Ireland | Motor Insurance  [SOLVED]
anthony
Post by anthony »
I was just wondering what sort of hurdles people have faced with insuring diy electric conversions in the the ripoff republic of Ireland?
Issues with type approval, certification, NCT, registration details etc?
Kevin Sharpe
Been thanked: 8 times
Re: Ireland | Motor Insurance
Post by Kevin Sharpe »
anthony wrote: Thu Dec 12, 2019 10:48 am I was just wondering what sort of hurdles people have faced with insuring diy electric conversions in the the ripoff republic of Ireland?
In our experience following this procedure results in a lower insurance bill than when the car had an ICE;
Automotive Engineer Inspection/Report -> VRT change to electric tax class (requires automotive engineers report and limited inspection by tax inspector) -> NCT (requires VRT) -> Insure car :)
It's important to get the automotive engineer involved at an early stage because they focus on safety and will spot things you've missed. Under no circumstances exceed the vehicles published axle weight limits because the vehicle will then require a complete custom car evaluation.
Stephen Darbey
Re: Ireland | Motor Insurance  [SOLVED]
Post by Stephen Darbey »
Hi Kevin.
Very Interesting subject. I have pondered this on many occasions. Very interesting that the Gross kerb weight should not be exceeded.
Stephen
SDev
johnspark
Has thanked: 59 times
Been thanked: 48 times
Post by johnspark »
This is an important post.
fitzroy
Post by fitzroy »
I'm new to all this. I am thinking of converting an old car to electric.
Does anyone have the name of (1) a good Automotive Engineer and (2) an individual in a good insurance broker or in an insurance company who would deal with insurance for the converted electric car?
Many thanks,
Brian
Kevin Sharpe
Kevin Sharpe wrote: Thu Dec 12, 2019 11:08 am Automotive Engineer Inspection/Report -> VRT change to electric tax class (requires automotive engineers report and limited inspection by tax inspector) -> NCT (requires VRT) -> Insure car :)
This statement contains an error... you don't need the "inspection by tax inspector" stage (only required if you're importing the car into Ireland).
Here's the process Damien followed on BEXUS and Grey Goose which are now both taxed as electric vehicles for €120 p/a;
Automotive Engineer Inspection/Report -> VRT change to electric tax class (requires automotive engineers report) -> NCT (requires VRT) -> Insure car 8-)
Kevin Sharpe
fitzroy wrote: Fri Feb 14, 2020 9:55 am Does anyone have the name of (1) a good Automotive Engineer
I'd recommend asking your local NCT centre for the name of an Automotive Engineer who works on insurance assessments. They are accessing the safety and quality of your work, not the electrical systems.
As stated above make sure you are under the published axle weight limits and have not cut into the chassis.
fitzroy wrote: Fri Feb 14, 2020 9:55 am and (2) an individual in a good insurance broker or in an insurance company who would deal with insurance for the converted electric car?
I'm using a national insurance broker and the fact that it's electric drive is not a red flag (lots electric cars on the road). Obviously, the fact it's a modified car is important but if you have the Automotive Engineers report, VRT, and NCT they don't seem to be overly concerned.
fitzroy
Post by fitzroy »
Hi Kevin,
Many thanks for that advice. Could you let me have the name of the insurance broker? That would certainly short-circuit the process; I have already spent too long trying to explain what I'm on about!
Thanks again and best wishes,
Brian
Phill
Post by Phill »
Hi All,
Newby to the forum.
I have been sniffing around the idea of doing an electric car conversion for a while. I also did a good bit of research into an electric motorbike conversation and the solid brick wall that I ran into was insurance.
The discussion on this thread suggests insurance isn't an issue for car conversions. Has anyone tried to do a motorbike conversion and have they been able to insure it? I would have done it last year but I wasn't going to spend a load of time and cash on something I couldn't use at the end of it.
P
marcexec
Has thanked: 760 times
Been thanked: 72 times
Post by marcexec »
Stupid question but could one get the VRT refunded after a completed conversion? It's based on CO2 and NOx emissions...
Getting started guide for Celeron55's iPDM56
My Suzuki RF400 build @ES
Honda IMA & Lebowski howto
