BMW I3 BMS
Mouse
Been thanked: 7 times
BMW I3 BMS
Post by Mouse »
Does anyone know anything about hacking the BMW I3 BMS system?
I've had a look around and can't find much regarding to amateur systems that can read the information from of them.
Has thanked: 199 times
Been thanked: 524 times
Re: BMW I3 BMS
The SimpBMS will work with the slaves from the BMW I3.
https://github.com/tomdebree/BMWI3BMS
Currently working on getting the balancing working, quite close now.
Mouse
Re: BMW I3 BMS
Post by Mouse »
Thanks for that.
Your Simp BMS looks like an interesting module. Is it fully a open source project?
Not sure if I can help but I'm often in Bristol if you want an hand or even just encouragement with the balancing.
Re: BMW I3 BMS
Not fully, hardware only V1 is opensource if you want to run it on just a teensy and can transceiver you can easily.
Mouse
Re: BMW I3 BMS
Post by Mouse »
Thanks, that's interesting to know especially as I've got things like Teensys knocking about in the workshop.
I've also just spotted the Simp BMS thread so I'll read that before asking any more RTFM questions.
Scott166
Re: BMW I3 BMS
Post by Scott166 »
Sorry to jump in but it is related, can you use Simp BMS to increase the range?
BMW set a buffer of 80% I presume for longevity but as my project will only be used sparingly I am less worried about getting 150,000 miles out of a pack.
Would this just involve charging to a higher voltage?
Restoring and converting a Classic Mini, I have mad ideas, semi sensible ideas and NO idea if I’ll ever get it done :lol:
Look me up on YouTube https://youtube.com/channel/UCxmP1hLys6Z5tHZpK5mn6eg to see my progress
mjc506
Has thanked: 30 times
Been thanked: 29 times
Re: BMW I3 BMS
Post by mjc506 »
With SimpBMS, you control the contactors, charging voltage and minimum voltage. You can set it to run the battery down to 0V if you really wanted to... (There's probably not all that much energy available at the low end, but charging higher might get you a bit of additional range)
Scott166
Re: BMW I3 BMS
Post by Scott166 »
mjc506 wrote: Tue May 10, 2022 1:30 pm With SimpBMS, you control the contactors, charging voltage and minimum voltage. You can set it to run the battery down to 0V if you really wanted to... (There's probably not all that much energy available at the low end, but charging higher might get you a bit of additional range)
Thank you
