,0x16A9543F,false,8, 0x52, 0x0B, 0x24, 0x00, 0x00, 0x00, 0x00, 0x00
502301,0x16A9542F,false,8, 0x0D, 0x50, 0x15, 0x01, 0x33, 0x00, 0x00, 0x00
502428,0x1A555467,false,8, 0x81, 0x39, 0x39, 0x41, 0x48, 0x26, 0x00, 0x00
502474,0x16A95441,false,8, 0xB5, 0x01, 0x24, 0x00, 0x00, 0x00, 0x00, 0x00
502510,0x16A95431,false,8, 0x3D, 0x5F, 0x1D, 0x01, 0x31, 0x00, 0x00, 0x00
502533,0x18FED802,false,5, 0x0A, 0x21, 0x00, 0x00, 0x00
8 | Temp Found502600,0x1A555408,false,8, 0x6B, 0xC0, 0x00, 0x00, 0x69, 0x6B, 0xFB, 0xFB
6,0 | 502602,0x1C4,false,8, 0x08, 0x6E, 0xAF, 0xF7, 0x8A, 0xAF, 0xF8, 0x0A
6,1 | 502603,0x1C5,false,8, 0x97, 0x7E, 0xAF, 0xF9, 0x6A, 0xAF, 0xF8, 0x0A
6,2 | 502604,0x1C6,false,8, 0x5D, 0xCE, 0xAF, 0xFC, 0xCA, 0xAF, 0xF9, 0x0A
502725,0x16A9543F,false,8, 0xD6, 0x0C, 0x24, 0x00, 0x00, 0x00, 0x00, 0x00
502802,0x16A9542F,false,8, 0xEE, 0x51, 0x15, 0x01, 0x33, 0x00, 0x00, 0x00
502844,0x18FED602,false,5, 0x0C, 0x21, 0x00, 0x00, 0x00
502976,0x16A95441,false,8, 0x55, 0x02, 0x24, 0x00, 0x00, 0x00, 0x00, 0x00
503012,0x16A95431,false,8, 0x3A, 0x50, 0x1D, 0x01, 0x31, 0x00, 0x00, 0x00
503038,0x1A555465,false,8, 0x81, 0x39, 0x39, 0x41, 0x48, 0x26, 0x00, 0x00
6,0 | 503103,0x1C4,false,8, 0x6B, 0x5F, 0xAF, 0xF7, 0x8A, 0xAF, 0xF8, 0x0A
6,1 | 503104,0x1C5,false,8, 0x64, 0x7F, 0xAF, 0xF9, 0x6A, 0xAF, 0xF8, 0x0A
6,2 | 503105,0x1C6,false,8, 0x7D, 0xCF, 0xAF, 0xFD, 0xCA, 0xAF, 0xF9, 0x0A
503109,0x1CC,false,8, 0xEF, 0xF6, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0x0F
503110,0x1CD,false,8, 0xE5, 0xF6, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0x0F
503111,0x1CE,false,8, 0x65, 0xF6, 0xFF, 0xFF, 0xEF, 0xFF, 0xFE, 0x0F
6 | Temp Found503189,0x1A555406,false,8, 0x6C, 0x00, 0x00, 0x00, 0x6B, 0x6B, 0xFB, 0xFB
503226,0x16A9543F,false,8, 0x27, 0x0D, 0x24, 0x00, 0x00, 0x00, 0x00, 0x00
503304,0x16A9542F,false,8, 0x6D, 0x52, 0x15, 0x01, 0x33, 0x00, 0x00, 0x00
503430,0x1A555467,false,8, 0x82, 0x30, 0x33, 0x32, 0x32, 0x76, 0x00, 0x00
503477,0x16A95441,false,8, 0x98, 0x03, 0x24, 0x00, 0x00, 0x00, 0x00, 0x00
503513,0x16A95431,false,8, 0x56, 0x51, 0x1D, 0x01, 0x31, 0x00, 0x00, 0x00
503534,0x18FED802,false,5, 0x0A, 0x21, 0x00, 0x00, 0x00
8 | Temp Found503602,0x1A555408,false,8, 0x6B, 0xC0, 0x00, 0x00, 0x69, 0x6B, 0xFB, 0xFB
6,0 | 503604,0x1C4,false,8, 0x6C, 0x50, 0xAF, 0xF7, 0x8A, 0xAF, 0xF8, 0x0A
6,1 | 503605,0x1C5,false,8, 0x4E, 0x70, 0xAF, 0xF9, 0x6A, 0xAF, 0xF8, 0x0A
6,2 | 503606,0x1C6,false,8, 0x04, 0xC0, 0xAF, 0xFD, 0xCA, 0xAF, 0xF9, 0x0A
503610,0x1CC,false,8, 0x4A, 0xF7, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0x0F
503611,0x1CD,false,8, 0xE6, 0xF7, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0x0F
503612,0x1CE,false,8, 0xE7, 0xF7, 0xFF, 0xFF, 0xEF, 0xFF, 0xFE, 0x0F
