MEB Chargers
- Has thanked: 106 times
- Been thanked: 226 times
Re: MEB Chargers
I seen on github Damien has made progress with his code.
I am yet to try this on my own charger to see if the E-Golf charger works the same way as the GTE one Damien has wrote the program for.
- jalovick
- Has thanked: 10 times
- Been thanked: 6 times
Re: MEB Chargers
I believe Damien has progressed fairly well with the xxx915682xx series 3.6 kW chargers. The latest info is on his github and pinouts are listed on the Wiki here.
If you're a Patreon, you can access the Discord, where all the action happens...
Jamie
- Has thanked: 43 times
- Been thanked: 111 times
Re: MEB Chargers
So I have a dumb question that I haven't been able to find the answer too. Figured I would ask it on here in case anyone else had the same thoughts.
What's the point with some of these chargers being two phases? Surely that means most home chargers are going to be limited to the single phase 3.6kW charging, but taking it to a 22kW public charger to use the extra phase is still going to be a bit slow at 7.2kW.
On a further potentially stupid thought. With the two phase chargers, could you parallel the live phase to both phases of the charger? Since it's not three phase both phases should return via the neutral anyway.
Re: MEB Chargers
I have a Cayenne two phase 7.2kW charger. Part number 5QE 915 681 BQ.
Got it responding to 0x570 DLC8 0xFF 0x00 0x00 0x00 0x00 0x00 0x00 on PT CAN at 1 sec intervals. Same as the Seat Mii Damien has, which is probably unsurprising given the part numbers are very similar. I also then get some can data on the PT canbus, log attached. Although I get nothing on my Hybrid can.
- Cayenne PT 570 wake up.csv
- (72.8 KiB) Downloaded 85 times
Re: MEB Chargers
I'm just guessing, but I think it is because those chargers are build to provide also markets with a single phase 32A infrastructure.
You can recode the charger to use one phase with 32A or back to two phases with 16A.
Here is a video about that coding:
Greetinx
marxx
Charging station with Raspberry Pi, own Open Source Software
OVMS Leaf/e-Up, hitch Leaf, GE Android App, SteVe OCPP Raspi Image
http://www.arachnon.de/wb
Renault Twizy Life (owned battery) 06/2016,
VW e-Up! 07/2020.
Tesla Model 3 09/2019, LR AWD,
VW e-Up! 07/2020.
Re: MEB Chargers
Thanks! That look's rather simple to do. I would imagine in that case you would just need to ask for 32amps on the canbus and it will switch automatically. That's very handy!
Re: MEB Chargers
Just picked up a 5QE.915.684.AD charger from a 2021 Audi E-Tron Canadian Model.
Hoping to help out with the Reverse Engineering efforts, or at least prove them on North American variants.
Likely best to document everything here, but I think this thread will fragment into the few various different models, even if they're all 'MEB' type, the implementation seems to differ quite a bit between the MQB and MLBevo models.
The E-Tron chargers have several things which make them a bit different, one major being the LIN LED module and Door actuator, as well as only having a Hybrid CAN connection (No Drive CAN)
The CAN signals appear to be totally different than those for the rest of the charger line.
As per the DBC file I posted, The charger is pretty integrated into the other bus messages, but the messages seem totally different than those found by Damien
**See Next Post for CAN Signal List**
I find the VCDS forums a good source to start at, The VAG Address is C6 and the Module is J1050
https://forums.ross-tech.com/index.php?threads/27373/
This post is interesting as the scan has quite a few Bus errors which re-confirm the some of the required CAN signals the module is looking for:
From this, the Blockmap of available signals are:
- ESP_21 -
- DCDC_01 -
- AWC_01 - Likely not required, Since it's for Wireless Charging
- NavData_02 -
Address C6: Batt. Chrg. (J1050) Labels:* None
Part No SW: 5QE 915 684 AD HW: 5QE 915 684 AD
Component: OBC KOSTAL H34 0070
Serial number: EEEEEEEEEEEEEEE
Coding: 7A59AC6742080E000000
Shop #: WSC 00000 000 00000
ASAM Dataset: EV_OBC3Phase1KLOMLBev16B 004001
ROD: EV_OBC3Phase1KLOMLBev16B.rod
VCID: 116AB0B8C07266035C-8044
Flap 1 for charging socket:
Subsystem 1 - Part No SW: 4KE 862 277 A HW: 4KE 862 277 A
Component: F496LKL1 004 0004
Serial number: 20200704030206080495
Flap 2 for charging socket:
Subsystem 2 - Part No SW: 4KE 862 277 A HW: 4KE 862 277 A
Component: F497LKL2 004 0004
Serial number: 20200527030206080290
12 Faults Found:
2097152 - Battery Management
P33EB 00 [040] - Read Event Memory
Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 1
Reset counter: 8
Mileage: 568 km
Date: 2021.03.20
Time: 14:27:06
1048578 - Internal Control Module Memory Check Sum Error
B2000 00 [109] - -
[error_internal_communication]
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Mileage: 12 km
Date: 2021.01.30
Time: 14:33:34
13705501 - Databus
U1121 00 [040] - Missing Message
[ESP_21_TimeOut]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 39
Reset counter: 39
Mileage: 15 km
Date: 2021.01.30
Time: 14:42:49
13705826 - Control Module for Active Park System
U13AE 00 [040] - Implausible
[error_hold_management_system]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 3
Reset counter: 7
Mileage: 26 km
Date: 2021.03.15
Time: 09:10:54
13705549 - Databus
[DCDC_01_Timeout]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 4
Reset counter: 37
Mileage: 26 km
Date: 2021.03.15
Time: 16:32:14
13705553 - Databus
U1121 00 [109] - Missing Message
[AWC_01_TimeOut]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 40
Mileage: 15 km
Date: 2021.01.30
Time: 14:42:52
3211299 - Unknown Error Code
B1A86 04 [109] - Internal System Fault
[push_button_LKL1_disconnected]
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 40
Mileage: 15 km
Date: 2021.01.30
Time: 14:42:51
3211302 - Unknown Error Code
B1A87 04 [109] - Internal System Fault
[push_button_LKL2_disconnected]
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 40
Mileage: 15 km
Date: 2021.01.30
Time: 14:42:51
14745862 - HV Battery Charging Voltage
P0CA4 00 [104] - Too High
Freeze Frame:
Fault Priority: 2
Fault Frequency: 218
Reset counter: 38
Mileage: 478 km
Date: 2021.03.20
Time: 06:54:30
13706243 - Databus
[NavData_02_TimeOut]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 46
Reset counter: 39
Mileage: 15 km
Date: 2021.01.30
Time: 14:42:55
14746766 - Charging Unit 2
P1A15 00 [109] - Function Restricted
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 40
Mileage: 15 km
Date: 2021.01.30
Time: 14:42:55
13705524 - Databus
U1121 00 [044] - Missing Message
[Motor_12_TimeOut]
Freeze Frame:
Fault Priority: 6
Reset counter: 40
Mileage: 12 km
Date: 2021.01.30
Time: 14:39:39
;SW:5QE-915-684-AD HW:5QE-915-684-AD --- Batt. Chrg.
;Component:OBC KOSTAL H34 0070, Coding:7A59AC6742080E000000
;EV_OBC3Phase1KLOMLBev16B,004001,EV_OBC3Phase1KLOMLBev16B.rod
;Monday,05,April,2021,12:31:42:06940
;VCDS Version: Release 21.3.0 (x64) Data version: 20210318 DS325.0
;VCID: 116AB0B8C07266035C-8044
Group,Description,Actual
IDE00019,Voltage terminal 30,13.0, V
IDE00025-MAS12429,Coolant temperature-Range 1,0,
IDE00025-MAS12430,Coolant temperature-Range 2,0,
IDE00025-MAS12431,Coolant temperature-Range 3,11,
IDE00025-MAS12432,Coolant temperature-Range 4,117,
IDE00025-MAS12433,Coolant temperature-Range 5,36,
IDE00025-MAS12434,Coolant temperature-Range 6,1,
IDE00025-MAS12435,Coolant temperature-Range 7,0,
IDE00025-MAS12436,Coolant temperature-Range 8,0,
IDE00025-MAS12437,Coolant temperature-Range 9,0,
IDE00030,Status of actuator test,not active,
IDE00056-MAS12429,History data 1-Range 1,0,
IDE00056-MAS12430,History data 1-Range 2,0,
IDE00056-MAS12431,History data 1-Range 3,2,
IDE00056-MAS12432,History data 1-Range 4,21,
IDE00056-MAS12433,History data 1-Range 5,82,
IDE00056-MAS12434,History data 1-Range 6,51,
IDE00056-MAS12435,History data 1-Range 7,8,
IDE00056-MAS12436,History data 1-Range 8,0,
IDE00056-MAS12437,History data 1-Range 9,0,
IDE00057-MAS12429,History data 2-Range 1,0,
IDE00057-MAS12430,History data 2-Range 2,0,
IDE00057-MAS12431,History data 2-Range 3,7,
IDE00057-MAS12432,History data 2-Range 4,90,
IDE00057-MAS12433,History data 2-Range 5,61,
IDE00057-MAS12434,History data 2-Range 6,7,
IDE00057-MAS12435,History data 2-Range 7,0,
IDE00057-MAS12436,History data 2-Range 8,0,
IDE00057-MAS12437,History data 2-Range 9,0,
IDE00058-MAS12429,History data 3-Range 1,0,
