i3 SME / Safety Box using CAN?
mnmn
Has thanked: 17 times
Post by mnmn »
Is it possible to command the SME / Safety Box of an i3, using CAN?
(Similar to the solution from Damien with the BMW PHEV SBox)
Does they use the same circuit in the boxes?
The connector on the i3 cable has 2x8 pins :)
Edit: 2x6pins has the white connector.
Thank you
EV-FAN
muehlpower
Been thanked: 186 times
Re: i3 SME / Safety Box using CAN?
Post by muehlpower »
It can definitely be controlled. It sends 6 CAN messages and receives 15+ messages. CAN high is on A191-1B pin 4, CAN low is on pin 10, GND on pin 2, Kl30 on pin 7, Kl15 on pin 9.
mnmn
Post by mnmn »
Great news :) thank you very much!
I guess, these commands are not the same, as for the PHEV, right?
Can you give me some more info about them?
Thank you very much in advance.
EV-FAN
muehlpower
SME sends: 2F5h,431h,239h,432h,1FAh,112h
SME receives: 2CAh,2F5h,3F9h,397h,3E8h,380h,3A0h,37Bh,1A1h,108h,330h,12Fh,3E9h,432h,3CAh,328h,30Bh,19Bh,1B9h
you can find the IDs marked in red in the LIM tread
mnmn
Post by mnmn »
Thank you very much!
EV-FAN
Has thanked: 631 times
Been thanked: 1607 times
sorry I am late to the party as per always, would it be possible to get the SME pinout for power and CAN here please I know there's other peeps interested in using these BMW i3 sBoxes as well
