Auris/Yaris inverter
Hi
Help me please with problem
Din_start always “On” but stm32 pin 58 (MG2 start) has 0V
How to fix it? I can’t save parameters because board always run and can’t stoped
- bexander
- Has thanked: 75 times
- Been thanked: 100 times
Re: Auris/Yaris inverter
Please, provide more information:
Which logic board and version are you using?
What version of the SW are you running?
Have you tried using "stop inverter"-button in web interface?
Have you tried upload SW from web interface?
I use a diy board assembled according to the Auris / Yaris V2B4 inverter circuits. Firmware version 5.24R-foc. The "stop the inverter" button in the web interface does not stop the inverter. I tried to download the software through the web interface, but it gave an error. I also checked with an oscilloscope the presence of a PWM on the outputs, it is only on 2 pins (pwm1_n and pwm2_n) in testing mode.
I didn’t say correctly, on pins pwm3_p and pwm2_p there is a PWM, on others there is nothing
- bexander
Please clarify, have you designed the board your self or bought one from evbmw?
Could there be some kind of soldering mishap or similar? Have you double checked all your solderings? No shorts?
Pete9008
- Has thanked: 102 times
- Been thanked: 350 times
If it is a custom board then there is a good chance it's being recognised as the wrong hardware. The OI firmware goes through quite a sophisticated process of pin checks to work out what hardware it is running on and then changes the pins used accordingly. Worth checking what HWVER is being reported in the web interface
I designed the board myself. Soldering is in order and there are no short circuits. I checked pin 58 (start) and it turned out that it was not working. It seems that the matter is in the stm32 itself. In the web interface, the board is defined as Prius
Pete9008
That explains pwm1_n and pwm2_n, the Prius code doesn't generate those. You probably want HW_REV3 to use both pos and neg outputs, suggest you have a look at the code that detects what board the code is running on to see what you need to change.
- bexander
Here is the part of the code that detects what HW you are running.
Looks like you need to pull-up or down the Desat and Cruise pins to get it to detect as HW_REV3.
HWREV detect_hw()
//Pull low via 30k the precharge output to test whether it is tied to Vcc
gpio_set_mode(GPIOB, GPIO_MODE_INPUT, GPIO_CNF_INPUT_PULL_UPDOWN, GPIO1);
if (!is_existent(GPIOC, GPIO12)) //Olimex LED pin does not exist
return HW_BLUEPILL;
/*else if (is_floating(GPIOC, GPIO1))
return HW_PRIUSMG1;*/
//else if (gpio_get(GPIOB, GPIO1)) //On Tesla M3 board precharge output is tied to Vcc
// return HW_TESLAM3;
else if (is_floating(GPIOC, GPIO9)) //Desat pin is floating
return HW_REV1;
else if (is_floating(GPIOB, GPIO5)) //Cruise pin is floating
return HW_PRIUS;
else if (is_floating(GPIOA, GPIO0)) //uvlo/button pin is floating
return HW_REV3;
else if (is_floating(GPIOC, GPIO8)) //bms input is output for mux and floating
return HW_TESLA;
else
return HW_REV2;
}Re: Auris/Yaris inverter
Is it possible to get foc firmware source code? This would solve my problem with a broken pin if pull-downed it in to gnd.
Oh I thought sin sw was only for induction motors and can't be used for synchronous motors. Thank you!
- bexander
Same SW with different build options. Look at the section furthest down on the github.
I tried to build sw and got issue
"Execution of 'CONTROL=SINE make' in 'C:\Users\.....\stm32-sine-5.24.R' failed."
What I doing wrong? I installed arm-none-eabi toolchain and set it in to toolchain executables
- bexander
I think you are suppose to run only "make" and not "CONTROL=SINE make" to build the sine version?
I'm trying to figure out how to compile the firmware, but I can't. What you need to open and where to typing "make"? I tried to build it in Code::Blocks but it doesn't work.
- bexander
I could compile the foc but not the sine from the latest SW. Don't know if you need to use an older verion to get the sine to work.
How I did the FOC compile, in Linux Mint.
In Terminal, sudo apt-get install git gcc-arm-none-eabi
Create a folder with desired name.
In Terminal, go to folder and type: git clone https://github.com/jsphuebner/stm32-sine
Go into stm32-sine folder.
In Terminal, make get-deps.
In Terminal, CONTROL=FOC make
Now there is a stm32_foc.bin available.
If I try in Terminal, make, to build sine I get the following error message:
LD stm32_sine
/usr/lib/gcc/arm-none-eabi/9.2.1/../../../arm-none-eabi/bin/ld: obj/stm32_sine.o: in function `Param::Change(Param::PARAM_NUM)':
stm32_sine.cpp:(.text._ZN5Param6ChangeENS_9PARAM_NUME+0x52): undefined reference to `PwmGeneration::SetControllerGains(int, int)'
/usr/lib/gcc/arm-none-eabi/9.2.1/../../../arm-none-eabi/bin/ld: stm32_sine.cpp:(.text._ZN5Param6ChangeENS_9PARAM_NUME+0x84): undefined reference to `FOC::SetMotorParameters(float, float)'
collect2: error: ld returned 1 exit status
make: *** [Makefile:107: stm32_sine] Error 1
If you are on another OS (windows, mac) I got nothing
LD stm32_sine
I installed linux and was able to compile. Thank you! All my attempts to do this in windows turned out to be useless.
- youngpoland
- Has thanked: 14 times
When I run it, I get the error [18] DERATE-TMPHSMAX. The small_dual_v1d board has the latest soft stm32_sin loaded, only the gas pedal from BMW is connected.
- bexander
You get a heat sink temperature derate. What heat sink temperature sensor have you selected? I run "snshs": 1 i.e. "semikron". Seem to work well for the toyota inverters.
And what does your heat sink temperature read? "tmphs" under "Spot Values".
- youngpoland
thank you very much for the hint. change "snshs": 1 i.e. "semicron" helped. I am very grateful for your help
- youngpoland
I have another question. are all the parameters displayed in the web interface described somewhere? I will ask for a link.
- lsh3rd
- Has thanked: 117 times
- Been thanked: 40 times
Here you go:youngpoland wrote: ↑Thu Feb 16, 2023 7:50 pm I have another question. are all the parameters displayed in the web interface described somewhere? I will ask for a link.
https://openinverter.org/wiki/Parameters
