In one housing inverter and motor capacity of 160 kilowatts
yaroslav
Has thanked: 14 times
Post by yaroslav »
Нi. There is a factory inverter with an IPM engine with a capacity of 160 kilowatts. Everything is built into one housing, which is convenient for installation in a car. My friend asked me for help with starting the inverter, it works through the can bus. There is a document with can messages, someone will be interested with its launch?
LOCAL_INV_DBC(1).xlsx
(70.93 KiB) Downloaded 120 times
catphish
Has thanked: 96 times
Been thanked: 188 times
Re: In one housing inverter and motor capacity of 160 kilowatts
Post by catphish »
Drive units like this are great. For DIY'ers, salvage Tesla drive units usually provide more power for a much lower cost, but if I were embarking on a commercial design, I would definitely try to source a drive unit like this.
You may also want co check out https://webshop.swindonpowertrain.com/i ... y&path=115
That's the only other similar unit I was able to find.
