Safe operating temp for phev charger
FFMan
Has thanked: 9 times
Been thanked: 50 times
Post by FFMan »
Does anyone know what a safe operating temp for a phev charger is.
I've got coolant running through it which hits 41c but the charger reports a stable 75c when charging at capacity.
Seems a bit high to me.
Has thanked: 91 times
Been thanked: 517 times
Re: Safe operating temp for phev charger
I've had mine that high, not checked recently though. Which way up have you mounted it? It's layed flat in the outlander, but I've got mine stood up, and pretty sure I had air trapped in there.
FFMan
Post by FFMan »
Mine is flat and hopefully no air as i fitted a bleed point nearby but it is possible.
it does level out at 75. Do you code to derate or cutoff at a certain temp ?
Can't remember, don't think it derated itself, mine is generally at 55 now, but I run a fan on rad when charging
Has thanked: 330 times
Been thanked: 848 times
It self regulates, seen it above 90C on certain temp sensors.
the case itself also gets quite hot (30C+) even under "normal" operation.
Ev8
Has thanked: 44 times
Been thanked: 173 times
Post by Ev8 »
Generally I see 50-60c on the higher of the 2 temp sensors, I do run a full size fiat cincento rad and the big brushless Bosch pump though
FFMan
Post by FFMan »
yeah i've got the original rad still in the car, but the pump could be bigger
i'll see how it goes, if it peaks at 75c i expect that is ok