503728,0x16A9543F,false,8, 0xD7, 0x0E, 0x24, 0x00, 0x00, 0x00, 0x00, 0x00
503805,0x16A9542F,false,8, 0x57, 0x53, 0x15, 0x01, 0x33, 0x00, 0x00, 0x00
503846,0x18FED602,false,5, 0x0C, 0x21, 0x00, 0x00, 0x00
503979,0x16A95441,false,8, 0x51, 0x04, 0x24, 0x00, 0x00, 0x00, 0x00, 0x00
504015,0x16A95431,false,8, 0xF5, 0x52, 0x1D, 0x01, 0x31, 0x00, 0x00, 0x00
504040,0x1A555465,false,8, 0x82, 0x30, 0x33, 0x32, 0x32, 0x76, 0x00, 0x00
6,0 | 504106,0x1C4,false,8, 0x5E, 0x61, 0xAF, 0xF7, 0x8A, 0xAF, 0xF8, 0x0A
6,1 | 504106,0x1C5,false,8, 0x1E, 0x71, 0xAF, 0xF9, 0x6A, 0xAF, 0xF8, 0x0A
6,2 | 504107,0x1C6,false,8, 0xF3, 0xC1, 0xAF, 0xFD, 0xCA, 0xAF, 0xF9, 0x0A
504111,0x1CC,false,8, 0x11, 0xF8, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0x0F
504112,0x1CD,false,8, 0x08, 0xF8, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0x0F
504113,0x1CE,false,8, 0xFA, 0xF8, 0xFF, 0xFF, 0xEF, 0xFF, 0xFE, 0x0F
6 | Temp Found504191,0x1A555406,false,8, 0x6C, 0x00, 0x00, 0x00, 0x6B, 0x6B, 0xFB, 0xFB
504229,0x16A9543F,false,8, 0xF4, 0x0F, 0x24, 0x00, 0x00, 0x00, 0x00, 0x00
504306,0x16A9542F,false,8, 0xC3, 0x54, 0x15, 0x01, 0x33, 0x00, 0x00, 0x00
504432,0x1A555467,false,8, 0x83, 0x43, 0x48, 0x20, 0x20, 0xB7, 0x00, 0x00
504480,0x16A95441,false,8, 0xEC, 0x05, 0x24, 0x00, 0x00, 0x00, 0x00, 0x00
504516,0x16A95431,false,8, 0x2A, 0x53, 0x1D, 0x01, 0x31, 0x00, 0x00, 0x00
504536,0x18FED802,false,5, 0x0A, 0x21, 0x00, 0x00, 0x00
8 | Temp Found504604,0x1A555408,false,8, 0x6B, 0xC0, 0x00, 0x00, 0x69, 0x6B, 0xFB, 0xFB
6,0 | 504606,0x1C4,false,8, 0xF2, 0x52, 0xAF, 0xF7, 0x8A, 0xAF, 0xF8, 0x0A
6,1 | 504607,0x1C5,false,8, 0x7A, 0x72, 0xAF, 0xF9, 0x6A, 0xAF, 0xF8, 0x0A
6,2 | 504608,0x1C6,false,8, 0xCB, 0xC2, 0xAF, 0xFD, 0xCA, 0xAF, 0xF9, 0x0A
504612,0x1CC,false,8, 0x28, 0xF9, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0x0F
504613,0x1CD,false,8, 0x01, 0xF9, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0x0F
504615,0x1CE,false,8, 0xE0, 0xF9, 0xFF, 0xFF, 0xEF, 0xFF, 0xFE, 0x0F
504731,0x16A9543F,false,8, 0x71, 0x00, 0x24, 0x00, 0x00, 0x00, 0x00, 0x00
504808,0x16A9542F,false,8, 0xDE, 0x55, 0x15, 0x01, 0x33, 0x00, 0x00, 0x00
504848,0x18FED602,false,5, 0x0C, 0x21, 0x00, 0x00, 0x00
504982,0x16A95441,false,8, 0x9F, 0x06, 0x24, 0x00, 0x00, 0x00, 0x00, 0x00
505018,0x16A95431,false,8, 0xCC, 0x54, 0x1D, 0x01, 0x31, 0x00, 0x00, 0x00
505043,0x1A555465,false,8, 0x83, 0x43, 0x48, 0x20, 0x20, 0xB7, 0x00, 0x00
6,0 | 505107,0x1C4,false,8, 0x9F, 0x63, 0xAF, 0xF7, 0x8A, 0xAF, 0xF8, 0x0A
6,1 | 505108,0x1C5,false,8, 0x13, 0x73, 0xAF, 0xF9, 0x6A, 0xAF, 0xF8, 0x0A
6,2 | 505109,0x1C6,false,8, 0xA6, 0xC3, 0xAF, 0xFD, 0xCA, 0xAF, 0xF9, 0x0A
505113,0x1CC,false,8, 0x12, 0xFA, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0x0F
