On the system I'm designing the BMS calculates the maximum current that can be drawn from or supplied to the HV battery using cell temp and cell voltage. I'm trying to send this value to the idcmax and idcmin param, but it does not seem to be working. I have tried the wiki description, but I must be missing something.
Does the ZombieVerter allow its parameters to be changed via canbus and if so could someone kindly give me an explanation on how this is done?
Thank you.
ZombieVerter - Setting idcmax / min via Can Bus
- Has thanked: 368 times
- Been thanked: 1541 times
Re: ZombieVerter - Setting idcmax / min via Can Bus
Are you using SDO? The current release of ZombieVerter has an issue with SDO, it won't receive it. Will be fixed soon.
Yep trying to use SDO, thanks for the update, look forward to the update.
Thank you
