Ansaldo Motor
- Has thanked: 75 times
- Been thanked: 696 times
Ansaldo Motor
My new Ansaldo motor in the E39 hates me. Finally got the cooling done today and decided to go try some tuning. Not very successfully. Can't get more than about 30 amps of battery current into the inverter but motor current very high. Speed signal is clean and current sensors are reading correctly. From what I can tell by the rating plate and looking in the terminal box, this is a delta wound motor. I picked it as it was available and seems to be rated for a low voltage as the Landyacht used to be DC. Any ideas much appreciated:)
Re: Ansaldo Motor
Can't seem to add picture of the motor plate. Error parsing server response.
- Has thanked: 455 times
- Been thanked: 1771 times
Re: Ansaldo Motor
Uploaded the file for you. It should work now, permission problems - of course.
So its a 2-pole pair motor (9000 rpm @ 310Hz)
It is also a bit of a give-away for the slip frequency: sync frequency at 9000rpm would be 300Hz. But they specify 310Hz -> 10Hz slip frequency! wow. Maybe try a range 3-10Hz or so.
Concerning V/Hz: fweak=73Hz (2200/30) at udcnom=183V (sqrt(2)*130V)
Is that about what you configured?
- ans_mot1.jpg (229.49 KiB) Viewed 13785 times
kiwifiat
- Been thanked: 11 times
Re: Ansaldo Motor
What type of position feedback does that motor have? If changing fslip makes no appreciable difference to the performance it might suggest that the firmware doesn't know the rotor position accurately.
Re: Ansaldo Motor
It uses an AB encoder bearing with 75ppr. I did have a noise issue on the speed signal but it is now clean. I think Johannes has a good point about the slip. I'll give this a try.
Re: Ansaldo Motor
Hi!Jack Bauer wrote: ↑Sun Dec 23, 2018 9:01 am It uses an AB encoder bearing with 75ppr. I did have a noise issue on the speed signal but it is now clean. I think Johannes has a good point about the slip. I'll give this a try.
Are you sure about the bearing pulses? I have almost the same ansaldo motor with SKF bearing and 80ppr output.
- Sensor-Bearings---SKF-Motor-Encoder-Unit---15276-EN.pdf.zip
- (64.1 KiB) Downloaded 370 times
Re: Ansaldo Motor
No I'm not sure:) I just measured the pulses on the scope but could easily have made an error. That could very well be the answer. Thanks very much:)
Re: Ansaldo Motor
I went down to the car today and changed to the correct 80 ppr setting for the encoder. Sadly however this didn't fix the problem although the motor does run much smoother. The main problem seems to be very high motor amps from the start. With the second parameter set, basically changed fslipmin to 2 and flipmax to 10 and slipstart to 10%, I get a very good response for the first few mm of throttle travel. But as soon as I push the pedal the motor amps max out , current limit kicks in and the car creeps.
I have attached a graph of IL1 and IL2 vs Speed for first gear and gradual full throttle pedal travel. In neutral I can rev the motor to 6000rpm no problems and regen it to a stop. If I try and start in a higher gear the motor amps max out and the car does not move. I'm going to trailer the car back home in the next few days as it will be easier to do tests when it's here. Any help much appreciated:)
- params_ansaldo_e39_b.zip
- (1.34 KiB) Downloaded 471 times
Re: Ansaldo Motor
One other thing of note is I think this is a delta connected motor if that makes any difference?
Re: Ansaldo Motor
Only thing that jumps out is the high fweak. Which I calculated to be more like 80Hz. Maybe try the ppr part of the tuning script (only works with over uart)
- tuning.py.gz
- (2.34 KiB) Downloaded 434 times
Re: Ansaldo Motor
I had set fweak high to try and reduce motor current. Almost like the motor is not making any back emf.
Re: Ansaldo Motor
Found this interesting data sheet.
- Ansaldo Drive 30-60kW.pdf.zip
- (205.08 KiB) Downloaded 450 times
Re: Ansaldo Motor
Hmm, very inconsistent. So here we have udcnom=288V and fweak=100Hz.
Could there be some damage to the rotor?
Re: Ansaldo Motor
I guess it's possible but I hope not. Going to get the car home tomorrow so hopefully will get to the bottom of it.
Re: Ansaldo Motor
This is probably nuts but what if the encoder bearing data sheet is counting 80 pulses over 2 channels and its really a 40ppr per channel output?
Re: Ansaldo Motor
Sounds unlikely, but worth a gentle try.
Another thing that gets me: they state the "limiting" speed for the 80ppr bearing to be 5600 rpm but the motor is rated 9000rpm. The shaft dimension for the 80ppr bearing is 40-45 mm. Is that the diameter of your motors shaft?
Re: Ansaldo Motor
Well, got the car home today and tested the spare motor. It is indeed 80ppr on the encoder. Did a little bit of playing and still pritty much the same. ie hits current limit when trying to accelerate. This gets me thinking about a possible hardware problem with my Enova board. What would happen if the phase order or sequence got messed up? Like high drive swapped for low or something like that?
Re: Ansaldo Motor
Ok forget that as I doubt it would have ran my Toyota hybrid motor correctly in this video if it had a flaw :
Re: Ansaldo Motor
Could it be that you are only running on 2 phases?
Re: Ansaldo Motor
I think that is very likely. Or 2.5 phases. When I modified the 3 phase cables on the Enova inverter I had to remove the gate connection board. They use these silly push on connectors and you have to line up all 12 in one go. I bet one didn't seat properly and only 5 igbts are getting drive. Will check asap.
Re: Ansaldo Motor
Well, so much for that theory. All 3 phases working fine. Running in neutral in closed loop mode showed 62,66 and 68Amps peak on each phase. In gear with handbrake on showed 289 , 176 and 92A per phase with no rotor rotation. It just will not make any power regardless of what parameter combo I try and just hits current limit. More investigation tomorrow.
Re: Ansaldo Motor
Measured the stator inductances :
216uH , 217uH and 215uH
for comparison the Tesla front drive unit gives :
379uH , 380uH and 358uH.
Is there any differences in driving a delta wound motor as I think this is?
Re: Ansaldo Motor
Well I think I found the problem. The low inductance makes motors REALLY particular about their parameters. Am now getting to the point the car is driving but still a way to go. More updates soon:)
Re: Ansaldo Motor
Yes, the values and step sizes you used for finding a good setup would be really valuable.
Have a good new year
Re: Ansaldo Motor
Parameters attached. I'll do a video on the procedures in a few days. The lower the inductance the more particular the setup. Happy new year
- params_ansaldo_e39_best_30_12.zip
- (618 Bytes) Downloaded 368 times