505114,0x1CD,false,8, 0x6A, 0xFA, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0x0F
505115,0x1CE,false,8, 0xED, 0xFA, 0xFF, 0xFF, 0xEF, 0xFF, 0xFE, 0x0F
1
6 | Temp Found505193,0x1A555406,false,8, 0x6C, 0x00, 0x00, 0x00, 0x6B, 0x6B, 0xFB, 0xFB
Debug Settings Menu
Toggle on/off
1 - Can Debug :0
3 - Output Check :0
4 - Input Check :0
5 - ESS mode :0
7 - Gauge Debug :0
8 - CSV Output :0
q - Go back to menuSorry long post but I tried to be precise.
Re: Simp BMS
So there is some more checks for plausible values being sent by modules, you log is showing 0x1CC, 0x1CD, 0x1CE as are expected for module 8 but all with 0xFF or 0xFE for cell voltages or translates to not correct cell voltages.JaniK wrote: ↑Tue Sep 19, 2023 7:34 pm I am using original old SimpBMS hardware, the software version is from 11.03.2023
VW BMS V2
The modules messages are discarded if they are shown as 0xFF in any of the plausible voltage locations as those are not correct messages.
For some reason your module 8 is not happy.
- JaniK
Re: Simp BMS
Thanks for your very fast reply and help!tom91 wrote: ↑Tue Sep 19, 2023 8:50 pm So there is some more checks for plausible values being sent by modules, you log is showing 0x1CC, 0x1CD, 0x1CE as are expected for module 8 but all with 0xFF or 0xFE for cell voltages or translates to not correct cell voltages.
I will try to think what could cause this, maybe I make a new simpBMS to one VW module CAN cable and continue testing then with modules on the table. PS, when 8S is read to CANBUS, disconnecting only orange interconnect cable between BMS and first 4S module results in module missing text and no voltages are then present. but only disconnecting the interconnect from 2S module removes temp reading temp3 but no error appears.
Re: Simp BMS
Please create a can log of connecting Module #8, so the 4s + 4s. this is required due to the way it powers itself. Once this shows correct data, connect the final section. I get the feeling something is weird about the wiring setup causing errors in the module voltage reading. Have you connected the cell modules HV together as it should?
- JaniK
Re: Simp BMS
The CAN module #8 is 10S and module #4 is 10S module also, so used the module #4 with 4S and 2S dumb modules for these logs, since module #8 is in the car and these were not currently installed. So could just bring them to kitchen table for debugging.tom91 wrote: ↑Wed Sep 20, 2023 6:23 am Please create a can log of connecting Module #8, so the 4s + 4s. this is required due to the way it powers itself. Once this shows correct data, connect the final section. I get the feeling something is weird about the wiring setup causing errors in the module voltage reading. Have you connected the cell modules HV together as it should?
