Free rev3 boards
- Bratitude
- Has thanked: 177 times
- Been thanked: 369 times
Free rev3 boards
Free! Just pay shipping
Bc canada
- Has thanked: 8 times
Re: Free rev3 boards
You didn't! Oh man... what little I've read... sounds like these are what I can use maybe for the Gen 3 inverter-converters I invested in... as well as maybe the one Gen3 CVT as well?
Time to find the BOM and ask you what shipping looks like to the States, i.e. Michigan.
- Bratitude
5$ shipped in a envelope !
I'm still reading into the forums and wiki and trying to find references to using the rev3 boards use with the Prius Gen3 inverter-converter and CVT.
Have you used the rev3 board for the Gen3 Prius by chance?
Looks like the variables parameters may be similar between the different boards and the firmware as well? Is that correct? Most what I read thus far is use for the Gen2 Prius and Leaf appears.
Any references you know would be great. I still need to look at the expense from the BOM, though do you know offhand since appears there are custom boards and parts required for the Gen3 operation that are not noted on the schematic for the rev3 board unless updates were made to include required? Reads like some parts are required for the Gen2 operation and not required for the Gen3 operaion? Am I interpreting correct?
Any parts unobtanium or best use situation by chance you know of?
What's the best way to get one of your boards, unless no one else wants... I'll take two or if you want me to take all I can? Private Message maybe?
- Bratitude
prius inverter has its own board.
they all run the same software.
https://github.com/jsphuebner/inverter-hardware
send me an email info@bratindustries.net