IDE00058-MAS12430,History data 3-Range 2,0,
IDE00058-MAS12431,History data 3-Range 3,6,
IDE00058-MAS12432,History data 3-Range 4,97,
IDE00058-MAS12433,History data 3-Range 5,55,
IDE00058-MAS12434,History data 3-Range 6,7,
IDE00058-MAS12435,History data 3-Range 7,0,
IDE00058-MAS12436,History data 3-Range 8,0,
IDE00058-MAS12437,History data 3-Range 9,0,
IDE00059-MAS12429,History data 4-Range 1,0,
IDE00059-MAS12430,History data 4-Range 2,0,
IDE00059-MAS12431,History data 4-Range 3,0,
IDE00059-MAS12432,History data 4-Range 4,0,
IDE00059-MAS12433,History data 4-Range 5,0,
IDE00059-MAS12434,History data 4-Range 6,0,
IDE00059-MAS12435,History data 4-Range 7,0,
IDE00059-MAS12436,History data 4-Range 8,0,
IDE00059-MAS12437,History data 4-Range 9,0,
IDE00060-MAS12429,History data 5-Range 1,0,
IDE00060-MAS12430,History data 5-Range 2,0,
IDE00060-MAS12431,History data 5-Range 3,17,
IDE00060-MAS12432,History data 5-Range 4,93,
IDE00060-MAS12433,History data 5-Range 5,52,
IDE00060-MAS12434,History data 5-Range 6,4,
IDE00060-MAS12435,History data 5-Range 7,0,
IDE00060-MAS12436,History data 5-Range 8,0,
IDE00060-MAS12437,History data 5-Range 9,0,
IDE00061-MAS12429,History data 6-Range 1,0,
IDE00061-MAS12430,History data 6-Range 2,0,
IDE00061-MAS12431,History data 6-Range 3,10,
IDE00061-MAS12432,History data 6-Range 4,96,
IDE00061-MAS12433,History data 6-Range 5,54,
IDE00061-MAS12434,History data 6-Range 6,6,
IDE00061-MAS12435,History data 6-Range 7,0,
IDE00061-MAS12436,History data 6-Range 8,0,
IDE00061-MAS12437,History data 6-Range 9,0,
IDE00322,Status of basic setting,was not yet started,
IDE00323,Security Access: Number of invalid keys,0,
IDE00637,DC link voltage,0.9, A
IDE00637,DC link voltage,0.7, A
IDE00767,No. of unscheduled ECU resets,00,
IDE01985-MAS01159,FAZIT identification test sum-Version number,81,
IDE01985-MAS06879,FAZIT identification test sum-Checksum,CB 08 20 A6,
IDE02486,Data logger triggering,not initialized,
IDE06805,Status of voltage freedom,High voltage power off not recognized,
IDE06954,Actual HV charge current,80 00,
IDE06955-ENG114223,Target HV charge current-Charger_HV_current_commanded_value,-102.0, A
IDE07145-ENG119926,Component protection properties-KS_Data_Generation,2,
IDE07145-ENG119382,Component protection properties-KS_data_version,0,
IDE07145-ENG119680,Component protection properties-KS_Standard_Software_Major_Version,1,
IDE07145-ENG119410,Component protection properties-KS_Standard_Software_Minor_Version,3,
IDE07145-ENG119983,Component protection properties-KS_Standard_Software_Patch_Version,5,
IDE07145-ENG119813,Component protection properties-KSB_Configuration_Status_1,01,
IDE07145-ENG119724,Component protection properties-KSB_Configuration_Status_2,5E,
IDE07159-ENG30068,Control module switch-off: counter-raw_value_in_develop_by_ODXauthor,00 00,
IDE07160-ENG119373,Control module switch-off: switch-off time-Control module,15, min
IDE07160-ENG119372,Control module switch-off: switch-off time-Data bus,15, min
IDE08097-MAS12429,serv.life charge current-Range 1,6297,
IDE08097-MAS12430,serv.life charge current-Range 2,0,
IDE08097-MAS12431,serv.life charge current-Range 3,3727,
IDE08097-MAS12432,serv.life charge current-Range 4,12,
IDE08097-MAS12433,serv.life charge current-Range 5,4,
IDE08097-MAS12434,serv.life charge current-Range 6,0,
IDE08097-MAS12435,serv.life charge current-Range 7,0,
IDE08097-MAS12436,serv.life charge current-Range 8,0,
IDE08421-IDE05431,Power outlet A for battery charging-Lock for high-voltage charging connector,not locked,
IDE08421-MAS07220,Power outlet A for battery charging-Status connect. recognition,not installed,
IDE08421-MAS07221,Power outlet A for battery charging-Connector locking requirement,00000000 ,
IDE08421-MAS07222,Power outlet A for battery charging-Connector unlocking requirement,00000000 ,
IDE08421-MAS07223,Power outlet A for battery charging-Max. current of charge connector,0, A
IDE08421-MAS07565,Power outlet A for battery charging-Activation charge cover lock charge socket A,not requested,
IDE08421-MAS07567,Power outlet A for battery charging-Status charge cover lock charge socket A,not locked,
IDE08421-MAS10983,Power outlet A for battery charging-Activation charge cover unlock charge socket A,unlock,
IDE08421-MAS12565,Power outlet A for battery charging-Charge socket temperature sensor AC,-54.8, °C
IDE08421-MAS12566,Power outlet A for battery charging-Charge sensor temperature sensor DC,6037.8, °C
IDE08422-IDE05431,Power outlet B for battery charging-Lock for high-voltage charging connector,not locked,
IDE08422-MAS07220,Power outlet B for battery charging-Status connect. recognition,not installed,
IDE08422-MAS07221,Power outlet B for battery charging-Connector locking requirement,00000000 ,
IDE08422-MAS07222,Power outlet B for battery charging-Connector unlocking requirement,00000000 ,
IDE08422-MAS07223,Power outlet B for battery charging-Max. current of charge connector,0, A
IDE08422-MAS07224,Power outlet B for battery charging-Temp. of charge socket,-54.8, °C
IDE08422-MAS07566,Power outlet B for battery charging-Activation charge cover lock charge socket B,not requested,
IDE08422-MAS07568,Power outlet B for battery charging-Status: chg. cover lock. device: chg. socket B,not locked,
IDE08423-MAS02949,Control signal for power outlet A for battery charging-Frequency,0, Hz
IDE08423-MAS02952,Control signal for power outlet A for battery charging-Control voltage,0, mV
IDE08423-MAS03873,Control signal for power outlet A for battery charging-Duty cycle,0.0, %
IDE08423-MAS04136,Control signal for power outlet A for battery charging-Current,0.0, A
IDE08423-MAS07262,Control signal for power outlet A for battery charging-Signal recognized,00000000 ,
IDE08424-MAS02949,Control signal for power outlet B for battery charging-Frequency,0, Hz
IDE08424-MAS02952,Control signal for power outlet B for battery charging-Control voltage,0, mV
IDE08424-MAS03873,Control signal for power outlet B for battery charging-Duty cycle,0.0, %
IDE08424-MAS04136,Control signal for power outlet B for battery charging-Current,0.0, A
IDE08424-MAS07262,Control signal for power outlet B for battery charging-Signal recognized,00000000 ,
IDE08425-MAS07225,Indicator lamps for socket A for battery charging-Status: indicator lamp 1,OFF,
IDE08425-MAS07226,Indicator lamps for socket A for battery charging-Status: indicator lamp 2,OFF,
IDE08425-MAS07227,Indicator lamps for socket A for battery charging-Status: indicator lamp 3,OFF,
IDE08425-MAS07228,Indicator lamps for socket A for battery charging-Intensity: indicator light 1,0, %
IDE08425-MAS07229,Indicator lamps for socket A for battery charging-Intensity: indicator light 2,0, %
IDE08425-MAS07230,Indicator lamps for socket A for battery charging-Intensity: indicator light 3,0, %
IDE08425-MAS07231,Indicator lamps for socket A for battery charging-Period duration: indicator light 1,0, ms
IDE08425-MAS07232,Indicator lamps for socket A for battery charging-Period duration: indicator light 2,0, ms
IDE08425-MAS07233,Indicator lamps for socket A for battery charging-Period duration: indicator light 3,0, ms
IDE08425-MAS07582,Indicator lamps for socket A for battery charging-Intensity: activation 4,0, %
IDE08425-MAS07590,Indicator lamps for socket A for battery charging-Period duration: activation 4,0, ms
IDE08425-MAS13012,Indicator lamps for socket A for battery charging-Status: indicator lamp 4,OFF,
IDE08426-MAS07225,Indicator lamps for power outlet B for battery charging-Status: indicator lamp 1,OFF,
IDE08426-MAS07226,Indicator lamps for power outlet B for battery charging-Status: indicator lamp 2,OFF,
IDE08426-MAS07227,Indicator lamps for power outlet B for battery charging-Status: indicator lamp 3,OFF,
IDE08426-MAS07228,Indicator lamps for power outlet B for battery charging-Intensity: indicator light 1,0, %
IDE08426-MAS07229,Indicator lamps for power outlet B for battery charging-Intensity: indicator light 2,0, %
IDE08426-MAS07230,Indicator lamps for power outlet B for battery charging-Intensity: indicator light 3,0, %
IDE08426-MAS07231,Indicator lamps for power outlet B for battery charging-Period duration: indicator light 1,0, ms
IDE08426-MAS07232,Indicator lamps for power outlet B for battery charging-Period duration: indicator light 2,0, ms
IDE08426-MAS07233,Indicator lamps for power outlet B for battery charging-Period duration: indicator light 3,0, ms
IDE08426-MAS07582,Indicator lamps for power outlet B for battery charging-Intensity: activation 4,0, %