I think my previous log from module #8 had only FF FE everywhere, because I had taken log on wrong point in testing or something, after I didnt get it to work. so starting fresh:
Now we have a new cable and direct CAN bus from SimpBMS to e-golf gen2 samsung 10S CAN module #4,
with termination on both ends, total 60ohm between H and L. the interconnect wires are double checked and HV links are installed.
"Immediately" after connecting power to module, we have cell voltages.
I think the last 2S voltages are also on the can bus, but the simpbms filteres them for some reason??
Is it 0x1BE?:
"4,0 | 1336511,0x1BC,false,8, 0x68, 0x41, 0xAF, 0xF6, 0x5A, 0xAF, 0xF5, 0x0A
4,1 | 1336512,0x1BD,false,8, 0x35, 0xA1, 0xAF, 0xFC, 0xAA, 0xAF, 0xFC, 0x0A
1336512,0x1BE,false,8, 0xD9, 0x81, 0xAF, 0xF7, 0xEA, 0xFF, 0xFE, 0x0F"
(If i remove 2S interconnect plug from 2S module on the fly it changes to:
60965,0x1BE,false,8, 0xED, 0xF4, 0xFF, 0xFF, 0xEF, 0xFF, 0xFE, 0x0F)
Debug Settings Menu
Toggle on/off
1 - Can Debug :1
2 - Current Debug :1
3 - Output Check :0
4 - Input Check :0
5 - ESS mode :0
6 - Cells Present Reset :8
7 - Gauge Debug :0
8 - CSV Output :0
q - Go back to menu
1336089,0x18FED402,false,5, 0x0A, 0x20, 0x00, 0x00, 0x00
4 | Temp Found1336109,0x1A555404,false,8, 0x74, 0xC0, 0x00, 0x00, 0x72, 0x74, 0xFB, 0xFB
1336129,0x16A9542D,false,8, 0xD4, 0x11, 0x11, 0x00, 0x10, 0x00, 0x00, 0x00
1336160,0x16A9543D,false,8, 0xDC, 0x01, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00
1336357,0x16A9542D,false,8, 0x24, 0x52, 0x11, 0x00, 0x13, 0x00, 0x00, 0x00
1336661,0x16A9543D,false,8, 0xE3, 0x02, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00
1336858,0x16A9542D,false,8, 0xAE, 0x53, 0x11, 0x00, 0x13, 0x00, 0x00, 0x00
1336959,0x1A555463,false,8, 0x00, 0x35, 0x51, 0x45, 0x35, 0x97, 0x00, 0x00
1336960,0x16A9542D,false,8, 0xB7, 0x54, 0x15, 0x01, 0x13, 0x00, 0x00, 0x00
4,0 | 1337013,0x1BC,false,8, 0x11, 0x42, 0xAF, 0xF6, 0x5A, 0xAF, 0xF4, 0x0A
4,1 | 1337013,0x1BD,false,8, 0xB8, 0xA2, 0xAF, 0xFC, 0xBA, 0xAF, 0xFC, 0x0A
1337013,0x1BE,false,8, 0xCF, 0x82, 0xAF, 0xF6, 0xEA, 0xFF, 0xFE, 0x0F
1337091,0x18FED402,false,5, 0x0A, 0x20, 0x00, 0x00, 0x00
4 | Temp Found1337111,0x1A555404,false,8, 0x75, 0x40, 0x00, 0x00, 0x73, 0x74, 0xFB, 0xFB
1337163,0x16A9543D,false,8, 0x30, 0x03, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00
1337461,0x16A9542D,false,8, 0x62, 0x55, 0x15, 0x01, 0x13, 0x00, 0x00, 0x00
1337548,0x16A9543D,false,8, 0xE2, 0x04, 0x04, 0x00, 0x00, 0x00, 0x00, 0x00
1337961,0x1A555463,false,8, 0x01, 0x39, 0x39, 0x41, 0x48, 0x26, 0x00, 0x00
1337962,0x16A9542D,false,8, 0xAB, 0x56, 0x15, 0x01, 0x13, 0x00, 0x00, 0x00
4,0 | 1338015,0x1BC,false,8, 0xC2, 0x43, 0xAF, 0xF6, 0x5A, 0xAF, 0xF4, 0x0A
4,1 | 1338015,0x1BD,false,8, 0x0B, 0xA3, 0xAF, 0xFC, 0xBA, 0xAF, 0xFC, 0x0A
1338015,0x1BE,false,8, 0xFF, 0x83, 0xAF, 0xF6, 0xEA, 0xFF, 0xFE, 0x0F
