inverter tempHS fluctuations
FFMan
Has thanked: 9 times
Been thanked: 50 times
Post by FFMan »
I'm adding some over under range detection to my code and (assuming no bugs in my code etc) note that temphs (I have it mapped to a can message like so can tx tmphs 20 0 16 1.00 0), varies wildly and quickly.
It'll start off at approx ambient and on a light throttle will be around 50, but if i nail the throttle in rises within seconds to 90+, and the settles equally as quickly when i lift off. The fluctuations are so quick and large that it's hard to believe it is measuring temperature at all.
What is the experience of others if monitoring this ?
Retired - (E46 touring, Phev rear motor, OEM inverter cabin heater and charger,BMW 9kwh & 12kwh packs)
[WIP] JImny & phev running gear
Has thanked: 91 times
Been thanked: 517 times
Re: inverter tempHS fluctuations
It's like this on the Prius gen3 inverter, it's measuring the temperature of the IGBTs. It will rise and fall rapidly.
FFMan
Post by FFMan »
Bigpie wrote: Mon Aug 21, 2023 9:35 am It's like this on the Prius gen3 inverter, it's measuring the temperature of the IGBTs. It will rise and fall rapidly.
ok - so normal
what might a sensible maximum value alert be do you think ?
Personally, I don't worry about it :D The Prius inverter will protect itself, can't remember if it cuts out or derates, but I've never managed to get there with my setup.
bexander
Has thanked: 78 times
Been thanked: 102 times
Post by bexander »
Bigpie wrote: Mon Aug 21, 2023 10:10 am Personally, I don't worry about it :D The Prius inverter will protect itself, can't remember if it cuts out or derates, but I've never managed to get there with my setup.
I use the Yaris inverter with the same behaviour and I agree with Bigpie.
FFMan wrote: Mon Aug 21, 2023 9:36 am ok - so normal
I have a warning light come on at 80degC over a 10 sample average.
FFMan
Post by FFMan »
ok - mine was set to 65 over 10 average and kept alerting so i'll push it up.
thanks