IDE08426-MAS07590,Indicator lamps for power outlet B for battery charging-Period duration: activation 4,0, ms
IDE08426-MAS13012,Indicator lamps for power outlet B for battery charging-Status: indicator lamp 4,OFF,
IDE08427-MAS07237,Statistics of power outlet A for battery charging-No. of connections,0,
IDE08427-MAS07238,Statistics of power outlet A for battery charging-No. of lockings,0,
IDE08428-MAS07237,Statistics of power outlet B for battery charging-No. of connections,0,
IDE08428-MAS07238,Statistics of power outlet B for battery charging-No. of lockings,0,
IDE08430,Cause of cancellation of charge procedure,not active,
IDE08639,max. loading power,0, W
IDE08640,Spec. mode: load mgmnt.,Standby,
IDE08649-IDE06971,Ready to charge-Operational readiness in H-V system,not active,
IDE08649-MAS07215,Ready to charge-Status charge readiness charge mngmt.,Unknown (0),
IDE08649-MAS15304,Ready to charge-Status drive readiness,not ready to drive,
IDE08677-MAS07258,Load mode-Stat.: charge mode,no request,
IDE08677-MAS07259,Load mode-Chg. type,Imm. charg.,
IDE08717,Status mains voltage,not installed,
IDE08718-MAS06699,Chademo version-Vehicle,2,
IDE08718-MAS07395,Chademo version-Charging Station,0,
IDE08719-IDE08720,Values from battery mgmt system-Current condition of battery mgmt. system,HV mains activ.,
IDE08719-MAS01420,Values from battery mgmt system-Limit for charge current,589.0, A
IDE08719-MAS04059,Values from battery mgmt system-Battery temperature,21.0, °C
IDE08719-MAS07397,Values from battery mgmt system-Act. current HV battery,-0.8, W
IDE08719-ENG119994,Values from battery mgmt system-bms_energy,57750, Wh
IDE08719-ENG119383,Values from battery mgmt system-Highvoltage_battery_state_of_charge,67.85, %
IDE08752,Stop management system,Park function active,
IDE08938,Chrgr cooling reqrmnt,Med. cooling reqmnt.,
IDE09039,HV charger - current output voltage,419, V
IDE09057,HV battery charge state,67.5, %
IDE10187-ENG119392,Supply voltage [V]-3_3V_supply_voltage,3.30, V
IDE11752-IDE09469,IP network: IPv6-addresses-IPv6 address,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE11753-MAS14855,IP network: IPv6-multicast-addresses-IPv6 Multicast address,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE11757,IP network: counter messages with inadmissible IPv6-addresses,0,
IDE11761-IDE09467,IP network: MAC addresses-MAC address,F0 7F 0C 0B 3C 04,
IDE12027,Active Security Access procedure,PIN_Minicode,
IDE12238,I network: discarded messages counter,0,
IDE12625,IP network: current link deceleration: branch 1,0, ns
IDE13628-MAS12429,HV charging voltage: current value-Range 1,131, H
IDE13628-MAS12430,HV charging voltage: current value-Range 2,2562, H
IDE13628-MAS12431,HV charging voltage: current value-Range 3,6983, H
IDE13628-MAS12432,HV charging voltage: current value-Range 4,257, H
IDE13628-MAS12433,HV charging voltage: current value-Range 5,0, H
IDE13628-MAS12434,HV charging voltage: current value-Range 6,0, H
IDE13628-MAS12435,HV charging voltage: current value-Range 7,0, H
IDE13628-MAS12436,HV charging voltage: current value-Range 8,0, H
IDE13628-MAS12437,HV charging voltage: current value-Range 9,0, H
IDE13628-MAS12438,HV charging voltage: current value-Range 10,0, H
IDE13628-MAS12439,HV charging voltage: current value-Range 11,0, H
IDE13628-MAS12440,HV charging voltage: current value-Range 12,0, H
IDE13806,Specified mode: contactless charging,not_active,
IDE14287-ENG120029,Connector lock loading hatch 1: voltage values-actual_voltage_plug_interlock_a,2218, mV
IDE14287-ENG119976,Connector lock loading hatch 1: voltage values-Max_limit_voltage_plug_interlock_locked_a,12194, mV
IDE14287-ENG119859,Connector lock loading hatch 1: voltage values-Max_limit_voltage_plug_interlock_not_locked_a,4574, mV
IDE14287-ENG119710,Connector lock loading hatch 1: voltage values-min_limit_voltage_plug_interlock_locked_a,6672, mV
IDE14287-ENG119579,Connector lock loading hatch 1: voltage values-min_limit_voltage_plug_interlock_not_locked_a,1655, mV
IDE14305,Plug and Charge service 3,00 00 00 05 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 06 DF E8 1C 8E 86 7A AB B4 99 05 38 40 CE C6 ED 58 6B E3 35 72 D3 50 C2 6C 94 05 04 30 62 23 3E E1 D2 A4 36 2F 6A 47 23 E8 D2 21 37 58 A0 00 30 0A 06 08 2A 86 48 CE 3D 04 03 02 03 48 00 30 45 02 20 46 B9 E3 DA 69 19 8D C8 80 E4 2C 11 53 EC 70 4F 82 89 4D E4 EC FE 3F 9B AC 45 44 D8 33 AB F7 CB 02 21 00 DE EF A1 CE B8 6D 47 B7 63 D4 9D 96 DE B8 88 3B 50 7A A5 1C FF DE 5D 69 69 D1 E5 5C D9 42 57 71 00 00 0A 30 30 30 30 30 30 30 30 30 31 00 17 4B 4F 31 2D 41 42 59 31 36 2E 31 31 2E 32 30 54 49 47 32 37 36 36 30 00 00 00 00 00 00 00 00 10 C2 D5 D1 30 BB 8F 34 EA 8C 0B 15 E7 CE 83 6D FA 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 81 94 06 45 B8 10 1B 79 EA D0 50 D1 CA 1B 66 DE 00 00 00 01 30 81 EC 30 81 93 02 01 00 30 31 31 0B 30 09 06 03 55 04 06 13 02 44 45 31 0D 30 0B 06 03 55 04 0A 0C 04 56 57 41 47 31 13 30 11 06 0A 09 92 26 89 93 F2 2C 64 01 19 16 03 4F 45 4D 30 59 30 13 06 07 2A 86 48 CE 3D 02 01 06 08 2A 86 48 CE 3D 03 01 07 03 42 00 04 E8 F2 54 F8 1D 8E 1F 87 40 35 0A 2E 6B 58 F0 EE EB 5A 40 06 DF E8 1C 8E 86 7A AB B4 99 05 38 40 CE C6 ED 58 6B E3 35 72 D3 50 C2 6C 94 05 04 30 62 23 3E E1 D2 A4 36 2F 6A 47 23 E8 D2 21 37 58 A0 00 30 0A 06 08 2A 86 48 CE 3D 04 03 02 03 48 00 30 45 02,
IDE14315,Plug and Charge service 13,00 00 00 05 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE14316,Plug and Charge service 14,00 00 00 05 00 00 00 00 00 00 00 00,
IDE14317,Plug and Charge service 15,00 00 00 05 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE14318,Plug and Charge service 16,00 00 00 05 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE14324-ENG119646,Connector lock loading hatch 2: voltage values-actual_voltage_plug_interlock_b,2218, mV
IDE14324-ENG119783,Connector lock loading hatch 2: voltage values-Max_limit_voltage_plug_interlock_locked_b,12193, mV
IDE14324-ENG119618,Connector lock loading hatch 2: voltage values-Max_limit_voltage_plug_interlock_not_locked_b,4574, mV
IDE14324-ENG119604,Connector lock loading hatch 2: voltage values-min_limit_voltage_plug_interlock_locked_b,6672, mV
IDE14324-ENG119506,Connector lock loading hatch 2: voltage values-min_limit_voltage_plug_interlock_not_locked_b,1655, mV
MAS00464-MAS00106,Standard - ambient data 1-Year,2021,
MAS00464-MAS00107,Standard - ambient data 1-Month,4,
MAS00464-MAS00108,Standard - ambient data 1-Day,5,
MAS00464-MAS00109,Standard - ambient data 1-Hours,12,
MAS00464-MAS00110,Standard - ambient data 1-Minutes,31,
MAS00464-MAS00111,Standard - ambient data 1-Seconds,56,
MAS00464-MAS00468,Standard - ambient data 1-Unlearning counter,33,
MAS00464-MAS00711,Standard - ambient data 1-Odometer reading,1463, km
MAS01118-MAS01904,Air Conditioning-Direct,0,
MAS01118-MAS14087,Air Conditioning-time delay activation,0,
MAS07396-ENG30068,Act. voltage HV battery-raw_value_in_develop_by_ODXauthor,06 81,
MAS07407-ENG30068,Max. battery charging voltage-raw_value_in_develop_by_ODXauthor,01 CB,
MAS07558,Spec. charger operating condition,Standby,
MAS07559,Act. charger operating condition,Standby,
MAS07564,Function limitation charging due to temp. charge unit,not active,
MAS08227-ENG119391,Quick charge: SOC upper limit-target_soc,50, %
MAS09777-MAS12429,Target current-Range 1,6296,
MAS09777-MAS12430,Target current-Range 2,0,
MAS09777-MAS12431,Target current-Range 3,3728,
MAS09777-MAS12432,Target current-Range 4,8,
MAS09777-MAS12433,Target current-Range 5,8,
MAS09777-MAS12434,Target current-Range 6,0,
MAS09777-MAS12435,Target current-Range 7,0,
MAS09777-MAS12436,Target current-Range 8,0,
MAS11301-ENG119564,Timer-History_Counter_Timer_Overruled,0,
MAS11301-ENG119480,Timer-History_Counter_Timer_Started_Charging,0,
MAS12397-ENG30068,Number of lockings: charge cover A-raw_value_in_develop_by_ODXauthor,00 00,
MAS12833-MAS12839,Chrg. unit working mode-Chrg. mod. 1,not active,
MAS12833-MAS12840,Chrg. unit working mode-Chrg. mod. 2,not active,
MAS12833-MAS12890,Chrg. unit working mode-Chrg. mod. 3,not active,
MAS13037-MAS12839,AC-network current: actual value per module-Chrg. mod. 1,0.0, A
MAS13037-MAS12840,AC-network current: actual value per module-Chrg. mod. 2,0.0, A
MAS13037-MAS12890,AC-network current: actual value per module-Chrg. mod. 3,0.0, A
MAS13038-MAS03084,AC-network voltage: actual value per phase-Phase 1,0, V
MAS13038-MAS03085,AC-network voltage: actual value per phase-Phase 2,0, V