1338049,0x16A9543D,false,8, 0x72, 0x05, 0x04, 0x00, 0x00, 0x00, 0x00, 0x00
1338093,0x18FED402,false,5, 0x0A, 0x20, 0x00, 0x00, 0x00
4 | Temp Found1338113,0x1A555404,false,8, 0x75, 0x40, 0x00, 0x00, 0x72, 0x74, 0xFB, 0xFB
1338464,0x16A9542D,false,8, 0x63, 0x57, 0x15, 0x01, 0x13, 0x00, 0x00, 0x00
4,0 | 1338515,0x1BC,false,8, 0x2E, 0x44, 0xAF, 0xF6, 0x5A, 0xAF, 0xF4, 0x0A
4,1 | 1338516,0x1BD,false,8, 0xE1, 0xA4, 0xAF, 0xFC, 0xBA, 0xAF, 0xFC, 0x0A
1338516,0x1BE,false,8, 0xDC, 0x84, 0xAF, 0xF6, 0xEA, 0xFF, 0xFE, 0x0F
1338551,0x16A9543D,false,8, 0x8E, 0x06, 0x04, 0x00, 0x00, 0x00, 0x00, 0x00
1338963,0x1A555463,false,8, 0x02, 0x30, 0x33, 0x32, 0x32, 0x76, 0x00, 0x00
1338965,0x16A9542D,false,8, 0x78, 0x58, 0x15, 0x01, 0x13, 0x00, 0x00, 0x00
4,0 | 1339016,0x1BC,false,8, 0x85, 0x45, 0xAF, 0xF6, 0x5A, 0xAF, 0xF4, 0x0A
4,1 | 1339017,0x1BD,false,8, 0x25, 0xA5, 0xAF, 0xFC, 0xBA, 0xAF, 0xFC, 0x0A
1339017,0x1BE,false,8, 0x46, 0x85, 0xAF, 0xF6, 0xEA, 0xFF, 0xFE, 0x0F
1339052,0x16A9543D,false,8, 0xBB, 0x07, 0x04, 0x00, 0x00, 0x00, 0x00, 0x00
1339095,0x18FED402,false,5, 0x0A, 0x20, 0x00, 0x00, 0x00
4 | Temp Found1339115,0x1A555404,false,8, 0x75, 0x40, 0x00, 0x00, 0x72, 0x74, 0xFB, 0xFB
1339153,0x16A9543D,false,8, 0x67, 0x08, 0x24, 0x00, 0x00, 0x00, 0x00, 0x00
1
1339467,0x16A9542D,false,8, 0x17, 0x59, 0x15, 0x01, 0x13, 0x00, 0x00, 0x00
4,0 | 1339518,0x1BC,false,8, 0xB7, 0x46, 0xAF, 0xF6, 0x5A, 0xAF, 0xF4, 0x0A
4,1 | 1339518,0x1BD,false,8, 0x68, 0xA6, 0xAF, 0xFC, 0xBA, 0xAF, 0xFC, 0x0A
1339518,0x1BE,false,8, 0x9F, 0x86, 0xAF, 0xF6, 0xEA, 0xFF, 0xFE, 0x0F
Debug Settings Menu
Toggle on/off
1 - Can Debug :0
3 - Output Check :0
4 - Input Check :0
5 - ESS mode :0
7 - Gauge Debug :0
8 - CSV Output :0
q - Go back to menu
q
MENU
Debugging Paused
Firmware Version : 221026
b - Battery Settings
a - Alarm and Warning Settings
e - Charging Settings
c - Current Sensor Calibration
k - Contactor and Gauge Settings
i - Ignore Value Settings
d - Debug Settings
q - exit menu
q
BMS Status : 5 Error 8
Modules: 0 Cells: 8 Strings: 1 Voltage: 30.464V Avg Cell Voltage: 3.808V Low Cell Voltage: 3.804V High Cell Voltage: 3.812V Delta Voltage: 8mV Avg Temp: 14.833C
Module #4 30.46V Cell0: 3.80V Cell1: 3.81V Cell2: 3.81V Cell3: 3.80V Cell4: 3.81V Cell5: 3.81V Cell6: 3.81V Cell7: 3.81V Cell8: 0.00V Cell9: 0.00V Cell10: 0.00V Cell11: 0.00V Cell12: 0.00V
Temp 1: 15.50C Temp 2: 14.00C Temp 3: 15.00C | Bal Stat: 0
CANbus 0.00mA 100% SOC 111000.00mAh
Modules: 1 Cells: 8 Strings: 1 Voltage: 30.464V Avg Cell Voltage: 3.808V Low Cell Voltage: 3.804V High Cell Voltage: 3.812V Delta Voltage: 8mV Avg Temp: 14.833C
Re: Simp BMS
My bad, I forget the fact that the E-Golf has 10S modules, let me tweak my code and upload for you to test. The filtering is to keep starting modules and messages for empty voltage from messing with things.
