Tesla LDU Pick & Place File Fix?  [SOLVED]
nubster
Has thanked: 66 times
Been thanked: 20 times
Post by nubster »
Hey everybody,
Trying to build my first LDU board here and ran into a couple of issues. Hoping someone can point me in the right direction.
I cloned johannes's repo and tried using the V6 files to order from JLCPCB. Due to a recent change on their side, the BOM file needed the Package column renamed to Footprint, which I easily addressed.
However, the pick & place file (CPL) does not render correctly in the preview. All the components seem to be off by a little bit, and some rotations are incorrect. I'm unsure if this is just a rendering issue or if the CPL actually needs to be updated. I tried editing the CPL file manually to see, and I was able to correct a few components, according to the preview, at least.
I am happy to contribute a PR to fix these minor issues, but I am unsure of the best way to fix the entire CPL. I tried opening the SCH file with KiCad, but I got an error saying it does not appear to be an Eeschema file, so is there another software I need to use? Should I write a Python script to fix it, as it's just a CSV file? What's the best approach? I am still relatively new to all this, so any help pointing me in the right direction is much appreciated. Thanks!
Owner | Founder: Westside EV
YouTube Channel
royhen99
Has thanked: 22 times
Been thanked: 134 times
Re: Tesla LDU Pick & Place File Fix?  [SOLVED]
Post by royhen99 »
The PCB layout tool is DesignSpark. Its placement file is not very compatible with JLCPCB. I have manunally adjusted the location and rotation in attached file. Check carefully as there could still be some mistakes. While doing that I noticed that the clearance between USART_RX and GND pin on STM32 was less than 0.1mm. I have corrected that and attached gerber files.
Tesla_V6_Gerber2.zip
(83.93 KiB) Downloaded 183 times
Tesla_V6_CPL_JLC.csv
(4.26 KiB) Downloaded 295 times
The files are the result of my manual adjustment but I was less eager than royhen ;)
Jlcpcb adjusts the placement, most of all they need to know polarity/pin1 of all components.
Anyway, thanks for posting the updates, will put them in the repo
catphish
Has thanked: 99 times
Been thanked: 197 times
Post by catphish »
It really bothers me that DesignSpark can't produce valid JLCPCB placement files, and I would be kinda embarrassed sending sending JLC a mess and expecting them to guess where everything should go. Also a big risk of orientations ending up incorrect.
Thanks royhen99 for posting corrected files.
This reply is more of a rant. I hope future designs can be done in Kicad which has a nice tool that spits out almost perfect JLC placement files (though be sure to fix the IC orientation with their GUI before finalizing.
I don't blame Damien for any of this of course, it's just bad luck that DesignSpark doesn't produce the right output. I've already pestered him enough to start using Kicad :)
nubster
Post by nubster »
You guys are the best, thank you! :pray:
YouTube Channel