MAS13038-MAS03086,AC-network voltage: actual value per phase-Phase 3,0, V
MAS13039-MAS12839,DC-output voltage: actual value per module-Chrg. mod. 1,419, V
MAS13039-MAS12840,DC-output voltage: actual value per module-Chrg. mod. 2,419, V
MAS13039-MAS12890,DC-output voltage: actual value per module-Chrg. mod. 3,419, V
MAS13040-MAS12839,DC-output current: actual value per module-Chrg. mod. 1,0.0, A
MAS13040-MAS12840,DC-output current: actual value per module-Chrg. mod. 2,0.0, A
MAS13040-MAS12890,DC-output current: actual value per module-Chrg. mod. 3,0.0, A
MAS16729,Efficiency ratio correction-current detector rail 1,-0.0, A
MAS16730,Efficiency ratio correction-current detector rail2,-0.0, A
MAS16731,Efficiency ratio correction-current detector rail 3,-0.0, A
MAS16732,Temperature sensor signal electronics,43, °C
MAS16733,Efficiency ratio correction temperature sensor 1,33, °C
MAS16734,Efficiency ratio correction temperature sensor 2,33, °C
MAS16735,Efficiency ratio correction temperature sensor 3,33, °C
MAS16736,DCDC temperature sensor 1,31, °C
MAS16737,DCDC temperature sensor 2,30, °C
MAS16738,Gate-driver voltage,Initialization,
MAS16739,Supply voltage efficiency ratio correction,6.4, V
MAS16739,Supply voltage efficiency ratio correction,6.6, V
MAS16740,Supply voltage DCDC,6.8, V
MAS16742-MAS00106,BAP alarm time-Year,208,
MAS16742-MAS00107,BAP alarm time-Month,1,
MAS16742-MAS00108,BAP alarm time-Day,1,
MAS16742-MAS00109,BAP alarm time-Hours,0,
MAS16742-MAS00110,BAP alarm time-Minutes,0,
MAS17247-ENG119447,Charge duration-History_Charging_Duration_Rail_1,7792, H
MAS17247-ENG119727,Charge duration-History_Charging_Duration_Rail_2,3677, H
MAS17247-ENG119578,Charge duration-History_Charging_Duration_Rail_3,3744, H
MAS18194-ENG119423,Voltage and temperature charging sockets-actual_temperature_sensor_ac_combo_socket,20.0, °C
MAS18194-ENG119746,Voltage and temperature charging sockets-actual_temperature_sensor_ac_socket,20.0, °C
MAS18194-ENG119969,Voltage and temperature charging sockets-actual_temperature_sensor_dcminus_combo_socket,36.2, °C
MAS18194-ENG120020,Voltage and temperature charging sockets-actual_temperature_sensor_dcplus_combo_socket,34.3, °C
MAS18194-ENG120052,Voltage and temperature charging sockets-actual_voltage_temp_sensor_ac_combo_socket,1601, mV
MAS18194-ENG119640,Voltage and temperature charging sockets-actual_voltage_temp_sensor_ac_socket,1967, mV
MAS18194-ENG119643,Voltage and temperature charging sockets-actual_voltage_temp_sensor_dcminus_combo_socket,2519, mV
MAS18194-ENG119616,Voltage and temperature charging sockets-actual_voltage_temp_sensor_dcplus_combo_socket,2465, mV
MAS18236,Number of charge processes DC (400V),2,
MAS18237,Number of charge processes DC (800V booster),0,
MAS18238,Number of charge processes DC (400V booster),0,
MAS18239,Number of charging processes: inductive,0,
MAS18241,Number of charging processes: AC,33,
MAS18263-MAS12429,AC charging socket temperature-Range 1,0,
MAS18263-MAS12430,AC charging socket temperature-Range 2,0,
MAS18263-MAS12431,AC charging socket temperature-Range 3,10,
MAS18263-MAS12432,AC charging socket temperature-Range 4,157,
MAS18263-MAS12433,AC charging socket temperature-Range 5,0,
MAS18263-MAS12434,AC charging socket temperature-Range 6,0,
MAS18263-MAS12435,AC charging socket temperature-Range 7,0,
MAS18263-MAS12436,AC charging socket temperature-Range 8,0,
MAS18263-MAS12437,AC charging socket temperature-Range 9,0,
MAS18264-MAS12429,DC charging socket temperature (sensor 1)-Range 1,0,
MAS18264-MAS12430,DC charging socket temperature (sensor 1)-Range 2,0,
MAS18264-MAS12431,DC charging socket temperature (sensor 1)-Range 3,77,
MAS18264-MAS12432,DC charging socket temperature (sensor 1)-Range 4,89,
MAS18264-MAS12433,DC charging socket temperature (sensor 1)-Range 5,0,
MAS18264-MAS12434,DC charging socket temperature (sensor 1)-Range 6,0,
MAS18264-MAS12435,DC charging socket temperature (sensor 1)-Range 7,0,
MAS18264-MAS12436,DC charging socket temperature (sensor 1)-Range 8,0,
MAS18264-MAS12437,DC charging socket temperature (sensor 1)-Range 9,0,
MAS18265-MAS12429,DC charging socket temperature (sensor 2)-Range 1,0,
MAS18265-MAS12430,DC charging socket temperature (sensor 2)-Range 2,0,
MAS18265-MAS12431,DC charging socket temperature (sensor 2)-Range 3,60,
MAS18265-MAS12432,DC charging socket temperature (sensor 2)-Range 4,106,
MAS18265-MAS12433,DC charging socket temperature (sensor 2)-Range 5,0,
MAS18265-MAS12434,DC charging socket temperature (sensor 2)-Range 6,0,
MAS18265-MAS12435,DC charging socket temperature (sensor 2)-Range 7,0,
MAS18265-MAS12436,DC charging socket temperature (sensor 2)-Range 8,0,
MAS18265-MAS12437,DC charging socket temperature (sensor 2)-Range 9,0,
MAS18266-MAS12429,DC charging socket temperature (sensor 3)-Range 1,0,
MAS18266-MAS12430,DC charging socket temperature (sensor 3)-Range 2,0,
MAS18266-MAS12431,DC charging socket temperature (sensor 3)-Range 3,167,
MAS18266-MAS12432,DC charging socket temperature (sensor 3)-Range 4,0,
MAS18266-MAS12433,DC charging socket temperature (sensor 3)-Range 5,0,
MAS18266-MAS12434,DC charging socket temperature (sensor 3)-Range 6,0,
MAS18266-MAS12435,DC charging socket temperature (sensor 3)-Range 7,0,
MAS18266-MAS12436,DC charging socket temperature (sensor 3)-Range 8,0,
MAS18266-MAS12437,DC charging socket temperature (sensor 3)-Range 9,0,
MAS19448,Vehicle internal status,no_error,
MAS19449,Communication flow powerline request (HLC),not requested,
MAS19450,Communication norm (SCC),none,
MAS19452,Charging condition high-voltage charge manager,not requested,
MAS19453,Powerline request (HLC),No communication,
MAS19454,Requirement - charging station measured voltage,not requested,
MAS19455,Battery conditioning requirement,not requested,
MAS19456,Charging option - inductive charging in infrastructure,not requested,
MAS19457,Number of DC charging charges (HVLM),2,
MAS19458-ENG119394,DC plug status for China variant-status_dc_china_connector,connected,
MAS19459-ENG119638,Plug and Charge Status-activation_status_pnc,not active,
MAS19459-ENG119946,Plug and Charge Status-implementation_status_pnc,not active,
MAS19461-ENG119403,Number of traction current agreements-counter_pnc_number_supported_contract_chains,0,
MAS19461-ENG119517,Number of traction current agreements-counter_pnc_number_supported_po_root_certificates,3,
MAS19461-ENG119421,Number of traction current agreements-counter_pnc_number_supported_v2g_roots,1,
MAS19463-ENG119393,Average damping value (SLAC)-average_attenuation_slac,0, dB
MAS19464-ENG119425,Damping values (SLAC)-attenuation_slac_1,0, dB
MAS19464-ENG119659,Damping values (SLAC)-attenuation_slac_10,0, dB
MAS19464-ENG119996,Damping values (SLAC)-attenuation_slac_11,0, dB
MAS19464-ENG119928,Damping values (SLAC)-attenuation_slac_12,0, dB
MAS19464-ENG119619,Damping values (SLAC)-attenuation_slac_13,0, dB
MAS19464-ENG119450,Damping values (SLAC)-attenuation_slac_14,0, dB
MAS19464-ENG120086,Damping values (SLAC)-attenuation_slac_15,0, dB
MAS19464-ENG120069,Damping values (SLAC)-attenuation_slac_16,0, dB
MAS19464-ENG119629,Damping values (SLAC)-attenuation_slac_17,0, dB
MAS19464-ENG119476,Damping values (SLAC)-attenuation_slac_18,0, dB
MAS19464-ENG119436,Damping values (SLAC)-attenuation_slac_19,0, dB
MAS19464-ENG119967,Damping values (SLAC)-attenuation_slac_2,0, dB
MAS19464-ENG119689,Damping values (SLAC)-attenuation_slac_20,0, dB
MAS19464-ENG119728,Damping values (SLAC)-attenuation_slac_21,0, dB
MAS19464-ENG119484,Damping values (SLAC)-attenuation_slac_22,0, dB
MAS19464-ENG119891,Damping values (SLAC)-attenuation_slac_23,0, dB
MAS19464-ENG120019,Damping values (SLAC)-attenuation_slac_24,0, dB
MAS19464-ENG119874,Damping values (SLAC)-attenuation_slac_25,0, dB
MAS19464-ENG120013,Damping values (SLAC)-attenuation_slac_26,0, dB
MAS19464-ENG120080,Damping values (SLAC)-attenuation_slac_27,0, dB
MAS19464-ENG119972,Damping values (SLAC)-attenuation_slac_28,0, dB
MAS19464-ENG119612,Damping values (SLAC)-attenuation_slac_29,0, dB
MAS19464-ENG120007,Damping values (SLAC)-attenuation_slac_3,0, dB
MAS19464-ENG119788,Damping values (SLAC)-attenuation_slac_30,0, dB
MAS19464-ENG119945,Damping values (SLAC)-attenuation_slac_31,0, dB
MAS19464-ENG120043,Damping values (SLAC)-attenuation_slac_32,0, dB
MAS19464-ENG120079,Damping values (SLAC)-attenuation_slac_33,0, dB
MAS19464-ENG119922,Damping values (SLAC)-attenuation_slac_34,0, dB