New one here:
https://github.com/Tom-evnut/VW-bms/tree/master/VWBMSV2
New one here:
- JaniK
Re: Simp BMS
THANKS TOM ! now it works. No worries, I am just happy it wasn't hardware issue.tom91 wrote: ↑Wed Sep 20, 2023 6:50 pm My bad, I forget the fact that the E-Golf has 10S modules, let me tweak my code and upload for you to test. The filtering is to keep starting modules and messages for empty voltage from messing with things.
New one here:
Also now I actually learned something about how it works.
BMS Status : 1 Ready 10
Modules: 1 Cells: 10 Strings: 1 Voltage: 38.076V Avg Cell Voltage: 3.808V Low Cell Voltage: 3.804V High Cell Voltage: 3.812V Delta Voltage: 8mV Avg Temp: 15.500C
Module #4 38.08V Cell0: 3.80V Cell1: 3.81V Cell2: 3.81V Cell3: 3.80V Cell4: 3.81V Cell5: 3.81V Cell6: 3.81V Cell7: 3.81V Cell8: 3.81V Cell9: 3.81V Cell10: 5.09V Cell11: 5.09V Cell12: 0.00V
Temp 1: 16.50C Temp 2: 15.00C Temp 3: 15.00C | Bal Stat: 0
Re: Simp BMS
Just for background info, turns out all of the flavours of VW/VAG uses the same CAN bus format, yet they all do somethings slightly different. You can have modules with 8 up to 16 cells, so 2 to 4 CAN bus messages with voltage.
Never done alot with the Egolf so was focusing on filtering when adding compatibility for the MEB the 10s situation got overlooked.
A interesting question for you, ever heard of the VAG 13s module
- JaniK
Re: Simp BMS
I think maybe this thread had it mentioned? Maybe I read about it being reason for the cell12? when I was browsing for solution to my problem before posting it. But I can't remember where it was used or anything.
BTW, opened up the 10S and 8S CAN Modules covers to measure voltages from board to rule out bad connectors, and even the 8S is physically equipped with 12 sets of resistors for balancing and they all look to me identical to 12S version, so I was even thinking I have accidentally somehow reset the module to send only 8S voltages
Re: Simp BMS
Hi, I tried my SimpBMS the first time
I have Tesla B-Class satellite units. I believe I connected them correctly. I also tried different ways to connect the data connections. The Tesla unites were not connected to any batteries. I just wanted to see if the temp sensors work.
The SimpBMS was connected to two Tesla units, the display and via USB with the PC. But when reading the values no temperature was shown (and no voltage but that was expected). Does the BMS need another power connection or should it be possible to read the Temp sensor values from the Tesla B-Class units in this minimal setup?
Re: Simp BMS
Connect them to the batteries or they do not work. This has been said many times now, the BMS slaves are isolated and are powered off the cells on the logic side.
- mnmn
- Has thanked: 17 times
- Been thanked: 3 times
Re: Simp BMS
Hello Tom,
I know, that the old Teensy board is unreachable, and so the SimpBMS is out of stock everywhere. I saw the EVS-BMS product, but do I understand right, that the software of these modules are not opensource anymore? So if I buy one, I can not modify it, just through sneding request to you?
