fredd90 wrote: ↑Thu Jun 17, 2021 10:27 pm
Then it was time to spread some light over all the broken Large drive units, i have against all odds managed to bring life to my P85 drive unit.
After replacing all the igbt in one of the bridges.
As well as all semiconductors in all three drive cards, everything had a short circuit. Not unexpectedly i constantly had overcurrent alarms.
Everything solder together, just the cap left.
All semiconductor on the "isolated" side replaced.
Everything from igbt driver to diodes and n/p transtors.
After final test i decided to add some re-entering silicone.
Couldn't find any transparent unfortunately.
Not a project for everyone but it has been quite educational, spare parts have cost about 4-500eur. Also had to buy a new soldering iron of 200w to cope with the thick laminated copper. The worst part was all the lacquered circuit boards in combination with the extreme lack of semiconductors...
Are you using this with the openinverter or some other logic board, not the stock one?
Reason I am asking is I went through the same thing, but just elected to replace the entire phase, and the motor still doesn't work. I really, really don't think anything is wrong with any of the hardware at all, just the (OEM) logic board having a stuck fault.
I think if you have this issue using the OEM controller, you must replace the controller as well unless you know how to reflash it. And finding a known good used controller board is not easy. Especially since the sport and non-sport use the same board but are not compatible with each other without a reflash.
