My BMW has a simple loop of pipe in front of the radiator that the power steering fluids runs through as a simple cooler.
For a road car running in the UK is his necessary. The pipes are in the way, and i wonder whether i bother to relocate the cooler or delete it ?
I'm using a zafira electric PS pump in my convernsion.
Power steering cooler
- Has thanked: 8 times
- Been thanked: 47 times
E46 touring
BMW 9kwh & 12kwh packs
- Boxster EV
- Has thanked: 39 times
- Been thanked: 30 times
Re: Power steering cooler
I think you’ll be okay to delete it. I’m using a TRW pump and don’t have a cooler.
- Has thanked: 81 times
- Been thanked: 241 times
Well i use TRW pump as well and it doesnt heat up. I think it is because it has its own oil reservoir where heat can be dissipated and engine which is a big heat source is not there.Boxster EV wrote: ↑Sun Feb 26, 2023 8:23 pm I think you’ll be okay to delete it. I’m using a TRW pump and don’t have a cooler.