Is there any chance, to buy (any type) hardware, which is able to run my "modified" simpBMS code?
Thank you very much,
Norbert
Norbert
EV-FAN
Re: Simp BMS
There has been people working on a ESP32 port of the Open Source SimpBMS code https://github.com/jamiejones85/ESP32-BMS
alexbeatle
- Has thanked: 82 times
- Been thanked: 35 times
Re: Simp BMS
Are there any notes how to setup the IVT-S sensor with the SImpBMS?
I have it selected in the menu: Have the IVT-S initialised and current transmits via 0x521 But the BMS reads gigantor values... CAN network is terminated on both ends and reads 60ohms.
royhen99
- Has thanked: 22 times
- Been thanked: 134 times
Re: Simp BMS
I have not used IVT-S with simpBMS but from looking at the code it uses big endian for current and voltage whereas Zombieverter and other OI solutions use little endian.
Re: Simp BMS
The IVTS setup is the factory default that is to be used with the SimpBMS, makes it easy on anyone buying one. No need to change any parameters.
alexbeatle
Re: Simp BMS
That's a bummer
tom91 do you think you can add an option in the menu to choose big endian vs little endian to make it more universal with the other OI solutions? Or I'll need to fork the code and learn how to reprogram my unit....
Re: Simp BMS
Why did you change the programming of the IDs are there other devices that us it too? Did you not propperly achieve a reset?alexbeatle wrote: ↑Wed Oct 04, 2023 3:41 pm tom91 do you think you can add an option in the menu to choose big endian vs little endian to make it more universal with the other OI solutions? Or I'll need to fork the code and learn how to reprogram my unit....
Never understood why people changed the CAN configs. If you need it the code is Opensource and I am not making any updates or changes to it myself, forking it will be the only way to get changes. These can ofcourse be pushed back into the main branch when proven.
et0
- Has thanked: 15 times
- Been thanked: 6 times
Re: Simp BMS
I have this same problem after replacing the broken Teensy 3.2 on my SimpBMS 2.3, and flashing it with the only .hex I could find, which is the one here: https://github.com/Tom-evnut/AmperaBatt ... ENSY32.hexamsmntparks wrote: ↑Wed Sep 06, 2023 12:00 am Has anyone used the VoltBMSV2 code yet? My Simp was constantly restarting because the watchdog wasn't updating. I got it to "work" by commenting out the cleartime block of the main loop, but I'm wondering if this version of the code is still in progress. It's possible I just don't have the settings configured properly, but I'd love to know if the code "should" be working as is.
Does anyone have a solution, or another .hex to try? I will update if I find the answer too.
Starting up!
SimpBMS V2 Volt-Ampera
Reason for last Reset:
Watchdog(COP) Reset
Started serial interface
Resetting to factory defaults
BMS Status : 5 Error 0 0
Modules: 0 Cells: 0 Strings: 1 Voltage: 0.000V Avg Cell Voltage: nanV Low Cell Voltage: 5.000V High Cell Voltage: 0.000V Delta Voltage: -5000mV Avg Temp: nanC
CANbus 0.00mA 0% SOC 0.00mAh
Re: Simp BMS
It turns out the Serial CAN library stopped working after an IDE update.
Now released one that remove Serial CAN functionality and it works again. I will consider the Serial CAN function which was limited to the Chevy Volt battery a dead function.
Update: turns out not to be the full fix, I do not have a chevy volt test setup so I recommend rolling back to a working .hex file, I made a branch for this purpose on github. https://github.com/Tom-evnut/AmperaBatt ... /VoltBMSV2
et0
Re: Simp BMS
Massive thanks for sorting this out Tom! I was worried that my replacement Teensy was defective. But it's all working again now with the roll-back version.
- andybpowell
- Has thanked: 219 times
- Been thanked: 257 times
Re: Simp BMS
It does indeed I believe modified version of the PHEV code will do it due to more modules available. However if it does not I can review can logs and make it work.andybpowell wrote: ↑Tue Oct 24, 2023 8:08 am Does anyone know if Simp BMS works with the X5 12x8s pack ?
Out of curiosity where did you find one affordable?
- andybpowell
