Aloha!
Does anyone know this torque value (bolts under the orange cover that connect the inverter cables to the motor cables?
Getting ready to try this thing...
Thanks!
SDU inverter to motor cable bolt torque?
- EV_Builder
- Been thanked: 37 times
Re: SDU inverter to motor cable bolt torque?
It's M6 but it are copper bolts if i recall correctly.
I would google the M6 strength for steel and compare steel to copper strength and down factor accordingly. With some safety.
- Boxster EV
- Has thanked: 57 times
- Been thanked: 50 times
Or just use goodandtight torque setting.EV_Builder wrote: ↑Fri May 12, 2023 9:39 pm It's M6 but it are copper bolts if i recall correctly.
