As the title says is it possible on V1c latest f/w to have throttle controlled by physical pot but regen level set by can.
Settings options would suggest not, but just wondered if there is a loophole ?
Possible to have pot throttle, can regen
- Has thanked: 8 times
- Been thanked: 47 times
E46 touring
BMW 9kwh & 12kwh packs
- Has thanked: 75 times
- Been thanked: 314 times
Re: Possible to have pot throttle, can regen
You can change settings with can messages. https://openinverter.org/wiki/CAN_communication Look at can SDO
VW Beetle 2003
Outlander front generator
Outlander charger
3x Golf GTE batteries
Chademo Charging
Outlander water heater
Outlander charger
Chademo Charging
yes thanks
i saw that, but does sdo work regardless of pot settings ? I have potmode set to 0 which means both throttle and regen are pots, will using sdo to write a regen value still work, as i think you have both throttle and regen on can don't you so potmode=2 ?
E46 touring
- Has thanked: 180 times
- Been thanked: 1109 times
With 5.27 you can set regenpreset via CAN 0-100% and have throttle via ADC
For V1c latest f/w version, throttle control by physical potentiometer and regenerative level setting via CAN protocol may not be supported by the existing setting
The site modded apk for android techzapk offers a vast collection of Mod APKs, which are modified versions of popular apps and games available for Android devices.
Oh wait, I assumed inverter here. ZombieVerter most likely doesn't support that as of now.
Sure, the latest firmware version of the V1c may not support throttle control by physical potentiometer and regenerative level setting via CAN protocol. This means that you may not be able to use both features at the same time.WilliamWard wrote: ↑Sat Jul 29, 2023 7:30 am For V1c latest f/w version, throttle control by physical potentiometer and regenerative level setting via CAN protocol may not be supported by the existing settingangry gran
i am using V1c in Prius inverter. Not only would i lke to vary regen by pedal pressure, but also vary it depending on which gear the car is in.
Regen levels ok in 2nd gear are quite harsh in first gear.
E46 touring
