Power steering cooler
FFMan
Has thanked: 8 times
Been thanked: 47 times
Post by FFMan »
My BMW has a simple loop of pipe in front of the radiator that the power steering fluids runs through as a simple cooler.
For a road car running in the UK is his necessary. The pipes are in the way, and i wonder whether i bother to relocate the cooler or delete it ?
I'm using a zafira electric PS pump in my convernsion.
E46 touring
BMW 9kwh & 12kwh packs
Boxster EV
Has thanked: 57 times
Been thanked: 48 times
Re: Power steering cooler
Post by Boxster EV »
I think you’ll be okay to delete it. I’m using a TRW pump and don’t have a cooler.
Has thanked: 134 times
Been thanked: 335 times
Boxster EV wrote: Sun Feb 26, 2023 8:23 pm I think you’ll be okay to delete it. I’m using a TRW pump and don’t have a cooler.
Well i use TRW pump as well and it doesnt heat up. I think it is because it has its own oil reservoir where heat can be dissipated and engine which is a big heat source is not there.