MAS19464-ENG119417,Damping values (SLAC)-attenuation_slac_35,0, dB
MAS19464-ENG119452,Damping values (SLAC)-attenuation_slac_36,0, dB
MAS19464-ENG119726,Damping values (SLAC)-attenuation_slac_37,0, dB
MAS19464-ENG119527,Damping values (SLAC)-attenuation_slac_38,0, dB
MAS19464-ENG119683,Damping values (SLAC)-attenuation_slac_39,0, dB
MAS19464-ENG120073,Damping values (SLAC)-attenuation_slac_4,0, dB
MAS19464-ENG119582,Damping values (SLAC)-attenuation_slac_40,0, dB
MAS19464-ENG119663,Damping values (SLAC)-attenuation_slac_41,0, dB
MAS19464-ENG120041,Damping values (SLAC)-attenuation_slac_42,0, dB
MAS19464-ENG119883,Damping values (SLAC)-attenuation_slac_43,0, dB
MAS19464-ENG119852,Damping values (SLAC)-attenuation_slac_44,0, dB
MAS19464-ENG119611,Damping values (SLAC)-attenuation_slac_45,0, dB
MAS19464-ENG119935,Damping values (SLAC)-attenuation_slac_46,0, dB
MAS19464-ENG119960,Damping values (SLAC)-attenuation_slac_47,0, dB
MAS19464-ENG119457,Damping values (SLAC)-attenuation_slac_48,0, dB
MAS19464-ENG119828,Damping values (SLAC)-attenuation_slac_49,0, dB
MAS19464-ENG119913,Damping values (SLAC)-attenuation_slac_5,0, dB
MAS19464-ENG119896,Damping values (SLAC)-attenuation_slac_50,0, dB
MAS19464-ENG120037,Damping values (SLAC)-attenuation_slac_51,0, dB
MAS19464-ENG120025,Damping values (SLAC)-attenuation_slac_52,0, dB
MAS19464-ENG119664,Damping values (SLAC)-attenuation_slac_53,0, dB
MAS19464-ENG119924,Damping values (SLAC)-attenuation_slac_54,0, dB
MAS19464-ENG119514,Damping values (SLAC)-attenuation_slac_55,0, dB
MAS19464-ENG119534,Damping values (SLAC)-attenuation_slac_56,0, dB
MAS19464-ENG119903,Damping values (SLAC)-attenuation_slac_57,0, dB
MAS19464-ENG119566,Damping values (SLAC)-attenuation_slac_58,0, dB
MAS19464-ENG119739,Damping values (SLAC)-attenuation_slac_6,0, dB
MAS19464-ENG119700,Damping values (SLAC)-attenuation_slac_7,0, dB
MAS19464-ENG119781,Damping values (SLAC)-attenuation_slac_8,0, dB
MAS19464-ENG119815,Damping values (SLAC)-attenuation_slac_9,0, dB
MAS19465-MAS00106,Loading procedure successful-Year,2021,
MAS19465-MAS00107,Loading procedure successful-Month,4,
MAS19465-MAS00108,Loading procedure successful-Day,5,
MAS19465-MAS00108,Loading procedure successful-Day,4,
MAS19465-MAS00109,Loading procedure successful-Hours,19,
MAS19465-MAS00109,Loading procedure successful-Hours,7,
MAS19465-MAS00110,Loading procedure successful-Minutes,18,
MAS19465-MAS00110,Loading procedure successful-Minutes,24,
MAS19465-MAS02949,Loading procedure successful-Frequency,1001, Hz
MAS19465-MAS02949,Loading procedure successful-Frequency,1000, Hz
MAS19465-MAS02952,Loading procedure successful-Control voltage,9021, mV
MAS19465-MAS02952,Loading procedure successful-Control voltage,6021, mV
MAS19465-MAS03873,Loading procedure successful-Duty cycle,40.0, %
MAS19465-ENG119447,Loading procedure successful-History_Charging_Duration_Rail_1,0, s
MAS19465-ENG119727,Loading procedure successful-History_Charging_Duration_Rail_2,0, s
MAS19465-ENG119578,Loading procedure successful-History_Charging_Duration_Rail_3,0, s
MAS19465-ENG119985,Loading procedure successful-History_Charging_Process_Charger_Temperature_Start_Charging,38, °C
MAS19465-ENG119826,Loading procedure successful-History_Charging_Process_Charger_Temperature_Stop_Charging,68, °C
MAS19465-ENG119856,Loading procedure successful-History_Charging_Process_Reason_For_Charging_Stop,customer,
MAS19465-ENG119569,Loading procedure successful-History_Charging_Process_SOC_End,3.85, %
MAS19465-ENG119938,Loading procedure successful-History_Charging_Process_SOC_Start,0.00, %
MAS19465-ENG119416,Loading procedure successful-History_Counter_Charging_Cycle,33,
MAS19465-ENG119648,Loading procedure successful-History_Energy_Amount_Rail_1,33, Wh
MAS19465-ENG119849,Loading procedure successful-History_Energy_Amount_Rail_2,32, Wh
MAS19465-ENG119862,Loading procedure successful-History_Energy_Amount_Rail_3,32, Wh
MAS19465-ENG119660,Loading procedure successful-History_PRX_Voltage,0, mV
MAS19466-IDE09039,Charging faulty-HV charger - current output voltage,0, V
MAS19466-IDE09193,Charging faulty-Temperature sensor 1,-55.0, °C
MAS19466-IDE09194,Charging faulty-Temperature sensor 2,-55.0, °C
MAS19466-IDE09195,Charging faulty-Temperature sensor 3,-55.0, °C
MAS19466-IDE09196,Charging faulty-Temperature sensor 4,-55.0, °C
MAS19466-MAS00106,Charging faulty-Year,2000,
MAS19466-MAS00107,Charging faulty-Month,0,
MAS19466-MAS00108,Charging faulty-Day,0,
MAS19466-MAS00109,Charging faulty-Hours,0,
MAS19466-MAS00110,Charging faulty-Minutes,0,
MAS19466-MAS02949,Charging faulty-Frequency,0, Hz
MAS19466-MAS02952,Charging faulty-Control voltage,0, mV
MAS19466-MAS03084,Charging faulty-Phase 1,0, V
MAS19466-MAS03085,Charging faulty-Phase 2,0, V
MAS19466-MAS03086,Charging faulty-Phase 3,0, V
MAS19466-MAS03873,Charging faulty-Duty cycle,0.0, %
MAS19466-MAS08781,Charging faulty-Connection state of charging plug,Initialization,
MAS19466-MAS11214,Charging faulty-State of charge in %,0.00, %
MAS19466-ENG119673,Charging faulty-History_Charging_Process_Failed_Cahrger_Temperature,-40, °C
MAS19466-ENG120061,Charging faulty-History_Charging_Process_Failed_Current_Mode_BMS,BMS_HV_Off,
MAS19466-ENG119469,Charging faulty-History_Charging_Process_Failed_HMS_State,HMS_State_Not_Active,
MAS19466-ENG119748,Charging faulty-History_Charging_Process_Failed_HVLM_State,HVLM_State_Component_Ready,
MAS19466-ENG119413,Charging faulty-History_Charging_Process_Failed_Plug_A_Interlock_Voltage,0,
MAS19466-ENG119577,Charging faulty-History_Charging_Process_Failed_Plug_B_Interlock_Voltage,0,
MAS19466-ENG119427,Charging faulty-History_Charging_Process_Failed_Target_Specification_BMS,BMS_HV_Off,
MAS19466-ENG119660,Charging faulty-History_PRX_Voltage,0, mV
MAS19467-MAS00478,Powerline error status-Reserved,not active,
MAS19467-ENG119491,Powerline error status-CDO_Emergency_Shutdown_EVSE,not active,
MAS19467-ENG119620,Powerline error status-CDO_Error_ISO_Measurement,not active,
MAS19467-ENG119614,Powerline error status-CDO_EVSE_Communication_TimeOut,not active,
MAS19467-ENG119405,Powerline error status-CDO_HVLM_Shutdown,not active,
MAS19467-ENG119406,Powerline error status-CDO_Time_Out_Charging_Plug_Lock,not active,
MAS19467-ENG119989,Powerline error status-CDO_Time_Out_Charging_Plug_Unlock,not active,
MAS19467-ENG119647,Powerline error status-CDO_version_greater_than_v1,not active,
MAS19467-ENG119957,Powerline error status-GBT_Emergency_Shutdown_EVSE,not active,
MAS19467-ENG119584,Powerline error status-GBT_Error_ISO_Measurement,not active,
MAS19467-ENG119467,Powerline error status-GBT_EVSE_Communication_TimeOut,not active,
MAS19467-ENG119556,Powerline error status-GBT_HVLM_Shutdown,not active,
MAS19467-ENG119667,Powerline error status-GBT_Time_Out_Charging_Plug_Lock,not active,
MAS19467-ENG119773,Powerline error status-GBT_Time_Out_Charging_Plug_Unlock,not active,
MAS19467-ENG119786,Powerline error status-PLC_Abort_Standard_Selection_DIN-ISO,not active,
MAS19467-ENG120054,Powerline error status-PLC_Encryption_Failure,not active,
MAS19467-ENG119442,Powerline error status-PLC_Error_Cable_Check,not active,
MAS19467-ENG119778,Powerline error status-PLC_Error_Certificate,not active,
MAS19467-ENG119686,Powerline error status-PLC_Error_Installation_new_certificate,not active,
MAS19467-ENG119544,Powerline error status-PLC_Error_Precharge,not active,
MAS19467-ENG119655,Powerline error status-PLC_EVSE_Emergency_Shutdown,not active,
MAS19467-ENG119568,Powerline error status-PLC_EVSE_Malfunction,not active,
MAS19467-ENG119774,Powerline error status-PLC_EVSE_Supported_Energy_Transfer_Types_incompatibel,not active,
MAS19467-ENG119599,Powerline error status-PLC_HVLM_Shutdown,not active,
ENG00219-ENG127685,AC_network_separated_frequency-AC_rail1_network_frequency,Initialization,
ENG00219-ENG127686,AC_network_separated_frequency-AC_rail2_network_frequency,Initialization,
ENG00219-ENG127687,AC_network_separated_frequency-AC_rail3_network_frequency,Initialization,
ENG119238-ENG119485,AC_phase_current_actual_value-AC_phase_1_current_actual_value,-1000.0, A
ENG119238-ENG119753,AC_phase_current_actual_value-AC_phase_2_current_actual_value,-1000.0, A
ENG119238-ENG119553,AC_phase_current_actual_value-AC_phase_3_current_actual_value,-1000.0, A
ENG119239,actual_current_hv_booster_hv_highside,0.00, A
ENG114448,actual_status_awc,Standby,
ENG119240,actual_status_hv_booster_OBC,Standby,
ENG119241,Actual_voltage_bmc_dc_charging_station,0, V
