Share parameters?
Joxson
Share parameters?
Post by Joxson »
Hi!
Is it anyone who can share a working set of parameters for the LDU sport unit?
Im quite new at tuning and Im looking in to getting a little head start ;)
Thanks in advance!
Best Regards
Joachim Westerlund :)
bexander
Has thanked: 78 times
Been thanked: 102 times
Re: Share parameters?
Post by bexander »
Seem like these parameters are a bit old but might get you going.
https://openinverter.org/parameters/
Try the search function on the forum as well, specially in the Tesla section.
P.S.Mangelsdorf
Has thanked: 323 times
Been thanked: 352 times
Post by P.S.Mangelsdorf »
Here are the two Tesla parameter threads:
viewtopic.php?t=195&hilit=parameter+thread
viewtopic.php?t=126&hilit=ldu+tuning
I'd generally say start with Jon Volk's tune, and tweak from there. I believe the set attached here is his most recent. If I remember correctly he was on a base LDU, but its probably a good starting point for your Sport LDU as he was right to the limit of what a base can take.
I've also attached my most recent parameter dump (just called params). On my base LDU, I'm still having an overcurrent issue when going WOT with a full battery pack. I'm still trying to find a tune that eliminates that while maintaining the violence. There is a chance I've got some inverter damage, but unknown at this time. This was on firmware v5.20
params.json
(1.49 KiB) Downloaded 150 times
JonVolk TESLA_PARAMS 2022-05-29.json
(1.47 KiB) Downloaded 220 times
Joxson
Post by Joxson »
Thanks for the replies! Will upload them and tune after that!
Best Regards
catphish
Has thanked: 99 times
Been thanked: 197 times
Post by catphish »
On the topic of shared Tesla paramaters, please can someone (ie johu) change the tripmode on the official SDU and LDU paramaters? The current defaults are almost definitely responsible for some damaged hardware.
Has thanked: 246 times
Been thanked: 469 times
Sad nobody uses the pram data base :(
catphish
Post by catphish »
Bratitude wrote: Thu Jun 22, 2023 11:28 am Sad nobody uses the pram data base :(
Unfortunately the param database is quite broken. I was planning to fix it but just never got time to do so :(
its such a good idea, the potential is there. forum sharing is such a mess
Been thanked: 1914 times
Yes, could use a rewrite. Would prefer more server side, less js.
https://github.com/jsphuebner/parameter-database
tripmode updated.
