Hi all, hope you have an easy fix.
I am having trouble with initiating all three modules on the charger. If I set it to manual 3p it only turns on one module not all 3. I can swap from charger 1,2or 3, but individually.
I am on the latest firmware and have the gen 3 charger on the v3 board.
Each one of the modules charge beautifully, but not together.
Any ideas would be great please.
Thanks in advance
3phase charging issue gen3 v3
- Has thanked: 369 times
- Been thanked: 1544 times
Re: 3phase charging issue gen3 v3
It's a flag field. Set it to 7 with the custom command function "set chargerena 7"