ENG119242,actual_voltage_hv_booster_dc_charging_station,0.00, A
ENG119243,actual_voltage_hv_booster_hv_highside,0.00, V
ENG119244,actual_voltage_hv_booster_hv_Lowside,0.00, V
ENG119246-MAS00478,available_services_scc-Reserved,not active,
ENG119246-ENG119460,available_services_scc-Contract_Certificate_Service_Installation_available,not active,
ENG119246-ENG119697,available_services_scc-Contract_Certificate_Service_Update_available,not active,
ENG119246-ENG120053,available_services_scc-diagnosis_iccpd,not active,
ENG119246-ENG119932,available_services_scc-EV_Charging,not active,
ENG119246-ENG119652,available_services_scc-Internet,not active,
ENG119246-ENG119570,available_services_scc-ISO_extension_ilf_private,not active,
ENG119246-ENG119979,available_services_scc-operation_and_display_ilf_iccpd,not active,
ENG119247,AWC_actual_current,0.0, A
ENG08841-ENG09564,Awc_control_values-HVLM_AWC_Sollmodus,not active,
ENG08841-ENG09565,Awc_control_values-HVLM_AWC_Sollstrom,0.0, A
ENG08842-ENG09567,Awc_values-AWC_MaxLadLeistung,0, W
ENG08842-ENG09566,Awc_values-AWC_Status,StandbyState,
ENG119253-ENG119759,chademo_status_signals-chademo_status_charging_connector,not connected,
ENG119253-ENG119666,chademo_status_signals-chademo_status_charging_connector_locking,unlocked,
ENG119253-ENG119600,chademo_status_signals-chademo_status_charging_readiness,not operational,
ENG119253-ENG119717,chademo_status_signals-chademo_status_charging_request_station,not requested,
ENG119253-ENG119743,chademo_status_signals-chademo_status_charging_station,Standby,
ENG119253-ENG119538,chademo_status_signals-chademo_status_charging_termination,Normal operating mode,
ENG119253-ENG119738,chademo_status_signals-chademo_status_iso_measurement,not active,
ENG125873,charger_coolant_temperature,32, °C
ENG119254,Charger_HV_current_actual_value_high_resolution,0.0, A
ENG119255,charging_current_chademo_station,0, A
ENG119256,charging_current_station_scc,0.0, A
ENG26217,charging_duration_total,0, min
ENG119235-ENG119385,Charging_flap_b_cycle_data-counter_locking_cycles_charge_flap,0,
ENG123142,charging_process_request,not requested,
ENG123144,charging_status,OFF,
ENG119257,charging_time_china_dc_ccs,0, min
ENG119258,charging_time_china_dc_csd,0, min
ENG125862,current_voltage_protection,not active,
ENG119261-ENG119505,Delay_AWC_Components-delay_fod,not active,
ENG119261-ENG119929,Delay_AWC_Components-delay_lop,not active,
ENG119261-ENG119672,Delay_AWC_Components-delay_temperature,not active,
ENG119261-ENG119795,Delay_AWC_Components-delay_zmover,not active,
ENG119261-ENG119535,Delay_AWC_Components-functional_protection,not active,
ENG26218,energy_turnover_total,0, kWh
ENG114566-ENG119482,error_awc_components-error_communication,No malfunction,
ENG114566-ENG115101,error_awc_components-error_fod,No malfunction,
ENG114566-ENG119889,error_awc_components-error_lop,No malfunction,
ENG114566-ENG119953,error_awc_components-error_zmover,No malfunction,
ENG125863,error_status_battery_charger,not active,
ENG119263,error_status_hv_booster,Komponente_IO,
ENG08845,Haltemanagementsystem_Entwicklerwerte,Parken_nicht_beibehalten,
ENG08845,Haltemanagementsystem_Entwicklerwerte,keine_Anforderung,
ENG126544,high_voltage_activation_request,not requested,
ENG119276-MAS07146,History_Counter_Actuations_Push_Button_Module_socket_ac-Button 1,10,
ENG119276-MAS07147,History_Counter_Actuations_Push_Button_Module_socket_ac-Button 2,0,
ENG119277-MAS07146,History_Counter_Actuations_Push_Button_Module_socket_dc-Button 1,49,
ENG119277-MAS07147,History_Counter_Actuations_Push_Button_Module_socket_dc-Button 2,0,
ENG119278-ENG119987,History_Counter_CP_Voltage-History_Counter_CP_Voltage_Range_5.5_to_5.9V,1,
ENG119278-ENG119793,History_Counter_CP_Voltage-History_Counter_CP_Voltage_Range_5_to_5.4V,0,
ENG119278-ENG119651,History_Counter_CP_Voltage-History_Counter_CP_Voltage_Range_6.5_to_7V,0,
ENG119278-ENG119685,History_Counter_CP_Voltage-History_Counter_CP_Voltage_Range_6_to_6.4V,0,
ENG119278-ENG119732,History_Counter_CP_Voltage-History_Counter_CP_Voltage_Range_8.5_to_8.9V,1,
ENG119278-ENG119670,History_Counter_CP_Voltage-History_Counter_CP_Voltage_Range_8_to_8.4V,0,
ENG119278-ENG119964,History_Counter_CP_Voltage-History_Counter_CP_Voltage_Range_9.5_to_10V,0,
ENG119278-ENG119936,History_Counter_CP_Voltage-History_Counter_CP_Voltage_Range_9_to_9.4V,0,
ENG119279,History_Counter_DC_Charging_China,0,
ENG119280,hv_booster_current_commanded_value,511.00, A
ENG119281,hv_booster_voltage_commanded_value,0.00, V
ENG119282,HV_DC_actual_voltage_value_awc,0, V
ENG119283,HV_DC_actual_voltage_value_hvlm,418, V
ENG119284-ENG119805,hvlb_charging_otpions_availability-ac_chargin,not active,
ENG119284-ENG119955,hvlb_charging_otpions_availability-dc_charging_with_boost,not active,
ENG119284-ENG120011,hvlb_charging_otpions_availability-dc_charging_without_boost,not active,
ENG08840,HVLM_Fehlerstatus,Komponente_IO,
ENG08847-ENG30021,HVLM_Signale_Konditionierung-HVLM_FreigabeKlimatisierung,KEINE_FREIGABE,
ENG08847-ENG119522,HVLM_Signale_Konditionierung-HVLM_VK_Modus,keine Vorkonditionierung,
ENG08843,HVLM_Zustand_LED,Farbe_1_aus,
ENG119285,ilf_charging_mode,Imm. charg.,
ENG119287,internal_status_charging_station_hlc,EVSE_Not_Ready,
ENG22813-ENG24171,Knockout_test_mode-Knockout_Test,00,
ENG119291-MAS00478,linked_charging_source-Reserved,not active,
ENG119291-ENG98334,linked_charging_source-AC,not active,
ENG119291-ENG119548,linked_charging_source-AC_IS_15118,not active,
ENG119291-ENG119658,linked_charging_source-AWC,not active,
ENG119291-ENG119950,linked_charging_source-AWC_ISO_15118,not active,
ENG119291-ENG119550,linked_charging_source-DC_CHAdeMO,not active,
ENG119291-ENG119595,linked_charging_source-DC_DIN_70121,not active,
ENG119291-ENG120060,linked_charging_source-DC_GBT,not active,
ENG119291-ENG119704,linked_charging_source-DC_ISO_15118,not active,
ENG119292-ENG119818,max_allowed_AC_phase_current_value-max_allowed_phase_1_current_value,0.0, A
ENG119292-ENG119870,max_allowed_AC_phase_current_value-max_allowed_phase_2_current_value,0.0, A
ENG119292-ENG119835,max_allowed_AC_phase_current_value-max_allowed_phase_3_current_value,0.0, A
ENG119293,max_dyn_current,0.00, A
ENG123143,max_HV_DC_voltage_obc,489, V
ENG119294-ENG120048,maximum_charging_power-maximum_charging_power_ac,0, W
ENG119294-ENG119833,maximum_charging_power-maximum_charging_power_awc,0, W
ENG119294-ENG119384,maximum_charging_power-maximum_charging_power_dc,0, W
ENG125868,maximum_charging_power_battery_charger,0, A
ENG119295,maximum_power_hvem,0, W
ENG119297,nominal_mode_hv_booster_OBC,Standby,
ENG119299,operation_time_interior_preconditioning,0, min
ENG119301-ENG119676,position_charging_flap-position_charging_flap_ac,Open,
ENG119301-ENG120070,position_charging_flap-position_charging_flap_dc,Open,
ENG125870,power_efficiency,Initialization,
ENG125869,power_loss_battery_charger,0, W
ENG07648-ENG30068,prx_voltage_charging_connector_A-raw_value_in_develop_by_ODXauthor,11 40,
ENG119302,prx_voltage_charging_connector_B,4416, mV
ENG00221-ENG127691,rail_energy_transformation-rail_1_energy_transformation,2.4, kWh
ENG00221-ENG127692,rail_energy_transformation-rail_2_energy_transformation,0.3, kWh
ENG00221-ENG127693,rail_energy_transformation-rail_3_energy_transformation,0.4, kWh
ENG119227,recharge_request,not active,
ENG119305-ENG119904,remaining_charging_time_chademo-overflow_remaining_charging_time_chademo,0, min
ENG119305,remaining_charging_time_chademo,0, min
ENG119308,request_connector_locking,not requested,
ENG119309,request_phev_combuster_pre_heater,combuster_pre_heater_forbid,
ENG119310,request_preconditioning_ilf,not requested,
ENG119313,scc_response_code,no_response_code,
ENG119314-MAS00478,selected_service_list_ilf-Reserved,not active,
ENG119314-ENG119460,selected_service_list_ilf-Contract_Certificate_Service_Installation_available,not active,
ENG119314-ENG119697,selected_service_list_ilf-Contract_Certificate_Service_Update_available,not active,
ENG119314-ENG120053,selected_service_list_ilf-diagnosis_iccpd,not active,
ENG119314-ENG119932,selected_service_list_ilf-EV_Charging,not active,
ENG119314-ENG119652,selected_service_list_ilf-Internet,not active,
ENG119314-ENG119570,selected_service_list_ilf-ISO_extension_ilf_private,not active,
ENG119314-ENG119979,selected_service_list_ilf-operation_and_display_ilf_iccpd,not active,
ENG119325-ENG119858,status_bap_actuality-bap_date,obsolet,
ENG119325-ENG119633,status_bap_actuality-bap_time,obsolet,
