GS450h, 300h cvt gear ratio modulation
Huskte
Has thanked: 13 times
Been thanked: 9 times
Post by Huskte »
Is it possible to change the internal gear ratio of the cvt by having it function like a cvt. Is this a limitation of current software and our knowledge of the transmissions or is it simply not possible?
Has thanked: 365 times
Been thanked: 249 times
Re: GS450h, 300h cvt gear ratio modulation
Post by jrbe »
I think it would only work if you have a 3rd motor driving the input shaft or had some other way of modulating the planetary gears.