ENG119326,status_clamp_15,not active,
ENG119327,status_communication_scc,no_Information,
ENG119328,status_contract_certificate,certificate_not_proved,
ENG119329-ENG119444,status_dc_charging_abort_ev03-error_hb_battery_low_voltage,No malfunction,
ENG119329-ENG119810,status_dc_charging_abort_ev03-error_hv_battery_over_temperature,No malfunction,
ENG119329-ENG119838,status_dc_charging_abort_ev03-error_hv_battery_over_voltage,No malfunction,
ENG119329-ENG59344,status_dc_charging_abort_ev03-error_vehicle,No malfunction,
ENG119330-ENG119787,status_dc_charging_abort_evse2-error_chademo_charging_station,No malfunction,
ENG119330-ENG119601,status_dc_charging_abort_evse2-error_hv_battery_voltage_compatibility,No malfunction,
ENG119330-ENG59344,status_dc_charging_abort_evse2-error_vehicle,No malfunction,
ENG119331-ENG18444,status_dc_charging_vehicle_ev03-Charging_Readiness,not operational,
ENG119331-ENG119821,status_dc_charging_vehicle_ev03-request_charging_termination,not requested,
ENG119331-ENG119507,status_dc_charging_vehicle_ev03-status_hv_relais,Open,
ENG119331-ENG120003,status_dc_charging_vehicle_ev03-status_selection_lever,not requested,
ENG119332,status_hlc,No communication,
ENG119333,status_ilf,not active,
ENG119334-MAS00478,status_scc_errors-Reserved,not active,
ENG119334-ENG119590,status_scc_errors-Scc_Stack_Error_Crypto,not active,
ENG119334-ENG119885,status_scc_errors-Scc_Stack_Error_Exi,not active,
ENG119334-ENG119894,status_scc_errors-Scc_Stack_Error_Invalid_Rx_Message,not active,
ENG119334-ENG119763,status_scc_errors-Scc_Stack_Error_Invalid_Rx_Parameter,not active,
ENG119334-ENG119585,status_scc_errors-Scc_Stack_Error_Invalid_Tx_Parameter,not active,
ENG119334-ENG120009,status_scc_errors-Scc_Stack_Error_NRC,not active,
ENG119334-ENG119443,status_scc_errors-Scc_Stack_Error_NvM,not active,
ENG119334-ENG119662,status_scc_errors-Scc_Stack_Error_SLAC,not active,
ENG119334-ENG119625,status_scc_errors-Scc_Stack_Error_Timeout,not active,
ENG119334-ENG119825,status_scc_errors-Scc_Stack_Error_Transport_Layer,not active,
ENG119334-ENG119497,status_scc_errors-Scc_Stack_Error_Xml_Security,not active,
ENG119335-ENG119827,status_state_machine_hlc-status_chademo_state_machine,0,
ENG119335-ENG119541,status_state_machine_hlc-status_china_dc_state_machine,0,
ENG119335-ENG119886,status_state_machine_hlc-status_plc_state_machine,24,
ENG119336-ENG119869,supported_energy_transfer_mode-AC_single_phase_core,not active,
ENG119336-ENG119895,supported_energy_transfer_mode-AC_three_phase_core,not active,
ENG119336-ENG119555,supported_energy_transfer_mode-DC_combo_core,not active,
ENG119336-ENG119939,supported_energy_transfer_mode-dc_core,not active,
ENG119336-ENG119698,supported_energy_transfer_mode-DC_dual,not active,
ENG119336-ENG119580,supported_energy_transfer_mode-DC_extended,not active,
ENG26417-ENG119918,Thermomanagement_conditioning-maximum_duration_pre_conditioning,calculation_phase,
ENG26417-ENG119481,Thermomanagement_conditioning-runtime_requirement_pre_conditioning,Default,
ENG26417-ENG120055,Thermomanagement_conditioning-Thermomanagement_operation_interior_conditioning,Voko_inaktiv,
ENG26417-ENG30160,Thermomanagement_conditioning-Thermomanagement_satus_interior_conditioning,Kond_innen_moeglich,
ENG08846-ENG09570,Thermomanagementsystem Entwicklerwerte-TME_Heizstrategie,OFF,
ENG36586-ENG36897,wakeupcounter_Infrastructure-wakeupcounter_cp,0,
ENG36586-ENG36898,wakeupcounter_Infrastructure-wakeupcounter_prx,0,
ENG125864,warning_status_battery_charger,Warning active,
ENG119341,warning_status_hv_booster,no warning,
Re: MEB Chargers
CAN signals likely required - Hope to expand/elaborate on what signals are or aren't required:
Additional Signals - May be required:
BAP signals Received:
BAP_BatteryControl_ASG_01 - 0x97332500
BAP_BatteryControl_ASG_02 - 0x97332501
BAP_BatteryControl_ASG_03 - 0x97332502
BAP_BatteryControl_ASG_04 - 0x97332503
BAP_BatteryControl_ASG_05 - 0x97332504
BAP_BatteryControl_ASG_06 - 0x97332505
BAP_Uhrzeit_FSG_01 - 0x97331110
BAP signals Sent:
BAP_BatteryControl_FSG_01 - 0x97332510
- BMS_01 - 0x191
- BMS_02 - 0x1A1
- BMS_03 - 0x39D
- BMS_04 - 0x5A2
- BMS_06 - 0x59E
- BMS_07 - 0x5CA
- BMS_09 - 0x96A955EB
- BMS_10 - 0x509
- BMS_11 - 0x96A954A6
- BMS_27 - 0x9A555552
- DCDC_HV_02_01 - 0x9A555545 - 400v to 800v converter - Likely not required
- DCDC_HV_02_02 - 0x92DD54AD - 400v to 800v converter - Likely not required
- DCDC_HV_02_03 - 0x9A55554E - 400v to 800v converter - Likely not required
- Dimmung_01 - 0x5F0
- Einheiten_01 - 0x643
- ESP_15 - 0x1A2 - Holding Management System info - Likely not required
- Kessy_11 - 0x1F1
- Klima_14 - 0x9A55548D
- Klima_17 - 0x9A555525
- Klima_Sensor_02 - 0x5E1
- Kombi_02 - 0x6B7
- Motor_12 - 0x0A8
- Motor_14 - 0x3BE
- Motor_31 - 0x556
- Motor_Hybrid_03 - 0x131
- MSG_TME_01 - 0x59A
- MSG_TME_02 - 0x2B1
- NavData_02 - 0x485
- OBD_01 - 0x391
- Reichweite_01 - 0x5F5
- Reichweite_02 - 0x5F7
- TME_07 - 0x3F7
- TME_09 - 0x577
- TME_10 - 0x55F
- TME_11 - 0x55D
BAP signals Sent:
Re: MEB Chargers
MLBEvo Magic Bytes:
Found in the DBC files under 'GenMsgPDUConstants'
0x040 - Airbag_01 - Hex ID 0x040 = { 0x40, 0x40, 0x40, 0x40, 0x40, 0x40, 0x40, 0x40, 0x40, 0x40, 0x40, 0x40, 0x40, 0x40, 0x40, 0x40 };
0x073 - EM1_HYB_12 - Hex ID 0x073 = { 0xdb, 0x71, 0x31, 0xf9, 0x26, 0x43, 0x6d, 0x22, 0x52, 0xe4, 0xe8, 0xa9, 0x73, 0x1c, 0xc5, 0x67 };
0x074 - EM2_HYB_12 - Hex ID 0x074 = { 0xb7, 0x6e, 0x93, 0xf5, 0xdc, 0x38, 0xe2, 0x40, 0x06, 0xfb, 0x80, 0x1c, 0x0e, 0xe3, 0xd5, 0xe5 };
0x075 - EM3_HYB_12 - Hex ID 0x075 = { 0x63, 0x04, 0xb4, 0x32, 0x56, 0xc1, 0xfa, 0x97, 0x1f, 0xa6, 0xae, 0xd7, 0x64, 0xc3, 0xbe, 0x42 };
0x087 - EM1_HYB_06 - Hex ID 0x087 = { 0x14, 0x40, 0x8b, 0x7a, 0x78, 0x23, 0xc6, 0x13, 0x1c, 0x03, 0xed, 0xf4, 0xcb, 0xf8, 0xf0, 0xe5 };
0x0A0 - LH_EPS_04 - Hex ID 0x0A0 = { 0x4a, 0xb4, 0xe8, 0x24, 0x99, 0x5a, 0x59, 0x8b, 0x1e, 0xaa, 0x94, 0xb6, 0x09, 0xd5, 0xaf, 0x97 };
0x0A8 - Motor_12 - Hex ID 0x0A8 = { 0x52, 0x8c, 0x50, 0xee, 0x4f, 0xa6, 0xcc, 0xcf, 0x7d, 0x2f, 0x98, 0x6b, 0x27, 0x41, 0x9f, 0x93 };
0x0B1 - Getriebe_17 - Hex ID 0x0B1 = { 0xe1, 0x9e, 0xc2, 0xe9, 0x48, 0x98, 0xf5, 0xb6, 0x47, 0x83, 0x26, 0x45, 0x9a, 0x10, 0x7b, 0x1c };
0x0B3 - Bremse_EV_01 - Hex ID 0x0B3 = { 0x41, 0x41, 0x41, 0x41, 0x41, 0x41, 0x41, 0x41, 0x41, 0x41, 0x41, 0x41, 0x41, 0x41, 0x41, 0x41 };
0x108 - Fahrwerk_01 - Hex ID 0x108 = { 0x09, 0x09, 0x09, 0x09, 0x09, 0x09, 0x09, 0x09, 0x09, 0x09, 0x09, 0x09, 0x09, 0x09, 0x09, 0x09 };
0x111 - EM2_HYB_06 - Hex ID 0x111 = { 0xb3, 0xeb, 0xe1, 0xf7, 0xba, 0x9e, 0x5f, 0xd9, 0xc2, 0xec, 0xf6, 0xe9, 0x24, 0x18, 0x48, 0xed };
0x116 - ESP_10 - Hex ID 0x116 = { 0xac, 0xac, 0xac, 0xac, 0xac, 0xac, 0xac, 0xac, 0xac, 0xac, 0xac, 0xac, 0xac, 0xac, 0xac, 0xac };
0x121 - Motor_20 - Hex ID 0x121 = { 0xe9, 0x65, 0xae, 0x6b, 0x7b, 0x35, 0xe5, 0x5f, 0x4e, 0xc7, 0x86, 0xa2, 0xbb, 0xdd, 0xeb, 0xb4 };
0x136 - HAL_01 - Hex ID 0x136 = { 0x37, 0x37, 0x37, 0x37, 0x37, 0x37, 0x37, 0x37, 0x37, 0x37, 0x37, 0x37, 0x37, 0x37, 0x37, 0x37 };
0x153 - MSG_HYB_30 - Hex ID 0x153 = { 0x03, 0x13, 0x23, 0x7a, 0x40, 0x51, 0x68, 0xba, 0xa8, 0xbe, 0x55, 0x02, 0x11, 0x31, 0x76, 0xec };
0x154 - Motor_28 - Hex ID 0x154 = { 0x21, 0x93, 0x4a, 0x04, 0x5c, 0x18, 0xe0, 0x69, 0x14, 0xce, 0x26, 0x8f, 0x5e, 0xb1, 0xdf, 0x53 };
0x184 - ZV_01 - Hex ID 0x184 = { 0xe3, 0xe8, 0xc4, 0x7f, 0xf1, 0x95, 0xd8, 0xb0, 0xc7, 0xa3, 0xf4, 0x6c, 0xe7, 0xc3, 0x5a, 0xf7 };
0x18D - BMS_MV_01 - Hex ID 0x18D = { 0x9c, 0xcc, 0xe1, 0x4c, 0xc9, 0x39, 0xe3, 0x53, 0x78, 0x33, 0x15, 0x49, 0x55, 0x0a, 0x62, 0x83 };
0x191 - BMS_01 - Hex ID 0x191 = { 0x7d, 0x0e, 0xaf, 0x0b, 0x24, 0x58, 0x88, 0x9e, 0x89, 0x3a, 0x81, 0x61, 0x4e, 0xe3, 0x04, 0x1f };
0x1A2 - ESP_15 - Hex ID 0x1A2 = { 0xcb, 0x47, 0xd7, 0xd2, 0x56, 0x3e, 0x20, 0xea, 0x6e, 0x6d, 0x8c, 0x1b, 0xdf, 0x49, 0xaa, 0xab };
0x1A3 - BMS_MV_02 - Hex ID 0x1A3 = { 0x4a, 0x06, 0x0a, 0x36, 0xf8, 0xd3, 0x60, 0x79, 0xaa, 0xd2, 0x2e, 0x89, 0xa3, 0x76, 0x5f, 0x45 };
0x1F3 - BMS_NV_01 - Hex ID 0x1F3 = { 0xc4, 0x1e, 0x9c, 0xae, 0x59, 0xcc, 0x66, 0x99, 0xe1, 0x87, 0xe8, 0x4c, 0x65, 0x4a, 0xc9, 0xde };
0x1F9 - STP_03 - Hex ID 0x1F9 = { 0x14, 0xf8, 0xf6, 0x94, 0x2a, 0x12, 0x39, 0x3d, 0x98, 0x3f, 0xfb, 0x9d, 0x36, 0xca, 0x1d, 0xe0 };
0x20F - NVEM_10 - Hex ID 0x20F = { 0xd4, 0x22, 0xad, 0x3f, 0x25, 0xaa, 0x62, 0x5b, 0xdc, 0x73, 0xed, 0xc3, 0x9a, 0x14, 0x2f, 0x3e };
0x2AD - DCDC_MV_01 - Hex ID 0x2AD = { 0x7b, 0xed, 0xa6, 0xd1, 0x57, 0x4b, 0x69, 0x9f, 0x13, 0x82, 0x9e, 0x19, 0x3e, 0x08, 0x5e, 0x78 };
0x2AE - DCDC_01 - Hex ID 0x2AE = { 0x83, 0x50, 0xbf, 0x5d, 0x67, 0x68, 0x2f, 0x4b, 0x32, 0x4e, 0x1a, 0xba, 0xc4, 0x39, 0xf5, 0xdb };
0x31B - ESP_24 - Hex ID 0x31B = { 0x67, 0x8a, 0xae, 0x22, 0x4d, 0xd0, 0x51, 0x80, 0x5c, 0xb9, 0xce, 0x1e, 0xdf, 0x02, 0x2d, 0xd4 };
0x365 - NVEM_05 - Hex ID 0x365 = { 0xe3, 0x0a, 0x29, 0xd3, 0x96, 0xaa, 0xeb, 0x89, 0xe6, 0x5f, 0x14, 0xc4, 0xe9, 0x27, 0x0b, 0x2d };
0x367 - BMS_MV_03 - Hex ID 0x367 = { 0xa1, 0xb0, 0xdb, 0x69, 0x9c, 0xef, 0xbd, 0x08, 0xdd, 0xcc, 0x1b, 0x05, 0xce, 0x20, 0xe1, 0x48 };
0x37C - EM1_HYB_11 - Hex ID 0x37C = { 0xed, 0x03, 0x1c, 0x13, 0xc6, 0x23, 0x78, 0x7a, 0x8b, 0x40, 0x14, 0x51, 0xbf, 0x68, 0x32, 0xba };
0x394 - WBA_03 - Hex ID 0x394 = { 0x47, 0x94, 0x92, 0x6a, 0x67, 0xb5, 0x0d, 0x38, 0xe3, 0x8a, 0x5d, 0xb4, 0x54, 0xab, 0xae, 0x27 };
0x3BE - Motor_14 - Hex ID 0x3BE = { 0x1f, 0x28, 0xc6, 0x85, 0xe6, 0xf8, 0xb0, 0x19, 0x5b, 0x64, 0x35, 0x21, 0xe4, 0xf7, 0x9c, 0x24 };
0x3C0 - Klemmen_Status_01 - Hex ID 0x3C0 = { 0xc3, 0xc3, 0xc3, 0xc3, 0xc3, 0xc3, 0xc3, 0xc3, 0xc3, 0xc3, 0xc3, 0xc3, 0xc3, 0xc3, 0xc3, 0xc3 };
0x3F4 - DCDC_02 - Hex ID 0x3F4 = { 0x26, 0xe4, 0xc5, 0x16, 0xcf, 0x20, 0x65, 0xad, 0xed, 0x6a, 0xa3, 0x49, 0x02, 0x6b, 0xb2, 0xbd };
0x3FA - DCDC_MV_02 - Hex ID 0x3FA = { 0x26, 0xe3, 0x43, 0x0a, 0x6d, 0x29, 0x22, 0xd3, 0x52, 0x96, 0xe4, 0xaa, 0xe8, 0xeb, 0xa9, 0x89 };
0x450 - EM3_HYB_14 - Hex ID 0x450 = { 0x30, 0x25, 0xc2, 0x1f, 0x02, 0xb1, 0x9e, 0xe0, 0x73, 0x51, 0xe1, 0xa5, 0xab, 0x0d, 0xf4, 0x2f };
0x451 - EM2_HYB_14 - Hex ID 0x451 = { 0x19, 0xc1, 0x1a, 0xf6, 0x7d, 0x28, 0x7b, 0x12, 0xcb, 0x29, 0x59, 0x98, 0xd2, 0xbf, 0x53, 0x9d };
0x452 - EM1_HYB_14 - Hex ID 0x452 = { 0x74, 0x4a, 0x84, 0x18, 0xb9, 0x14, 0x9e, 0x8f, 0x0c, 0xdf, 0x29, 0x40, 0x63, 0x1f, 0xd4, 0xca };
0x457 - BMS_14 - Hex ID 0x457 = { 0x82, 0x79, 0xee, 0xb9, 0xf9, 0x67, 0x97, 0xad, 0xb1, 0xd5, 0xcb, 0xf7, 0xb6, 0x70, 0x13, 0xaa };
0x503 - HVK_01 - Hex ID 0x503 = { 0xed, 0xd6, 0x96, 0x63, 0xa5, 0x12, 0xd5, 0x9a, 0x1e, 0x0d, 0x24, 0xcd, 0x8c, 0xa6, 0x2f, 0x41 };
0x504 - MVK_01 - Hex ID 0x504 = { 0x03, 0x63, 0x3e, 0x04, 0xf9, 0xb4, 0x4f, 0x32, 0x25, 0x56, 0x1e, 0xc1, 0x83, 0xfa, 0x31, 0x97 };
0x53C - HVLM_04 - Hex ID 0x53C = { 0x8e, 0xf9, 0xe1, 0x2e, 0x83, 0x34, 0xd0, 0xf1, 0xaa, 0x2c, 0xbb, 0x81, 0x17, 0x60, 0x11, 0x37 };
0x564 - LAD_01 - Hex ID 0x564 = { 0x24, 0x24, 0x24, 0x24, 0x24, 0x24, 0x24, 0x24, 0x24, 0x24, 0x24, 0x24, 0x24, 0x24, 0x24, 0x24 };
0x578 - BMS_DC_01 - Hex ID 0x578 = { 0x48, 0x48, 0x48, 0x48, 0x48, 0x48, 0x48, 0x48, 0x48, 0x48, 0x48, 0x48, 0x48, 0x48, 0x48, 0x48 };
0x5A2 - BMS_04 - Hex ID 0x5A2 = { 0xeb, 0x4c, 0x44, 0xaf, 0x21, 0x8d, 0x01, 0x58, 0xfa, 0x93, 0xdb, 0x89, 0x15, 0x10, 0x4a, 0x61 };
0x5A3 - BMS_MV_04 - Hex ID 0x5A3 = { 0x0a, 0xd3, 0xaa, 0x89, 0x5f, 0xc4, 0x27, 0x2d, 0xfb, 0xa0, 0x47, 0x1e, 0x28, 0xa8, 0x44, 0x5c };
0x5CA - BMS_07 - Hex ID 0x5CA = { 0x43, 0x43, 0x43, 0x43, 0x43, 0x43, 0x43, 0x43, 0x43, 0x43, 0x43, 0x43, 0x43, 0x43, 0x43, 0x43 };
0x5CC - DCDC_MV_03 - Hex ID 0x5CC = { 0x92, 0x9d, 0xb8, 0x71, 0xc4, 0x40, 0x3d, 0x49, 0x5b, 0x4d, 0xfa, 0x94, 0x6d, 0x72, 0xb3, 0x46 };
0x5CD - DCDC_03 - Hex ID 0x5CD = { 0x93, 0x04, 0x18, 0x69, 0xce, 0x8f, 0xb1, 0x53, 0x40, 0x2d, 0xe4, 0xca, 0x90, 0x25, 0x79, 0x8c };
0x641 - Motor_Code_01 - Hex ID 0x641 = { 0x47, 0x47, 0x47, 0x47, 0x47, 0x47, 0x47, 0x47, 0x47, 0x47, 0x47, 0x47, 0x47, 0x47, 0x47, 0x47 };
0x65D - ESP_20 - Hex ID 0x65D = { 0xac, 0xb3, 0xab, 0xeb, 0x7a, 0xe1, 0x3b, 0xf7, 0x73, 0xba, 0x7c, 0x9e, 0x06, 0x5f, 0x02, 0xd9 };
0x67E - LAD_02 - Hex ID 0x67E = { 0x25, 0x25, 0x25, 0x25, 0x25, 0x25, 0x25, 0x25, 0x25, 0x25, 0x25, 0x25, 0x25, 0x25, 0x25, 0x25 };
0x92DD5477 - EM2_HYB_11 - Hex ID 0x92DD5477 = { 0x41, 0x5e, 0x7f, 0xc7, 0xc3, 0x04, 0x0a, 0x11, 0x34, 0x4d, 0x9b, 0x27, 0xaf, 0x0d, 0x0f, 0x31 };
0x92DD5478 - EM3_HYB_11 - Hex ID 0x92DD5478 = { 0xe0, 0x2f, 0x8d, 0x3c, 0x70, 0x22, 0x03, 0x60, 0x0e, 0x18, 0xd9, 0xeb, 0x95, 0x63, 0xcb, 0x76 };
0x92DD5490 - LAD2_01 - Hex ID 0x92DD5490 = { 0x48, 0x52, 0xa7, 0xe6, 0x83, 0x2b, 0x8c, 0xfb, 0x7b, 0x64, 0x58, 0x50, 0xbc, 0xb3, 0x0f, 0x9c };
0x92DD5491 - HVLM_11 - Hex ID 0x92DD5491 = { 0xb1, 0x44, 0x37, 0xca, 0xb5, 0xd6, 0x0e, 0xa3, 0x3b, 0x16, 0xa6, 0x1a, 0x23, 0x1d, 0x91, 0x9c };
0x92DD5493 - LAD_05 - Hex ID 0x92DD5493 = { 0x74, 0x7e, 0x45, 0xe8, 0x3c, 0xd0, 0x13, 0x1f, 0x4e, 0x3a, 0x88, 0x0b, 0x7d, 0xd2, 0x6d, 0xab };
0x92DD54AB - ESP_25 - Hex ID 0x92DD54AB = { 0xab, 0xe1, 0x73, 0x9e, 0x02, 0xc2, 0x30, 0xe9, 0x75, 0x48, 0x2e, 0x98, 0x7f, 0xf5, 0xa7, 0xb6 };
0x92DD54AD - DCDC_HV_02_02 - Hex ID 0x92DD54AD = { 0x02, 0xf4, 0x6f, 0x42, 0x4a, 0x62, 0xcd, 0x1b, 0xb4, 0xa0, 0x16, 0x14, 0xe8, 0x0a, 0x71, 0xef };
0x92DD54E0 - BMS_NV_05 - Hex ID 0x92DD54E0 = { 0xd0, 0x4d, 0x22, 0xae, 0x8a, 0x67, 0xf4, 0x35, 0x15, 0x2a, 0xb8, 0x4e, 0xcc, 0x07, 0xad, 0xa2 };
0x92DD550B - BMS_30 - Hex ID 0x92DD550B = { 0x67, 0xf7, 0x44, 0xdc, 0xd2, 0xca, 0xe7, 0x2b, 0xd6, 0x5c, 0xc6, 0xa3, 0xbe, 0x0d, 0x16, 0x58 };
0x96A95414 - NVEM_06 - Hex ID 0x96A95414 = { 0xa3, 0xed, 0x65, 0xcf, 0xc5, 0x26, 0x54, 0x1a, 0x99, 0x3c, 0x01, 0x84, 0xf4, 0x46, 0x9c, 0x28 };
0x96A95415 - NVEM_07 - Hex ID 0x96A95415 = { 0x01, 0x40, 0xf0, 0x21, 0x22, 0x92, 0x44, 0x1a, 0x85, 0xeb, 0x7b, 0xcd, 0x7c, 0x59, 0xc5, 0xc2 };
0x96A954A6 - BMS_11 - Hex ID 0x96A954A6 = { 0x79, 0xb9, 0x67, 0xad, 0xd5, 0xf7, 0x70, 0xaa, 0x44, 0x61, 0x5a, 0xdc, 0x26, 0xb4, 0xd2, 0xc3 };
0x9A555517 - AWC_01 - Hex ID 0x9A555517 = { 0xfb, 0xee, 0x5d, 0x2d, 0xfa, 0x85, 0x27, 0xd4, 0xc9, 0xc4, 0xa5, 0x45, 0x5f, 0x76, 0xa3, 0x89 };
0x9A555545 - DCDC_HV_02_01 - Hex ID 0x9A555545 = { 0xc2, 0xe1, 0xd3, 0x20, 0x42, 0xce, 0x68, 0x05, 0xa9, 0x1b, 0xa3, 0xcc, 0xe2, 0xdd, 0x14, 0x08 };
- Has thanked: 345 times
- Been thanked: 44 times
Re: MEB Chargers
I'd like to get one of these running too. So are you using savvycan for reading and arduino or something for sending messages? Is there no interface besides this setup?
- Has thanked: 75 times
- Been thanked: 306 times
Re: MEB Chargers
I've connected my Golf GTE charger up to ODIS (connected to the power train can) and it looks like theres some coding options.
Not sure what they mean as of yet, but maybe some of the checks can be coded away like on it's bigger brother.
EDIT Coded off the flap lock and socket lock. Lets see.
VW Beetle 2003
Outlander front generator
Outlander charger
3x Golf GTE batteries
Chademo Charging
Outlander water heater
Outlander charger
Chademo Charging
- Has thanked: 43 times
- Been thanked: 111 times
Re: MEB Chargers
Been messing around with my Cayenne charger for the last few months. Tonight I finally got some continuous charge out of it. Uploaded are the coding settings I used in PIWIS.
I think the main settings that did it was disabling power line communications and also enabling plug and charge.
Edit: On further testing these didn't make any difference.
Further edit: It seems what it really cares about is socket temperature, if that's open or too high it wont charge at all. It also doesn't like charging with a target voltage of below 380v or so. Apart from that I have many faults showing on PIWIS but it will charge anyway.
With this set I use Mitchys code that he used with the higher power chargers and could enable and disable charge, also lower or increase charging amps.
Further further edit: On reflection I think this is probably more useful in the MLBevo charger thread, as I think this Porsche charger is part of that family.
- Has thanked: 21 times
- Been thanked: 5 times
Re: MEB Chargers
EDIT: Got 684J 11kW charger. After testing I 'accidentally' noticed charger data is on the same CAN bus, no need for two busses on this one. Now that I read previous posts this is clear, mee soo stupid Now I need to code things using ODIS, so there is hope on this.
- Has thanked: 256 times
- Been thanked: 68 times
Re: MEB Chargers
Hey, was this from Lars? I have the same and was a little concerned that they might be a different model as kine has a "cityscooter" sticker and part numbers have turned up anything. The connectors match the Audi E-Tron OBC though with the same number although the casing is slightly different.
- crasbe
- Has thanked: 44 times
- Been thanked: 108 times
Re: MEB Chargers
The chargers from Lars are most likely 5QE915684BJ, but nobody powered them up yet as far as I know.
Streetscooter is a company from Germany, building electric vehicles: https://en.wikipedia.org/wiki/StreetScooter
Let's hope they don't have different software than the VAG ones.
